Latest post Mon, Aug 10 2009 12:32 PM by mvegas. 7 replies.
  • Sun, Aug 9 2009 1:13 PM
    • maxxim
    • Joined on Sun, Aug 9 2009
    • Posts 3
    • Points 55
    need help about MC
    Hello
    recently i have buy on ebay PowerMac 9600/350 sold as Avid workstation
    Have recived the set with some HW cards inside:
    1) audio card (cant remember the name , has a scsi connector to wire 442 audio box)
    2) UL3D scsi card
    3) 0030-00019-02 AVBV with SDI Top Card
    4) 0870-00169-03 Janus/Gasket
    Then was includes 442 and Video external box , lots cables and 2 dongles
    the dongles dump at botom of this message
    I guess the 2 dongles not working with this hardware i bought , someone can pls clear
    what model is this HW confirguration? 9000 or 1000?
    What software versions i can install? i have found MC7.1 on ebay but it shutdown with message no valid
    dongle licenses.
    thanks
    Dump for key #dongle1
    Avid System ID: *****
    Product: Media Composer
    Model: Avid Xpress
    Version: 0.0.x (0)
    Extra Options:
    AVR 3s
    4 Video Tracks
    AVR 75
    Xpress Pro Effects
    Xpress Fast Render Effects
    Xpress RealTime Play Effects
    AVR 77
    Complete List:
    Timeline/pict
    bins/etc
    + AVR 3s
    Digitize Window
    Edit Window
    Deck control
    AVR 12 *
    Full Rate Only
    Pre-Vis-1 Title Tool
    + 4 Video Tracks
    Picture-In-Picture Effect *
    opt_PreVis_BC2
    No AutoSync
    TC Base
    8 Audio Tracks
    + AVR 75
    + Xpress Pro Effects
    MCX UI
    AVR 71
    MCX base effects
    + Xpress Fast Render Effects
    + Xpress RealTime Play Effects
    + AVR 77
    Items marked with "+" are extra options. All others are standard to the model.
    Dump for key #dongle2
    Model: Model 1000
    Version: 0.0.x (0)
    Extra Options:
    No AutoSync
    Complete List:
    Enhanced Audio (2n2/CD)
    Timeline/pict bins/etc
    AVR 3s
    Digitize Window
    Edit Window
    Deck control
    Dissolves only
    AVR 70
    AVR 26
    Full Rate Only
    Pre-Vis-1
    Visual Effects
    Transitional Vis Effects
    Programmable Vis Effects
    Title Tool
    8 Video Tracks
    AVR 25
    + No AutoSync
    TC Base Real
    Time Color Correction
    Real Time Dissolves/Wipes
    Real Time 2D
    DVE Real Time Titles
    AVR 75
  • Sun, Aug 9 2009 5:51 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,836
    • Points 201,230
    Re: need help about MC
    This is not a Media Composer system. It is an old Avid Xpress system. They were two different products so that's the software you will need to load.
  • Sun, Aug 9 2009 6:02 PM In reply to
    One of the 2 systems is a Media Composer.  The 2nd dongle dump includes ...
    Model: Model 1000
    Media Composer 3.5.9/4.0.2 w/Mojo (analog), HP xw8400, 1xQC 3.0GHz, 8GB RAM, FX 3700, 1TB Boot, 1 x 1TB & 1 x 500GB internal SATA media drives, 3-Ware... [view my complete system specs]
    Our new websites are up!
    http://www.lifenetintl.org/
    http://www.capitalchristian.net/
  • Sun, Aug 9 2009 6:13 PM In reply to
    Your dumps both report the version as:
    Version: 0.0.x (0)
    This might indicate the dongles are defective.  Aer you running the Dongle Dumper on the system you bought?
  • Sun, Aug 9 2009 6:50 PM In reply to
    • maxxim
    • Posts 3
    • Points 55
    Thanks for all replies
    Yes i have used the dongle dumper application  included in the MC7.1  i have bought
    ebay dont know if it give correct informations about dongles details.
    so if this HW is an expres someone can tell me more details please , i am hobbist and new to avid systems
    since its very old more than 10 years was very cheaper , so i need to know what software and wich version i need
    make working this system with those dongles , wich the best in quality among the 2? still for sale the soft i need?
  • Sun, Aug 9 2009 7:21 PM In reply to
    You've got quite a dinosaur there.  I don't know how much luck you'll have finding the right software version to work and even if you did the limitations of the old software would make it a bear to use.  No HD, no DV, no mixing of resolutions in the Timeline, depending on exactly how old it is - it may not even have a built in Title Tool.
    If you're a hobbyist and new to Avid, this software/hardware combo may not be your best option as an introduction to the Avid editing world.
    Warning - Car Analogy:
    It would be like if you just got your licensce and found a 1946 Ford that needed an engine rebuild.  If you're not intimately familiar with all the components and mechanically inclined, you may find yourself more frustrated with your new toy than actually using it.  Whereas - spending a little money to get a newer vehicle with fewer issues will help get you on the road a lot quicker.
  • Sun, Aug 9 2009 7:42 PM In reply to
    • maxxim
    • Posts 3
    • Points 55
    I know Kenton , sure am new to this and thats why am here asking to expert
    ..its very old system but enough for my needed because willing to use it only for some video analogic cut and paid everything just '90 euro'
    so i know alredy cant expect that much , i just need for a simple system but want at output have same quality of input.
    if you know some links where i can learn about old systems please post it.
  • Mon, Aug 10 2009 12:32 PM In reply to
    • mvegas
    • Posts 1,436
    • Points 16,450
    By the time Avid supported the PMAC 9600, Avid also supported Mac OS 7.6.1, 8.0, 8.1, 8.5.1 or 8.6 with MC software versions 7.x.  The most stable OS was 8.1.  OS 8.5.1 and 8.6 were ram hogs, needed 40mb ram just to run itself.  Avid officially supports only up to 32mb DIMMs memory chips in the 9600 and with a total of 12 memory slots in the CPU the total ram supported is only 384 mbs tops.  You can most likely find Mac OS software on the web.  There are web sites that have old or vintage software to download, often times free of charge.  With only 8 tracks of audio available, BLKDOG is right, seems as if you have the dongle for a MC Xpress.  The audio board was called Amadeus (Mozart).  The 9600, while no speed merchant, was a very reliable box.  Kudos to Apple for the wonderful clamshell design, making it very easy to open and replace boards, add Ram, etc. (Apple had to do something to redeem itself after the PMAC 9500 which forced you to literally remove the motherboard from the chassis in order to add ram, etc).  Since the OS loads a plethora of printer inits and monitor inits, make sure you add a folder to the systems folder calling it disabled extensions and streamline the OS extensions as much as possible.  Limit too the number of active fonts to no more than 120ish.  As long as you are not asking too much of the system (and from you state above it seems as if you are not), its a great system as long as the hardware boards work.
