Latest post Sat, Jul 18 2009 12:59 PM by malefunktion. 1 replies.
Page 1 of 1 (2 items)
  • Sat, Jul 18 2009 7:43 AM
    • spacevybe
    • Joined on Tue, May 20 2008
    • Los Angeles, CA
    • Posts 4
    • Points 50
    proper audio levels for web delivery
    I'm currently cutting a short video for the web - probably to be posted on Vimeo.  Anyone know the best way to mix audio for the web within Avid, with regard to levels?  I figure I'll aim for as hot as possible without peaking, but is there a better way to limit the dynamic range with a mixdown and some AudioSuite plugins?  I also have Sorenson Squeeze 5 if that's useful for this at all...
    HP xw8600 (4GB RAM), MC 3.5, Mojo SDI, Sony DSR-11 [view my complete system specs]
  • Sat, Jul 18 2009 12:59 PM In reply to
    Re: proper audio levels for web delivery
    Hi.
    When I ready videos for my YouTube channel I export my final mixed-down cut (Separate Audio and Video files) and then feed the audio into Audacity (Free Audio Editor).
    I then tend to "Normalise" the audio to around -0.3dB. The reason I don't normalise to 0dB or 100% is that some re-encoding takes place on Vimeo/YouTube and sometimes that process can elevate the audio ever so slightly. Using 0dB would then result in clipping if that happened, so I keep it safe by using -0.3dB.
    If the dynamic range is too much, ie... quite-to-loud transitions are extreme, I use Audacity and its "Leveller" filter which reduces the dynamic range and thus brings the overall perceived loudness back into line. (Sometimes I need to re-normalise the audio back to -0.3dB as a result of the "levelling" process).
    Once I'm happy with my audio, I MUX it together with my Video file and then compress appropriately for whatever website format. I almost always go with H264 video compression and AAC audio.
    Bare in mind this is just my workflow, and a workflow I only use for Vimeo/YouTube. Obviously audio requirements may vary for different output destinations (broadcast/DVD etc...)
    MSI Neo-2 Platinum Nforce3 Ultra (Bios Rev 1.0D) Athlon64 X2 4200+ (Overclocked to 2 x 2.4GHz) AMD Cool'N'Quiet CPU Throttling 2GB Corsair PC3200... [view my complete system specs]
