Latest post Sun, Nov 1 2009 5:15 PM by Job ter Burg. 8 replies.
Page 1 of 1 (9 items)
  • Wed, Jul 29 2009 3:03 PM
    • birck
    • Montreal, Canada
    • Posts 21
    • Points 235
    Does the Link to AMA works with the RED Camera?
    Hi everyone. I was wondering if the Link to AMA works with the RED Camera (R3D files or QuickTime ref.)?
    Thanks in advance.
    Avid MC 3.5.9 with Mojo DX, Win XP sp2. HP xw8600 2x2.66 GHz dual Quad core, 4gb RAM, QuadroFX 1700. [view my complete system specs]
  • Wed, Jul 29 2009 3:27 PM In reply to
    Re: Does the Link to AMA works with the RED Camera?
    Currently only P2 & XDCAM.  We are hopeful for more file formats to be added.
    Media Composer 3.5.9/4.0.2 w/Mojo (analog), HP xw8400, 1xQC 3.0GHz, 8GB RAM, FX 3700, 1TB Boot, 1 x 1TB & 1 x 500GB internal SATA media drives, 3-Ware... [view my complete system specs]
    Our new websites are up!
    http://www.lifenetintl.org/
    http://www.capitalchristian.net/
  • Wed, Jul 29 2009 4:16 PM In reply to
    birck:
    For that, there's MetaFuze 2.0 now (released yesterday): http://www.avid.com/metafuze.
    As far as I can tell, the difference is that AMA is meant to work with formats and codecs that the Avid can handle natively. Since the R3D's have such a different size and aspect ratio (up to 4096x2048) than "regular" video formats, as well as the need to use a colorspace conversion (Redspace to Rec709), it's not something that AMA may easily work with. I'd think.
    Symphony Classic Nitris 4.0.2 on 2x 2.33 quad core XW8400/8GB Vista Biz 64bit | MC 4.0.2 on 2x dual core 2.66 XW8400/7GB Vista Biz 64bit | Mojo SDI | Unity... [view my complete system specs]
  • Wed, Jul 29 2009 7:46 PM In reply to
    • birck
    • Montreal, Canada
    • Posts 21
    • Points 235
    I see... thanks for the quick reply. I guess we will have to work with METAFuze!
  • Wed, Jul 29 2009 8:15 PM In reply to
    Be sure to check out the new MetaFuze forum on this site.
    MetaFuze 2 allows you to scan one or more selectable folders for R3D files, choose a transcode type, batch change parameters (like scaling quality, destination codec flavor, burnin timecodes and source tape names, Project names, etc) and then it is able to use all available cores on your machine (and apparently even those on a remote machine) to transcode the R3D into DNxHD Avid MXF MediaFiles, whcih you can drag straight into your mediafiles folders, and access from the Media Tool (or you can have MetaFuze create you an ALE for the transcoded clips).
    Like everything around the Red (perhaps with the exception of the BaseLight BLT station), you'll be looking at render times, but MetaFuze is a very decent option. I think it takes me around 5-6 hours to transcode 100GB worth of dailies into DNxHD36, using a dual-dual-core machine.
  • Thu, Sep 3 2009 4:12 PM In reply to
    • Glans
    • Sweden
    • Posts 192
    • Points 2,735
    Wouldn't it be possible to link with AMA to the proxy files? For offline work and test-edit on location, that is the way to go. If AMA can link to the HD proxies, then we can edit offline with timecode and metadata, right?
    All we need is that someone creates that possibility.
    As for other formats, why wouldn't it be possible to edit a DV PAL 25p with AMA? P2 Media can still be edited right off the card due to it's MXF fileformat, so AMA doesn't change much.
    AMA is a great step twords the thing that FCP users always complain about Avid; enable you to work right off a file without any transcoding. I think it's a major priority that AMA recieves the greatest attention. File based workflow is the future and FCP is ahead of Avid at this.
    * Pentium D 950 3,4 Ghz - 3GB DDRII RAM - Geforce 7800 GTX 256 * Intel Core 2 Quadcore 2,5 GHz (Q9300 6mb Cache) - 4GB RAM - Geforce 8800GTX 512mb... [view my complete system specs]
    * Intel Core 2 Quadcore 2,5 GHz (Q9300 6mb Cache) - 4GB RAM - Geforce 8800GTX 512mb - Laptop
    * Avid Media Composer  3.5.4
  • Wed, Sep 9 2009 9:59 PM In reply to
    • Glans
    • Sweden
    • Posts 192
    • Points 2,735
    Anybody has any news or knows anything? Ama seems like something no one talks about?
  • Sun, Nov 1 2009 3:54 PM In reply to
    • Codec Moment
    • Joined on Mon, May 21 2007
    • Philadelphia
    • Posts 314
    • Points 3,985
    AMA is a little scary because it's new and less stable. It's still pretty neat and overal has worked better than I expected.
    I don't see it as being too much of a stretch to work with r3d files using AMA. My understanding is that the wavelet codec makes it relatively quick and easy to pull lower resolutions out of the 4K file in real time. It could adaptively drop the debayer quality to the project format (half for 1080, quarter for SD, eighth for SD yellow) and then pad the video when added to a sequence. Yes it would be a little messy and hard on the computer, and no you couldn't ever work in the right frame size, but it would be a great option to have. This would be particularly welcome as a competitor to the FCP workflow using log and transfer to make QT references.
    Mac OSX 10.5.6 Avid Media Composer v4.0 soft Macbook Pro 2.5GHz Intel Core 2 Duo 2 GB 667 MHz DDR2 SDRAM Galaxy Metal Gear Box with 2 WD Caviar... [view my complete system specs]
    I trust orange juice more than I trust most people.
  • Sun, Nov 1 2009 5:15 PM In reply to
    Glans:
    Huh? Really? I hear and read about people using it al the time. Used it myself only once, and it just worked as advertised, instantly.
