Latest post Fri, Aug 7 2009 5:21 PM by Randall L Rike. 11 replies.
Page 1 of 1 (12 items)
  • Tue, Aug 4 2009 12:58 AM
    • Maureen
    • Joined on Mon, Aug 3 2009
    • Posts 2
    • Points 30
    Symphony Nitris p2 workflow (NO DX upgrade)
    My facility currently has two Avid Symphony Nirtis's.  We will be upgrading to media composer DX in the near future but haven't yet.  A short project has been brought in that was shot on P2.  My question is what is the appropriate workflow to work with this format on a Symphony Nitris?  I believe it can be done if we transcode but my online editor and engineer are arguing whether it's possible to do it without the DX upgrade.  Please help!
    Thanks in advance!
  • Tue, Aug 4 2009 1:24 AM In reply to
    Re: Symphony Nitris p2 workflow (NO DX upgrade)
    You don't need to Transcode, unless you really want to change the resolution.  The P2 media is MXF that Avid can work with directly.  If you're on SN prior to v3.5, you use File > Import P2 > Clips to Bin and then File > Import P2 > Media.  Thsi will populate a Bin with Master Clips and copy the media to your Avid media storage.  It's basically a Consolidate.  If you're on v3.5, you use File > Link to AMA Volumes.  Point to the P2 folder structure and the media will be linked and ready to edit.  No copy/consolidate required.  Very cool!  This also will populate a Bin with Master Clips.
    Media Composer 3.5.9/4.0.2 w/Mojo (analog), HP xw8400, 1xQC 3.0GHz, 8GB RAM, FX 3700, 1TB Boot, 1 x 1TB & 1 x 500GB internal SATA media drives, 3-Ware... [view my complete system specs]
    Our new websites are up!
    http://www.lifenetintl.org/
    http://www.capitalchristian.net/
  • Tue, Aug 4 2009 1:48 AM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 474
    • Points 5,830
    Totally agree with Randy.  But just to make sure, what version Symphony are you on?  Older versions might have slighty different issues.
    I know that the method he outlined work back to at least 1.8.3.
    Jef
    MC 3.1.3 Mac Dual 2.8 8core ATI2600 OS 10.5.7 QT 7.6 10 GB ram 2xSATA software raid local storage [view my complete system specs]
  • Tue, Aug 4 2009 6:32 AM In reply to
    Although Randy is not wrong, I slightly disagree.
    Classic Nitris does not actively support thin raster (1440 rather than 1920). That means that if you stay in native P2 (assuming DVCPROHD, not DV25), you will put the burden of thin raster processing on the CPU/GPU. Symphonies on older CPU's might not always cope with that.
    In the early days of Symphony Nitris 3.x, it was recommended to transcode to a full raster codec, to improve performance.
    So when I had a (fairly large) P2-based project last year, on SN 3.x, I used the "classic" way to import P2 clips, then, instead of "Import P2 Media" I chose to consolidate the clips into the system, at DNxHD120.
    That worked just fine. The classic Nitris has a hardware DNxHD codec, so performance with DNxHD is likely to be much smoother than with something like thin raster DVCPROHD (P2).
    Importing the media straightforward versus a transcode to DNxHD is a very minor difference in importing times (if any).
    Symphony Classic Nitris 4.0.2 on 2x 2.33 quad core XW8400/8GB Vista Biz 64bit | MC 4.0.2 on 2x dual core 2.66 XW8400/7GB Vista Biz 64bit | Mojo SDI | Unity... [view my complete system specs]
  • Tue, Aug 4 2009 9:18 AM In reply to
    • jakeheat
    • Joined on Sun, Sep 3 2006
    • Posts 152
    • Points 1,820
    Job's right.
    I did a P2 project in May, and although everything was smooth at the start, but as soon as my sequence got a little bit complex, my machine really started to slow down.  In retrospect I should have transocoded my media first, and then relinked to the original P2 files once my offline was done.
    If you're doing a straight Online, then just convert your P2 media to the highest DNxHD codec you can use.
    SYMPHONY NITRIS 3.5.4 HP xw8400 QT 7.6 Vista 64 ADRENALINE 3.5.1 PC HP xw8400 XP MC SOFT 4.0.2 PC HP xw8400 - & MacPro 3Ghz Quad OS 10.5.8 QT 7.6.2... [view my complete system specs]
  • Tue, Aug 4 2009 12:38 PM In reply to
    jakeheat:
    Just a thought: since DVPCRO is runs 100 Mbit/s, any DNxHD flavor higher than that should be more than fine. IMHO.
  • Tue, Aug 4 2009 2:05 PM In reply to
    • jakeheat
    • Posts 152
    • Points 1,820
    As you know lower Avid resolutions have trouble compressing complex images, and as P2 or Sony EX rushes tend to have a fair amount or artifacts and banding, you'll find that the higher the Avid resolution the closer the transcode will be to the original material. Furthermore, assuming this is an Online, the higher you go the better your effects and filters will look.
  • Tue, Aug 4 2009 7:16 PM In reply to
    • Maureen
    • Posts 2
    • Points 30
    We have version 1.6.4 and 1.6.7.  Will that workflow still work on our older versions???
    Thanks!
  • Tue, Aug 4 2009 7:39 PM In reply to
    jakeheat:
    I think that the DNxHD resolutions are quite a bit better than would be expected based on bandwidth figures. I am truely amazed at DNxHD36 for offline. Looks way better than it is entitled to ;-)
    Agreed, but you could transcode to DNxHD120, yet still do any rendering at DNxHD145x.
    Many ways to Rome. Indeed, if one can spare the storage, why not go for 145x.
  • Tue, Aug 4 2009 7:42 PM In reply to
    I think P2 import has improved a great deal with the arrival of version 3. If 1.6.x is what you have, I think I would try to use some smaller MC 3.x system to import (and transcode) the media, then take the media into your 1.6.x system.
    MC 3.5 offers a 14 day full functional trial. You might use it to import the P2 media within those 14 days.
  • Fri, Aug 7 2009 5:15 PM In reply to
    "You don't need to Transcode, unless you really want to change the resolution" or drop frames
    1.8.4 Read Me
    "Avid Symphony Nitris cannot always play back native DVCPRO HD media without
    dropping frames. This is due to the fact that on playback, the system has to create a version
    of the media at 1920x1080 at full resolution on-the-fly.
    Workaround: Transcode the media to Avid DNxHD or uncompresssed HD for real-time
    playback".
    From my experience you will need to transcode to a DNX resolution when preforming a digital cut.
  • Fri, Aug 7 2009 5:21 PM In reply to
    I stand corrected.
