Latest post Tue, Jul 21 2009 10:39 AM by luca.mg. 5 replies.
Page 1 of 1 (6 items)
  • Mon, Jul 20 2009 9:22 AM
    • Le Maitre
    • Joined on Sat, Apr 11 2009
    • England
    • Posts 28
    • Points 370
    Mojo HD down-conversion quality
    I recently bought a Mojo SDI and have been trying it out with XDCAM EX HQ 1080/50i footage in a PAL 25i project. I wanted to see what the real-time HD down-conversion was like using MC3.5.4. I connected the Mojo-SDI to a Sony BVM grade-1 monitor through component.
    I noticed that if I set the Video Playback Quality to "Full Quality 10-bit" the output was brilliant! It looked like perfect SD footage. However if I set the Video Playback Quality to "Full Quality" the output looked like it was single-field (hard to tell exactly). Bearing in mind that XDCAM is only 8-bit and the only difference between the two settings I used is the bit depth, why would this be? Is this normal? Has it always been like this?
    Also I am thinking of recommending a secondhand Mojo Analogue to a colleague who is on a budget. He specifically wants to use the real-time HD down-conversion. As I don't know if Mojo Analogue can be set to "Full Quality 10-bit" (according to the Avid Basic manual p.250 neither Mojo or Mojo-SDI can be set to 10-bit), I don't know what the output is likely to be. Can anyone tell me what the Mojo Analogue HD down-conversion is like on interlaced material when viewed on a CRT monitor?
    Thanks.
    Supermicro PDSGE motherboard, Intel Pentium-D 3GHz CPU, 2GB RAM, Quadro FX3700 512MB, Sound Blaster X-Fi XtremeMusic, Mojo SDI, DIGI002, Adaptec 39160... [view my complete system specs]
  • Mon, Jul 20 2009 10:03 AM In reply to
    • nicov
    • Joined on Wed, Jun 7 2006
    • Posts 135
    • Points 1,610
    Re: Mojo HD down-conversion quality
    Hi, it will be same I think, I had a mojo DNA, in fact it's not the mojo doing the downconvert but the soft when project is turned to 25i. You don't even need a mojo, this work the same with a dv deck (just not in sync with the composer monitor). Now i've never connected a mojo dna or sdi since 3.0 and I think this 10bit playback quality wasn't available before, the downconvert quality I had was always a single field preview, no matter if a deck or a mojo was use for monitoring. Maybe sofware downconversion has been improve with MC 3 but I don't see why 10bit playback quality has to be turned on to achieve it (this also means less real time).
    OSX 10.5.5 / MC 3.1.3 / Mojo DX / octo 2.8 Macpro / 6g ram / Ati 2600 + Ati 3870 / 2x Nec 19' + JVC DTV24 / Sony HVR M15 / 2To sata raid0 / [view my complete system specs]
  • Mon, Jul 20 2009 11:06 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 1,388
    • Points 15,885
    FWIW: I have an analog Mojo that use for HD monitoring switching to 25i, it does not go up to full res 10 bit, only green mode, but it looks OK on a Sony broadcast monitor.
    MC 3.5/Mojo, Vista 64 biz, Gigabyte GA-EP45T-EXTREME, Intel Q9450, 8 GB ram, Pyro 64, Quadro FX 1700, 2 x 1TB drives (raid 0) for mediafiles + G4 MacBook... [view my complete system specs]
    peace luca
  • Mon, Jul 20 2009 11:18 PM In reply to
    • bee gee
    • UK
    • Posts 523
    • Points 6,215
    Both mojo and mojo sdi show single field only on downconvert. It's ok for grading on a crt. I'm still on 3.0.5, but if the 'full quality 10-bit' setting in 3.5.4 is both fields, then that's a good reason to upgrade. Can any moderators chime in with an official word?
    xw8600 dual quad 3ghz, MCv3.0.5, 4gb ram, xp pro, fx3700, Adrenaline DNA, Seagate 2TB internal raid'0', WD 250gb boot, Blu-ray writer [view my complete system specs]
  • Tue, Jul 21 2009 8:39 AM In reply to
    • bee gee
    • UK
    • Posts 523
    • Points 6,215
    bump
  • Tue, Jul 21 2009 10:39 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 1,388
    • Points 15,885
    My Mojo MC doesn't allow 10-bit display as in Nitris DX, I've no experience with both Mpjo SDI and Mojo DX.
    peace luca
