Latest post Thu, Aug 13 2009 6:41 PM by Optimusheim. 17 replies.
  • Tue, Jul 21 2009 4:52 PM
    • Mr. Mark
    • Joined on Wed, Mar 5 2008
    • Posts 11
    • Points 125
    Audio playback pops and clicks
    I did a search for this and didn't come up with anything helpful.
    We are working on upgrading our old HP workstation to new quad core systems. MC 3.5 with Mojo worked perfectly on the old systems.
    On the new system, when I play a timeline, the audio will pop and click. If the audio waveform is showing it's pretty much impossible to work, without it, the pops and clicks are less, but it's its still quite annoying. There are pops and clicks when using media from the Unity and on a local drive. When not playing through the Mojo, everything works as it is supposed to.
    There is no Firewire on the motherboard, and the system has a PCI FireWire card. I tried moving the FireWire to the other PCI slot, and I tried with an additional 3 FireWire cards, which only made it much worse. Removing the Fiber card does not help.
    We ordered 2 of these new workstations, and they both have this problem. Is this system simply not able to play nicely with the Mojo, or is there something I'm missing?
    Thanks in advance!
    Dell Precision T3500, Xeon W3520 2.66Ghz, 4GB RAM, 80GB WD Velociraptor, QuadroFX 1500, onboard audio, Firewire in PCI slot, Windows XP SP2, Media Composer... [view my complete system specs]
  • Tue, Jul 21 2009 6:49 PM In reply to
    • editz
    • Eugene, Oregon
    • Posts 127
    • Points 1,620
    Re: Audio playback pops and clicks
    Audio project settings?  Maybe sample rate set to something other than 48kHz?
    MCA 2.2.10 XW8000 dual 3.0GHz, 2GB RAM, NVIDIA 980 [view my complete system specs]
  • Tue, Jul 21 2009 9:35 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 1,400
    • Points 16,025
    I have had a similiar problem when playing timelines with mixed sample rates clips. hth
    MC 3.5/Mojo, Vista 64 biz, Gigabyte GA-EP45T-EXTREME, Intel Q9450, 8 GB ram, Pyro 64, Quadro FX 1700, 2 x 1TB drives (raid 0) for mediafiles + G4 MacBook... [view my complete system specs]
    peace luca
  • Tue, Jul 21 2009 10:48 PM In reply to
    • Mr. Mark
    • Posts 11
    • Points 125
    Thanks for the replies
    Audio project is 48Khz and all media is 48khz
  • Fri, Jul 24 2009 7:18 PM In reply to
    • Mr. Mark
    • Posts 11
    • Points 125
    bump
  • Fri, Jul 24 2009 7:42 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 3,108
    • Points 35,510
    Mr. Mark:
    bump
    You don´t have any description of what audio card you are using ( propably onboard as you have probs ) in your profile, tell a little more about your system in your profile and you might get more answers
    MC 4,03 ( Liquid 7,2 ) V 64 Ultimate Mbo gigabyte 965-DQ6,cpu quad core QX 6700, mem Corsair Dominator 8500 8 GB, PNY Quadro 1800, Soundblaster X-Fi... [view my complete system specs]
    Tomas
  • Fri, Jul 24 2009 8:01 PM In reply to
    • Mr. Mark
    • Posts 11
    • Points 125
    mjolnarn:
    Audio card is onboard. The problems I am having with audio are when I am using the Mojo. Playing back through the onboard audio works fine.
  • Fri, Jul 24 2009 9:37 PM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 1,612
    • Points 20,140
    Sometimes these problems are due to the USB controller chip. Check to see if the USB port is one controlled by the South bridge Intel chip or a secondary chip on the MoBo. Also anything else that is using the USB controller could be taxing the bandwidth.
    Sometimes onboard sound is ok, but many are using an audio card to ease the load on the CPU. Audio cards enabled for ASIO2 work best.
    PhenomII 940, AMD770 mobo, 4gigXMS DDR, ATIx4850, Audigy2zs, 500g SATA system drive, SATA 750g render, 640g SATA media storage, LG GGW-20HL BD/DVD XH... [view my complete system specs]
    Trial MC3.5, Using AL7.2 pro, Boris FX, DVDit6proHD, CCE Basic, TmpGe Express4, TmpGe Authoring Works 4, DVDLab-Studio. Canon XH-A1, GL2, GL1
  • Fri, Jul 24 2009 9:49 PM In reply to
    • Mr. Mark
    • Posts 11
    • Points 125
    TVJohn:
    All USB controllers are Intel ICH10.
    Again, onboard audio has no problems, only playback through the MOJO is problematic.
  • Fri, Jul 24 2009 9:55 PM In reply to
    • Mr. Mark
    • Posts 11
    • Points 125
    When I playback through the Mojo, I get stacks of error messages like this in the console -
    Error/Status Reporting: Your hardware has detected a serious error.
    Please quit the application and power cycle the hardware.
    [Error: DMPort Error]
    Error/Status [0x80001013]Error/Status Reporting: Hardware detected a host vsync error
    Error/Status [0x80001013]MSMRescan() took:     0.203000s
  • Fri, Jul 24 2009 10:04 PM In reply to
    • editz
    • Eugene, Oregon
    • Posts 127
    • Points 1,620
    It might be a bad Mojo itself.  There are defective ones out there.
  • Fri, Jul 24 2009 10:12 PM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 1,612
    • Points 20,140
    Your MoJo is Firewire? Is the firewire card sharing resources with something else?
  • Fri, Jul 24 2009 10:45 PM In reply to
    • Mr. Mark
    • Posts 11
    • Points 125
    editz:
    Tried another Mojo, same thing
  • Fri, Jul 24 2009 10:53 PM In reply to
    • Mr. Mark
    • Posts 11
    • Points 125
    TVJohn:
    Firewire is sharing IRQ 17 with ethernet and and USB controller. Disabling everything else on the IRQ doesn't help.
  • Fri, Jul 24 2009 11:00 PM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 1,612
    • Points 20,140
    No firewall or anti virus running/
