Latest post Wed, Sep 16 2009 7:29 AM by camoscato. 18 replies.
Page 1 of 2 (19 items) 1 2 Next >
  • Sun, Aug 2 2009 8:01 AM
    • IBL
    • Los Angeles, CA
    • Posts 32
    • Points 405
    XDCAM offline when it's not - need 3.5.4 patch!
    Hello,
    I upgraded to 3.5.4 tonight in order to overcome ScriptSync issues and other AMA bugs, but now I'm dealing with an even worse bug!
    XDCAM EX media from mounted AMA volumes reads "media offline" on the sequence but when I match back, it plays fine in the source monitor. Only the video appears to be offline in the sequence, not audio, regardless which video track it's on. I've been searching around and it looks like Avid came up with a patch to fix this problem, but one has to get it directly from Marianna who is on vacation until August 10th! I'm on a tight deadline and don't want to spend $200 to call Avid tech support. Any suggestions?
    Thanks!
    MC 3.5.6 + SD Mojo OSX 10.5.5 Mac Pro 8-core 3Ghz 6 GB RAM [view my complete system specs]
  • Sun, Aug 2 2009 2:58 PM In reply to
    • camoscato
    • Posts 6,586
    • Points 78,755
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: XDCAM offline when it's not - need 3.5.4 patch!
    I don't think you have to pay for the support call in order to get the patch.  If you can't get through to a human being to explain what you need, contact Todd Smelser (user ID: BLKDOG) and he ought to be able to get you pointed in the right direction.
    good luck,
    Carl
    MC 4.0.5, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 4 GB RAM, nVidia GeForce 7150M, Conexant HD Audio, G-tech 500GB G-drive [view my complete system specs]
    There is no such thing as a video emergency.
    I've got a new website for 2010!
  • Sun, Aug 2 2009 6:02 PM In reply to
    • pierreh
    • Paris, London
    • Posts 662
    • Points 8,095
    Hum I'm about to start a film shot on XDCam EX, what is this story about patch?
    Personal system: MacBookPro 2.5Ghz, 4Gig Mem, Mojo SDi - Work system: MacPro Nehalem, 3 monitors, internal Raid setup [view my complete system specs]
  • Sun, Aug 2 2009 6:14 PM In reply to
    • IBL
    • Los Angeles, CA
    • Posts 32
    • Points 405
    Stay with MC 3.5.1 if you can, or wait for 3.5.6 official release, which should be soon.
    If you intend to work with AMA volumes without consolidating to local hard drive, 3.5.4 is useless. It has a bug that displays "media offline" in the sequence even if the media is there.
    Hope this helps. I'm cutting a feature doc all shot with XDCAM EX, so if you have any other questions, feel free to contact me.
  • Sun, Aug 2 2009 6:23 PM In reply to
    • pierreh
    • Paris, London
    • Posts 662
    • Points 8,095
    Thanks for your reply, the shoot starts on the 17th of August - any idea if 3.5.6 will be released by then?
    We're not intending to edit with AMA volumes, but once the edit will be finished (using DNxHD36), we will relink to the original XDCam files via AMA to do the playout/export...
  • Sun, Aug 2 2009 6:35 PM In reply to
    • IBL
    • Los Angeles, CA
    • Posts 32
    • Points 405
    Have no idea when 3.5.6 will be released, but if you plan to consolidate to DNxHD36, you should be good to go with 3.5.4. It should relink just fine and you can always update your software when it is officially released.
  • Wed, Aug 12 2009 12:07 PM In reply to
    • avdesign
    • Joined on Mon, Jan 30 2006
    • Netherlands
    • Posts 24
    • Points 250
    I received the 3.5.6 for MAC version via my AVID rep.; solved the AMA issue!
    Note that it's a MAC bug only. 3.5.4 on PC runs OK.
    AVID Media Composer with NITRIS DX (MAC Pro), with MOJO SDI & Studio Essentials (PC), MacBookPro with MC3 on OS X.5 & Win XP (Studio Essentials... [view my complete system specs]
    ______________________________________
    Richard C. van Nijnatten MA, SOC, MBKS
    The Netherlands
  • Wed, Aug 12 2009 2:15 PM In reply to
    • Posts 2,076
    • Points 25,765
      Avid Employee
      Moderator: Broadcast Newsroom
    Folks....
    The softwre that asdesign references is a CPR - Customer Patch Release. CPRs should only be used to resolve a specific issue addressed in the respective CPR.  It's not an "official update."
    If you have Avid Support, I suggest contacting support for the release. If you don't have support I suggest contacting me directly.
    Customer Advocate/Customer Success [view my complete system specs]
    AOL IM avidmarianna
  • Sat, Aug 15 2009 3:16 PM In reply to
    • avdesign
    • Netherlands
    • Posts 24
    • Points 250
    Although... so I was told.... 3.5.4 on PC turns out having the same issue...
    Can I download the 3.5.6 patch somewhere Marianna? Need it fast, in order to finish a project!
    Richard van Nijnatten
    AVDESIGN
    The Netherlands
  • Sat, Aug 15 2009 6:18 PM In reply to
    You could try a workaround if you need to fix it very soon: Put any effect on all the videoclips (maybe just the video on tracks obove 1 - not shure) and render (maybe a resize without resizing). This fixed it for me. But it really is a annoying workaround.
    I hope it works for you. For me it did.
    MacPro 2x3 GHz DualCore Xeon NVIDIA GeForce 7300 GT OSX 10.5.7 Avid MediaComposer 3.5.6 QT 7.6.2 [view my complete system specs]
  • Sat, Aug 15 2009 11:14 PM In reply to
    • avdesign
    • Netherlands
    • Posts 24
    • Points 250
    I know about the workarounds, but those will not work for me.
    Back to 3.5.1 is no option as this version is very buggy with AMA/XDCAM EX files; many crashes, strange error messages and worst of all - the most important bug fix in 3.5.4 - the audio cannot be patched to other tracks than 1 and 2.
    Working in 3.5.4 with only one layer is no option either, as I need to add lower thirds and keys.
    3.5.6 patch on MAC works fine, but I need to work on the customers PC for this project, where all footage is in XDCAM EX.
    The only option I see right now is a very time and diskspace consuming process of transcoding everything to DNxHD, with as a result loosing all links to the original files, so cannot reload/batch convert when I have deleted the MXF media files.... and that's not where I'm paying AVID the big bugs for....
    I really don't understand why AVID has so much trouble in getting it right, as they seem to be the only one...
    Most of us are working as professionals in a very though and fast business, and no one can afford loosing time (and customers) over a stupid software bug. AVID really needs to get its act together as this for sure will not help to gain back some of the many editors that moved away to FCP... for a reason I almost would say.
    Don't know about you people, but I get a feeling that since the introduction of filebased HD I'm spending more time in getting (and keeping) my tools to work than on editing...Hmm
    The Netherlands
  • Sat, Aug 15 2009 11:26 PM In reply to
    • avdesign
    • Netherlands
    • Posts 24
    • Points 250
    Wow, that's fast!. Just received an email from my AVID rep. (Saturday evening late!), with a link to download a CPR version 3.5.4.3 that should have all bugs fixed. Haven't opened it yet, but have to share this swift response with you. I think I'm in my rights to be pissed when they screw up, but they also deserve compliments when they provide excellent service Smile
    The Netherlands
  • Sun, Aug 16 2009 10:43 AM In reply to
    • avdesign
    • Netherlands
    • Posts 24
    • Points 250
    IT WORKS! Thank you Olaf!
    The Netherlands
  • Sun, Aug 16 2009 12:14 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 16,585
    • Points 210,550
    3.5.4.3 is Windows Only. If you are on a Mac, then you received something different.
  • Sun, Aug 16 2009 12:34 PM In reply to
    • avdesign
    • Netherlands
    • Posts 24
    • Points 250
    Correct. For MAC I received version 3.5.6 (see my earlier post). This is a CPR.
    The Netherlands
