Latest post Fri, Aug 7 2009 4:58 PM by Aaron Montoya. 3 replies.
  • Fri, Aug 7 2009 1:10 AM
    • Aaron Montoya
    • Joined on Fri, Jun 5 2009
    • Costa Rica
    • Posts 8
    • Points 100
    Import P2 Files
    I need import p2 files 60i 1920x1080i in 24p 1920x1080p any idea................
  • Fri, Aug 7 2009 1:44 AM In reply to
    • SmacDiddy
    • Joined on Thu, Aug 6 2009
    • Posts 4
    • Points 60
    Re: Import P2 Files
     know to get P2 footage into the DS is through a Media Composer. You use the Import P2 function in the MC and generate an AAF and MXF media. Bring the AAF into a 59.94 project, park on the FIRST jitter frame in the cadaince and apply a 3:2 contract which should remove the pulldown and then export a TGA sequence and import the TGA sequence into a 23.98 sequence.
  • Fri, Aug 7 2009 3:06 AM In reply to
    • slabross
    • Montreal
    • Posts 381
    • Points 3,800
      Moderator: Avid DS
    Re: Import P2 Files
    Or hold the F key and drag the 59.94 clips into the 24p timeline, then add a 3:2 contract effect on these clips to produce the correct play speed.  This avoids the file export and import.
    Sylvain Labrosse
    Avid DS Product Champion | Video Customer Success
    Avid
    3510 St-Laurent Boulevard
    Montréal, QC H2X 2V2
    Canada
    sylvain.labrosse@avid.com
    We're Avid.  Learn more at www.avid.com
  • Fri, Aug 7 2009 4:58 PM In reply to
    • Aaron Montoya
    • Costa Rica
    • Posts 8
    • Points 100
    Re: Import P2 Files
    Thanks guys I try both options
