Latest post Tue, Aug 25 2009 10:45 AM by mjolnarn. 32 replies.
Page 2 of 3 (33 items) < Previous 1 2 3 Next >
  • Wed, Aug 5 2009 5:56 PM In reply to
    • camoscato
    • Posts 6,093
    • Points 73,065
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: related to Equivelent version of media composer
    charan:
    what is MC11.8? is it a new series of media composer?
    No, it's actually a really old version of MC.  MC 3.5.x is the most current version.
    good luck,
    Carl
    MC 3.5.4, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 4 GB RAM, nVidia GeForce 7150M, Conexant HD Audio, G-tech 500GB G-drive [view my complete system specs]
  • Thu, Aug 20 2009 9:01 PM In reply to
    • charan
    • Joined on Sun, Apr 6 2008
    • India
    • Posts 24
    • Points 305
    can i run MC 3.0 or higher(3.5.4) on windows 7 OS??
    i have currently HP xw8000 PC XP sp2 MC 3.0.5 Adrenaline DNA 3.5 gb mem matrox perhelia(can be upgaded to NVidia quadro fx 3300 or 3500)
    pls suggest!
    workstation HP xw8000,WinXP Pro sp2,3.5 GB RAM, NVIDIA quadro fx 3000, Adrenaline DNA, Media composer 3.5.1,striped drives of Avid's 6th gen SCSI drives [view my complete system specs]
  • Thu, Aug 20 2009 9:07 PM In reply to
    • camoscato
    • Posts 6,093
    • Points 73,065
      Moderator: Meridien
    charan:
    No.  Windows 7 isn't qualified yet.
    good luck,
    Carl
  • Thu, Aug 20 2009 9:17 PM In reply to
    • charan
    • India
    • Posts 24
    • Points 305
    camoscato:
    curiosity:
    Okay I bit the bullet and set up a system to try this out. Windows 7 (Beta7000) - 64bit Ultimate - formatted the hard drive and installed really quickly (much quicker than XP).
    Avid MC 3.1.2 installed with only a couple of errors (I got a illegal function call error during the install - but I was unable to determine what is was in reference to.) I dismissed the errors and completed the installation.
    MC loads fine - and basic functions (capturing video, playback to a deck/client display), basic edits, all work correctly.
    i have read the article in  Avid Media Composer - PC » MC on Windows 7
    what does it mean?
  • Thu, Aug 20 2009 9:44 PM In reply to
    • camoscato
    • Posts 6,093
    • Points 73,065
      Moderator: Meridien
    charan:
    what does it mean?
    It means those guys are playing with their systems to see if Windows 7 works or not.  That's fine if you do not need your system to work all day every day because you rely on your system to make money.
    If you need the system to run all the time, stick with the system requirements.  Windows 7 is not listed on the system requirements.
    good luck,
    Carl
  • Fri, Aug 21 2009 3:40 PM In reply to
    • charan
    • India
    • Posts 24
    • Points 305
    thanks for ur suggessions. i will stick to my existing configuration.
    how can i change the title of this post??
  • Mon, Aug 24 2009 5:12 PM In reply to
    • charan
    • India
    • Posts 24
    • Points 305
    how can i rename the captured clips in MC so that the new name should display in every project in media tool??
    i have caputured clip named jackson's birthday but it should be krimy's birhtday, how can we change the name in original clip so that we can get krimy's birhtday in every project in media tool.
  • Mon, Aug 24 2009 5:59 PM In reply to
    • charan
    • India
    • Posts 24
    • Points 305
    when i insert edit a clip in mC 3.0.5 to a tape with DSR 1800p 4 ch deck, it does not record few frames of audio at the start(audio missing at start after insert edit).i have tried this with other deck modules in digital cut tool and different digital cut offset but i failed. then i tried this job with dsr 20p,30p,40p,45p and i succeed.
    pls help me!
  • Mon, Aug 24 2009 6:22 PM In reply to
    Are you doing a digital cut over FireWire or are you using RS-422? The latter is what is supported for the DSR1800, IIRC.
    Symphony Classic Nitris 4.0.2 on 2x 2.33 quad core XW8400/8GB Vista Biz 64bit | MC 4.0.2 on 2x dual core 2.66 XW8400/7GB Vista Biz 64bit | Mojo SDI | Unity... [view my complete system specs]
  • Mon, Aug 24 2009 6:28 PM In reply to
    • charan
    • India
    • Posts 24
    • Points 305
    i am using FireWire not RS-422
    DSR1800, IIRC what does it mean
  • Mon, Aug 24 2009 6:45 PM In reply to
    IIRC= If I Recall (or Remember) Correctly.
    There used to be a list of supported decks on the Avid website, stating under which conditions they could be used (FireWire, RS422, Digital Cut, Insert Edit, etc), but the unusable Knowledge Base doesn't come up with a darn thing. Neither does Google.
    *edit* through Google I found a list of Supported Devices and it does list the DSR1800 as supported for both IEE1394 and RS-422, but under Digital Cut it says "Fully Supported" for PAL and "Fully Supported with Inconsistent Results" for NTSC.
    Just another thought: are both the deck and the Avid properly genlocked?
    It also says it only supports 4ch audio at 32KHz, not 48K.
  • Tue, Aug 25 2009 6:26 AM In reply to
    • charan
    • India
    • Posts 24
    • Points 305
    Rename of captured clips in media composer
  • Tue, Aug 25 2009 8:52 AM In reply to
    • camoscato
    • Posts 6,093
    • Points 73,065
      Moderator: Meridien
    Re: Rename of captured clips in media composer
    charan:
    Usually you just click on the name of a clip in the bin and type a new name.  The new name should show up in the media tool.  If that's not working, can you post a screen shot of where you're trying to change the clip name?
    good luck,
    Carl
  • Tue, Aug 25 2009 9:13 AM In reply to
    • charan
    • India
    • Posts 24
    • Points 305
    when we rename the clip in the bin it is changed in bin and media tool only for the project we are working on but when we open the same clip in media tool in another project, it shows the name of the clip which was originally captured.
  • Tue, Aug 25 2009 9:21 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 3,122
    • Points 35,670
    I am just thinking loud and I am not at my system right now, but it might be possible to rename clips when you are using MDV, not at all sure however.
    MC 4,03 ( Liquid 7,2 ) V 64 Ultimate Mbo gigabyte 965-DQ6,cpu quad core QX 6700, mem Corsair Dominator 8500 8 GB, PNY Quadro 1800, Soundblaster X-Fi... [view my complete system specs]
    Tomas
