Latest post Sat, Aug 8 2009 7:42 AM by hensil. 9 replies.
Page 1 of 1 (10 items)
  • Mon, Jul 20 2009 11:14 AM
    • hensil
    • United Arab Emirates
    • Posts 20
    • Points 260
    Wacom Tablet & DS 8.4
    The tablet was working fine so far until the CPU was shifted to the machine room which is approximately 10 mts away. Although the tablet is powered on I cannot configure it to the whole screen that consists of dual HP LP2465 monitors. After doing search I came across this old 2005 thread that points to the distance between the CPU and tablet.
    http://community.avid.com/forums/p/2830/14550.aspx#14550
    Is this a DS issue? because we also have Smoke and Flame that has no issue like this.
    We have 2 DS ver. 8.4 and the problem is on both the machines. Is there a quick solution?
    The tablet is Wacom Intus 3, 12*9 and the driver is updated.
    DS 10.1.2/Symphony Nitris, HP8400, Dual Link, 8MB RAM [view my complete system specs]
  • Mon, Jul 20 2009 12:26 PM In reply to
    • slicker
    • Bucharest, RO
    • Posts 85
    • Points 1,195
    Re: Wacom Tablet & DS 8.4
    I think You should check how many USB ports are you using on that computer. I had that problem and removing some of them  solved it.  Its a MB not a DS thing.  Try to use the tablet with other software (like Photoshop...)
    Avid DS v10_2_1 HP xw8600 Dual quad-core Intel® Xeon® 3.0GHz, FX 3700, AJA 2Ke Dual link I/O card Avid VideoRaid SR storage 16TB [view my complete system specs]
    Laurentiu Rusescu.Bucuresti.RO
  • Mon, Jul 20 2009 1:10 PM In reply to
    • hensil
    • Posts 20
    • Points 260
    Just 2 USB ports are in use. One for the dongle and the other for the extender. The problem persists in Photoshop.
  • Mon, Jul 20 2009 11:55 PM In reply to
    • M-Edit
    • Joined on Thu, Jan 29 2009
    • Posts 60
    • Points 730
    Going past 5 meters with a USB-cable you will probably need an
    active USB-extender like these (well, just some examples
    and a USB 2.0 compatible extender is the way to go):
    http://www.vpi.us/usb-extender.html
    Some more reading on the USB "length-subject":
    http://en.wikipedia.org/wiki/Usb#Maximum_useful_distance
    So with that in mind, ie. the 5 meter limit, when the USB-distance
    is reaching 10 meters you might need TWO of these ACTIVE
    extenders cascaded.
    But that's only ONE part of the problem, dealing with the USB2
    specifications length limitations, and this will work for USB-devices
    that doesn't draw much current or has it's own powersupply,
    ie. "self-powered" USB-devices.
    The old serial-port connected Wacom's used to be self-powered
    9-pin serial devices, so extending the serial cable often didn't
    impose any problems "powerwise", but not so the USB Wacom's
    delivered with for example a brand new DS10.
    They work prefectly fine when you connect the Wacom "directly"
    to the xw8600, but if you shove in a 5 meter non-active USB-cable
    extender you will probably experience problems.
    In my case, "DS10 and the Wacom that comes with it", having to
    extend the cable route about 5 meters, but realizing the problematics
    ahead, I put one of those ACTIVE extenders in, and it worked for
    about half a day.
    So what happened? Well, it seems that the "ACTIVE USB extender"
    gave in, due to the Wacom tablets power hunger. The "electronic
    "lump"-part of the cable was very hot when I checked and I never
    got it to work with even low-power surge USB devices after that.
    So I got a new active USB (5 meter) extender cable BUT also a
    self-powered USB hub. And everything seems to have been
    rocking ever since
    //mike
  • Tue, Jul 21 2009 6:58 AM In reply to
    • hensil
    • Posts 20
    • Points 260
    Thanks Mike and Slicker,
    We have ViewLink CATx  powered USB extender manufactured by Rose Electronics, Texas. And I guess this is not a proper extender.
  • Tue, Jul 21 2009 1:05 PM In reply to
    • M-Edit
    • Posts 60
    • Points 730
    Hmmm, I wouldn't think that the Viewlink would be a problem
    communication-wize, but it might be that it can't output enough
    power for the Wacom board.
    You could try to connect a USB-hub with external powersupply
    inbetween the Viewlink and the Wacom and see if that makes
    any difference.
    //mike
  • Wed, Jul 22 2009 8:50 AM In reply to
    • M-Edit
    • Posts 60
    • Points 730
    For these products
    http://www.bellequip.at/viewlink-catx-rose-electronics-mini-kvm-extender.htm
    they don't mention the max. power that can de output from the USB-socket.
    while for this
    http://www.bellequip.at/rose_electronics/usb_kvm_extender/crystalview_usb2.htm
    the specs says:
    "Up to 500 mA of power is available at each USB port for powering high-power USB devices"
    and 500mAmps is the standardized max. current output from a single USB-port.
    That's why devices needing more than 500mAmps, for example larger USB-harddrivs,
    are delivered with a "split-cable" (well, it's actually the opposite) where the main
    connector is used for communication and power, while the second is used only
    for getting more power from a second USB-port.
    Hmmm, found this:
    GENERAL SPECIFICATIONS FOR ALL INTOUS4 TABLETS
    Power requirements:
    DC 5V, less than 300mA, from primary USB port or powered USB hub.
    So it would be interesting to know what the Viewlink can deliver
    when it comes to milliAmps...
    //mike
    P.S.
    Just wondering about the Smoke and Flame. Are their computers
    located as far from Wacom as the DS, i.e cable-wize? And do they
    use an equal or simliar CATx/USB-extender?
    D.S.
  • Thu, Jul 23 2009 7:25 AM In reply to
    • hensil
    • Posts 20
    • Points 260
    Thank you very much for your response. I have asked our engineer to add a power USB hub between the extender and the tablet. He may do it today.
    The Flame and Smoke are furthur away from their CPU, they use different extender. I have aslo asked the engineer to use the Smoke extender with DS to check.
  • Thu, Aug 6 2009 7:04 AM In reply to
    • M-Edit
    • Posts 60
    • Points 730
    Just curious, but did you have any luck with this?
    //mike
  • Sat, Aug 8 2009 7:42 AM In reply to
    • hensil
    • Posts 20
    • Points 260
    Hi Mike,
    A direct cable from the CPU to the tablet worked but there were many problems with DS 10.1.2. One of them was, we could not get the Quicktime working for some days even after trying various things. Finally all the problems were solved after reinstalling Winodws XP, in fact we did a repair. Thanks Mike for your help.
