Latest post Thu, Oct 8 2009 12:00 PM by CharlieBAE. 4 replies.
  • Wed, Aug 12 2009 11:45 AM
    • podrush
    • Joined on Tue, Aug 11 2009
    • Posts 14
    • Points 200
    duplicate bins in interplay
    Hi everyone, got an odd situation...
    Interplay 1.6 on ISIS 2.01 using MC 3.5.4.3
    Editor checked a bunch of bins into interplay after re-naming the bins. project got re-replicated using back up background software, and original (un-renamed bins got checked in too) - dont ask me how I wasn't there at the time ;-)
    Net result is though, that there are two sets of Bins with identical contents (or near identical) but different names. I cant just remove them without dealing/deleting the contests somehow. I dont want the seqs and mstr clips to be deleted...
    Anyone found an elegant way of dealing with this?
    thx in advance
    graham
    from the quadra 900 in 1991 onwards [view my complete system specs]
  • Fri, Aug 14 2009 5:55 AM In reply to
    • lawsonr
    • Joined on Thu, Jun 8 2006
    • CBS News
    • Posts 313
    • Points 3,655
    Re: duplicate bins in interplay
    You're maybe overthinking it a bit.
    You can place a reservation on the Interplay folders you want to keep, and then delete the other folders and all associated metadata. Make sure you only delete clips and sequences and NOT the associated media.
    If anything you wanted to keep in Interplay disappears, then you can just check in all the properly named bins again.
    Avid NewsCutter v10.5.4, ISIS 7000 v4.6.1, Interplay 2.7, Interplay Central 1.8 [view my complete system specs]
  • Sun, Sep 6 2009 9:56 PM In reply to
    • podrush
    • Posts 14
    • Points 200
    Hi Rob, thanks for the reply, you are right I think I was overcomplicating it for myself - we are going to go down this route, will update how we get on...
  • Thu, Oct 1 2009 7:58 PM In reply to
    • Stephen Hull
    • Tulsa, OK
    • Posts 35
    • Points 420
    I use this approace all the time to clean up projects checked in using an incorrect project path.  There's nothing more irritating than having a sports program check into the middle of your hunting program and again in the middle of a documentary.
    Make sure not to delete media, only meta data.  That would be bad.
    Unity, ISIS, Interplay, Media Composers [view my complete system specs]
    Stephen H Media Manager WinnerComm Tulsa, OK
  • Thu, Oct 8 2009 12:00 PM In reply to
    another approach which we have discussed but not implemented is when the job is done (and properly cleaned up) delete the folder from Interplay. Then open up job and re-check in all bins and sequences. This will keep your final cleaned up sequences and bins in your database in the correct more searchable order. Another thing is to create a delete me bin and color all clips in it blue. Anything blue in your project (no matter what bin its in) doesn't belong. Reservations on folders (you want to keep) seems like its a easier idea. I was unaware of this feature.
