Latest post Thu, Sep 3 2009 8:29 PM by Rich. 16 replies.
  • Wed, Aug 12 2009 1:01 AM
    • Avid 99
    • Dallas, Texas
    • Posts 448
    • Points 5,750
    MC 3.1.3 with OS 10.5.7 or 10.5.8 & QT 7.6.2
    It's gotta' be asked (if it hasn't been already):  Is anybody successfully running MC 3.1.3 with OS 10.5.7, or 10.5.8, and the latest version of Quicktime (7.6.2)?
    These are required for the new FCS.
    MBP 17" - 1x2 2.66 - 4G RAM - 10.5.8 - 7.6.2 - MC 3.1.3 <<<<<>>>>>> MP (1/08) - 2x4 3GHz - 32G RAM - 10.5.8 - 7.6... [view my complete system specs]
  • Wed, Aug 12 2009 5:53 AM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 472
    • Points 5,820
    Re: MC 3.1.3 with OS 10.5.7 or 10.5.8 & QT 7.6.2
    I have been told by other users that this combo does work.  I am planning on trying myself over the weekend.
    Cheers,
    jef
    MC 3.1.3 Mac Dual 2.8 8core ATI2600 OS 10.5.7 QT 7.6 10 GB ram 2xSATA software raid local storage [view my complete system specs]
  • Wed, Aug 12 2009 6:18 PM In reply to
    • heyriddle
    • Posts 28
    • Points 390
    We have a workstation that is not mission critical that has an updated OS.  We only use Avid MC occasionally on it, but it is functioning properly.  It is a Mac Pro 2x3Ghz with 4GB ram and the ATI Radeon X1900 (512MB), Mac OS 10.5.8, QuickTime 6.5.2 and Avid MC 3.1.2.  Hope that helps.
  • Sun, Aug 16 2009 2:25 AM In reply to
    • jef
    • Maryland
    • Posts 472
    • Points 5,820
    Ok, so I did a small test of MC 3.1.2 on a MacPro 09 2x2.8 quad core 10.5.7 QT 7.6.2 with an old analog Mojo.  Seems to be fine.  Opened a Multicam sequences and all looked ok.  I give it more of a test and get back.
    Jef
  • Sun, Aug 16 2009 2:36 AM In reply to
    • Rich
    • South Florida
    • Posts 194
    • Points 2,430
    Thanks for keeping us updated Jef. I almost went to 10.5.8 but thought I should wait until I'm finished with these last few projects.
    MC 3.1.3 Adrenaline MacPro 3GHz Dual Core OSX 10.5.8 *MC v12.0.6 G4 933mhz. OS 10.2.6 *MC 3.1.3 MacBook Pro 2.4 GHz 17 PB OSX 10.5.8 [view my complete system specs]
  • Tue, Aug 18 2009 4:49 AM In reply to
    • jef
    • Maryland
    • Posts 472
    • Points 5,820
    Just to add ... captured some 2:1 MXF via Mojo analog and exported an Animation QT no problems.
    Knock on wood.
    Jef
  • Tue, Aug 18 2009 2:28 PM In reply to
    • Avid 99
    • Dallas, Texas
    • Posts 448
    • Points 5,750
    I'll just add that I went ahead and updated to this config, and Avid has launched without crashing, and I poked and twiddled a bit, with no ill effects, so far.
  • Tue, Aug 18 2009 11:52 PM In reply to
    • Rich
    • South Florida
    • Posts 194
    • Points 2,430
    Which configuration? 10.5.8 & QT 7.6.2?
  • Thu, Aug 20 2009 11:52 PM In reply to
    • sedavis
    • Austin, Texas
    • Posts 169
    • Points 2,085
    Running both on my MacPro 2.8 with 6 gb of RAM.  No problems so far running software only.
    Office - G5 quad 2.5 with 4 GB ram, Adrenaline and Avid VideoRaid 320 with 2.5 TB storage. Home - G5 Mac Pro 8 core 2.8, 6 GB RAM, 3 TB internal SATA... [view my complete system specs]
    Don't ask me, I don't know either.
  • Fri, Aug 21 2009 12:33 AM In reply to
    • Rich
    • South Florida
    • Posts 194
    • Points 2,430
    I guess you guys are all running 10.5.8 & QT 7.6???
  • Fri, Aug 21 2009 9:41 PM In reply to
    • Avid 99
    • Dallas, Texas
    • Posts 448
    • Points 5,750
    Rich:
    I am now.  7.6.2 (& 10.5.8)
  • Fri, Aug 21 2009 10:22 PM In reply to
    • Rich
    • South Florida
    • Posts 194
    • Points 2,430
    thanks for the update. I'll give it a go on Monday as well.
  • Wed, Sep 2 2009 8:44 PM In reply to
    • Avid 99
    • Dallas, Texas
    • Posts 448
    • Points 5,750
    I thought I'd better post back.  I did my first real edit job with this configuration today.  NOT GOOD.  I kept getting the SPOD every two minutes.  The bad kind that force you to hold the power button down in order to really force quit.
    I was working with HDV source material that had been video-mixed-down to a DNxHD track.  All I was doing was audio mix and audio edit tasks.
    After about a dozen of the SPODs and forced reboots, I booted my system off an ext. FW drive running OSX 10.5.5.  THEN, no beach balls.
    So, my conclusion is that 10.5.8 with MC 3.1.3 is a NO GO.  At least for me.  YMMV.
    Sorry to be the bringer of bad news.
    Jim
  • Thu, Sep 3 2009 3:58 PM In reply to
    • jef
    • Maryland
    • Posts 472
    • Points 5,820
    Interesting - in a bad way.
    Thanks for posting.  Your workflow is somehting I never do (HDV) so I can not double check.
    Jef
  • Thu, Sep 3 2009 7:54 PM In reply to
    • Avid 99
    • Dallas, Texas
    • Posts 448
    • Points 5,750
    It's actually now much worse than my last report.  Apparently the crashing caused by 3.1.3 on 10.5.8 caused many fonts to be damaged, and was causing some other weirdness.  I believe that Apple has truly hosed us with 10.5.8. It's slower than 10.5.5 was.
    I had a clone, so I restored my system back to 10.5.5.  That puts me back into FCS2-land, which is OK.  I worked with FCS3 for a bit, and nothing big to report there.  I do like the new ripple-able markers.  But, I'll live.
    Maybe I'll try to upgrade to 10.5.7 at some point, and see if Avid likes that any better than 10.5.8.  Might not be soon; I have a lot of work booked up right now.
    BTW, Jef... I don't think the problem was HDV footage.  The timeline I was playing was a Video Mixdown from HDV to DNxHD.
