charan:what is MC11.8? is it a new series of media composer?
No, it's actually a really old version of MC. MC 3.5.x is the most current version.
good luck,Carl
can i run MC 3.0 or higher(3.5.4) on windows 7 OS??
i have currently HP xw8000 PC XP sp2 MC 3.0.5 Adrenaline DNA 3.5 gb mem matrox perhelia(can be upgaded to NVidia quadro fx 3300 or 3500)
pls suggest!
charan:can i run MC 3.0 or higher(3.5.4) on windows 7 OS??
No. Windows 7 isn't qualified yet.
camoscato: curiosity: Okay I bit the bullet and set up a system to try this out. Windows 7 (Beta7000) - 64bit Ultimate - formatted the hard drive and installed really quickly (much quicker than XP). Avid MC 3.1.2 installed with only a couple of errors (I got a illegal function call error during the install - but I was unable to determine what is was in reference to.) I dismissed the errors and completed the installation. MC loads fine - and basic functions (capturing video, playback to a deck/client display), basic edits, all work correctly.
curiosity:
i have read the article in Avid Media Composer - PC » MC on Windows 7
what does it mean?
charan:what does it mean?
It means those guys are playing with their systems to see if Windows 7 works or not. That's fine if you do not need your system to work all day every day because you rely on your system to make money.
If you need the system to run all the time, stick with the system requirements. Windows 7 is not listed on the system requirements.
thanks for ur suggessions. i will stick to my existing configuration.
how can i change the title of this post??
how can i rename the captured clips in MC so that the new name should display in every project in media tool??
i have caputured clip named jackson's birthday but it should be krimy's birhtday, how can we change the name in original clip so that we can get krimy's birhtday in every project in media tool.
when i insert edit a clip in mC 3.0.5 to a tape with DSR 1800p 4 ch deck, it does not record few frames of audio at the start(audio missing at start after insert edit).i have tried this with other deck modules in digital cut tool and different digital cut offset but i failed. then i tried this job with dsr 20p,30p,40p,45p and i succeed.
pls help me!
Are you doing a digital cut over FireWire or are you using RS-422? The latter is what is supported for the DSR1800, IIRC.
i am using FireWire not RS-422
DSR1800, IIRC what does it mean
IIRC= If I Recall (or Remember) Correctly.
There used to be a list of supported decks on the Avid website, stating under which conditions they could be used (FireWire, RS422, Digital Cut, Insert Edit, etc), but the unusable Knowledge Base doesn't come up with a darn thing. Neither does Google.
*edit* through Google I found a list of Supported Devices and it does list the DSR1800 as supported for both IEE1394 and RS-422, but under Digital Cut it says "Fully Supported" for PAL and "Fully Supported with Inconsistent Results" for NTSC.
Just another thought: are both the deck and the Avid properly genlocked?
It also says it only supports 4ch audio at 32KHz, not 48K.
charan:how can i rename the captured clips in MC so that the new name should display in every project in media tool?? i have caputured clip named jackson's birthday but it should be krimy's birhtday, how can we change the name in original clip so that we can get krimy's birhtday in every project in media tool.
Usually you just click on the name of a clip in the bin and type a new name. The new name should show up in the media tool. If that's not working, can you post a screen shot of where you're trying to change the clip name?
when we rename the clip in the bin it is changed in bin and media tool only for the project we are working on but when we open the same clip in media tool in another project, it shows the name of the clip which was originally captured.
I am just thinking loud and I am not at my system right now, but it might be possible to rename clips when you are using MDV, not at all sure however.
Tomas
