Latest post Fri, Oct 8 2010 1:59 AM by Bernhard. 10 replies.
Page 1 of 1 (11 items)
  • Thu, Jul 23 2009 11:56 AM
    • slugman
    • Joined on Wed, Dec 17 2008
    • Posts 41
    • Points 590
    Import Error
    Media Composer 3.5 now support the of .m2t files.  I am now trying to import a collection of 720p30  .m2t files from a JVC GY-HD100.  This normally works perfectly when I import .m2t files created from a Canon XHA1 at 1080 60i.
    However with the 720p footage I start the import and it seem to work fine saying
    "Fast Importing MPEG file:__"
    Then a minute or two in an error message pops up...
    MPEGAudioImportReader::~MPEGAudioImportReader() CONSISTANCY CHECK FAILURE !?! : [0]
    Any ideas on how to solve this? Please help!
    Here is what the Console read...
    Exception caught in APlayer::Play - Exception: MPEGImportParserFifo::ReqGivePtr - Not enough space in Temp Buffer
    Exception caught in APlayer::Play - Exception Exception: CORE_UNABLE_TO_DO, className:AudioFileWriter, methodName:FlushRemainingSamples, preventedAction:Flush remaining samples - Timeout in seconds:, unableValue:1 raised Quiescing in the exception handlerException:
    @ Thu Jul 23 03:35:12 2009
    * MPEGAudioImportReader::~MPEGAudioImportReader()
       CONSISTENCY CHECK FAILURE !?! : [0]
    AudioPunchInWindow:
        Had to dump the user's previous Input Chl to Track mappings
        due to differences in configuration.
    @ Thu Jul 23 03:52:28 2009
  • Thu, Jul 23 2009 12:47 PM In reply to
    Re: Import Error
    I have found that m2t files exported from MC can be imported by fast import fine.
    Also captures from HDV Split can be imported by fast imported.
    Not other m2t files though.
    I am waiting the day that MC would be able to import ALL mpeg files.
    Desktop PC
    3 Heads Digital Films
  • Thu, Jul 23 2009 10:51 PM In reply to
    • slugman
    • Posts 41
    • Points 590
    Re: Import Error
    Actually I forgot to mention, they were captured using HDVsplit. Sorry.
  • Fri, Aug 7 2009 12:35 AM In reply to
    • slugman
    • Posts 41
    • Points 590
    Re: Import Error
    Ok, I figured it out myself.  I'm posting this for anyone else that comes accross the same problems.
    I ran my .m2t files through this MPEG2Repair program (freeware). It did a wonderfull job repairing and logging errors.  For some, this may be all you need to do.
    http://www.videohelp.com/tools/MPEG2Repair
    However, when I tried to import the fixed .m2t files i recieved the ever vague "Track -1 Not Found" error.  Which I guess it basically means its corrupt(for Avid).
    So I ran the "fixed .m2t files through Canopus Procoder(Not "free") , with a target set as the same as the original file, so it basically recreates it.  (on a side note, Procoder is the best encoding software I've ever used)
    http://desktop.grassvalley.com/products/ProCoderSW/index.php
    (When you click "Add Target" Select SYSTEM then HDV TARGET. Then under the Target Parameters select your appropiate HDV Mode{720 or 1080} and Format{frame rate}. Adjust where it get sent to under "Path")
    This is all a pain the ass, but HDV is a pain in the ass.
    However, these processes move pretty fast and it works.  And its MUCH faster and a higher success rate than MPEG Streamclip.
    Good luck to anyone who tries this!
  • Fri, Aug 7 2009 7:57 PM In reply to
    Re: Import Error
    slugman:
    LOL, true. Thanks for posting the fix.
    :: Work - Symphony Nitris DX 3.5.1, HP xw8600 :: Home - Intel 3.0Ghz Quad CPU 8GB G.Skill DDR3 7-7-7 1600 Ram Asus P5E3 Pro NVidia Quadro FX... [view my complete system specs]
    "Don't go by my script, they're always wrong." - producer to me while editing
  • Sat, Aug 8 2009 11:29 AM In reply to
    Re: Import Error
    Why you didn't capture within MC? Sometimes it has some problems but it can work after 2-3 attempts.
    I can't see how HDV is a problem. I work on that very much.
    AVCHD is a problem.
    Desktop PC
  • Fri, Dec 4 2009 4:35 PM In reply to
    • pt3
    • Joined on Thu, Jun 1 2006
    • Posts 11
    • Points 115
    Re: Import Error
    Thanks, this helped me A LOT!!! I can't tell you how much I HATE HDV and MPEG in general.  I use P2 now and LOVE it, there's none of this craziness!
    Cheers
    Dell T7400 dual 3Ghz Xeon w/ 12 GB Ram nVidia Quadro 570FX 2 x 2TB Striped Raid eSata HDD's 1 x 4TB G-Raid HDD Mojo (Old School SD) MC 4.0.5 + Adobe... [view my complete system specs]
  • Thu, Mar 4 2010 7:46 PM In reply to
    • Alcy
    • Joined on Tue, Mar 10 2009
    • Posts 1,002
    • Points 12,975
    Re: Import Error
    Is HDV and MPEG that you hate or a program that can't handle HDV and MPEG that you hate? I hate gasoline because it's too expensive or, do I hate the vehicle because it's a gas guzzler?
    Avid MC 8.1
    Windows 8.1
    HP Z800
    Dual Intel Xeon E5530 2.4GHz
    24GB RAM
    SAS 320GB @ 15K RPM OS Hard Drive
    1TB HD and 1.5TB HD Internal
    Nvidia Quadro FX 3800
  • Fri, Mar 5 2010 5:18 AM In reply to
    • slugman
    • Posts 41
    • Points 590
    Re: Import Error
    Good point, but I certainly don't hate Avid.
  • Mon, Apr 5 2010 8:33 PM In reply to
    Re: Import Error
    Hai friend, I met the same problem. I could not get MTS files in to avid. I red your answer and tried a lot but i couldn't. finally I use tmpeg enc express 4.0 to convert my MTS files in to M2t files. Now it is working with no problems.
  • Fri, Oct 8 2010 1:59 AM In reply to
    • Bernhard
    • Joined on Fri, Sep 17 2010
    • Austria
    • Posts 70
    • Points 810
    Re: Import Error
    If you have m2t files causing errors while fast importing into MC, you could try to do an automatic scene detection with HDVSplit. I had a similar problem described in this thread.
    iMac 27", 2.93 GHz i7, 8GB RAM, Mac OS X 10.6.5, Avid MC 5.0.3.5 [view my complete system specs]
