Latest post Sat, Jul 18 2009 11:01 PM by jwrl. 6 replies.
Page 1 of 1 (7 items)
  • Fri, Jul 17 2009 5:37 PM
    • GabeTe
    • Joined on Wed, Apr 9 2008
    • Toronto
    • Posts 46
    • Points 535
    No recompress while import.
    Hi guys,
               I'm using 1920x1080 dnxhd 115 footage and I want to avoid recompressing while import it in the project.
    I'm importting the footage as DNxHD 115 MXF. Is it recompressing the footage while importing it as 115 DNx or should I importing it as 1:1 mxf????
    AMC 3.1.3
    G
    Dell Precision M6300 with two Intel Core 2 Extreme CPU X9000 @ 2.80GHz. 4 gigs of ram and NVIDIA Quadro FX 1600M graphics card 512MB. 17' screen 1920... [view my complete system specs]
  • Sat, Jul 18 2009 10:19 AM In reply to
    • fiendish
    • Posts 343
    • Points 4,155
    Re: No recompress while import.
    What did you render the footage with? You need to make sure you set colour levels and field order correctly in the Avid import options, relative to how the DNxHD was rendered, otherwise MC will recompress. Its also a good idea to set the OMF option under the second tab to 'use source file's resolution'.
    xw8600 Dual Quad 3ghz - MC 3.5.4 / QT 7.6 / Win XP / Vista 64 bit with Mojo SDI - 12gb RAM / Quadro 3500 / 3700 and 3ware 9650SE Raid 5 [view my complete system specs]
  • Sat, Jul 18 2009 10:34 AM In reply to
    • Sycophant
    • Auckland, New Zealand
    • Posts 1,143
    • Points 13,860
    • Moderator: MCA Mac
    The main thing that stops the 'Fast Import' from working, in my experience, is that the colour levels in the import dialogue are set to 'RGB' instead of '601/709'
    Essentially to fast import the following things have to be true:
    1. Codec natively supported by Avid.
    2. Correct Raster size.
    3. Correct Colour space.
    4. Correct Field order
    You need to tell Avid that you have all those things in the file you're importing. So...
    Image Size Adjustment: Image sized for current format
    File Pixel to Video Mapping: 601 SD or 709 HD (16-235)
    Field Ordering in File: Ordered for current format
    Assuming the file is all correct then you should get a fast import.
    HP XW8600s - Media Composer 3.5.4 - HP XW8400s - DS Nitris 10.1 [view my complete system specs]
    Dylan Reeve - Editor and Stuff
    My opinions are my own.
    Dylan's Templater - Basic Avid project templating tool.
    BatchFuze - MetaFuze batch transcoding tools.
  • Sat, Jul 18 2009 1:08 PM In reply to
    • redreini
    • Joined on Thu, Jul 16 2009
    • Germany
    • Posts 16
    • Points 200
    Hi guys ,
    how can you tell that it is a fast import? Is there any hint in MC while importing. Takes way too long for me.
    Importing media encoded with Sorenson DNxHD120 from an avchd-file and I don´t want MC to reencode the file. Can´t tell whether it´s doing or not?
    Thanks for help.
    Avid Media Composer 3.5.4, Dell Precision Workstation T5500, Win XP Pro SP3, Intel Xeon E5530 @ 2,40 GHz, 4GB RAM,NVidia Quadro FX 1800 Graphics card,Onboard... [view my complete system specs]
    Don´t buy DELL , Nobody can help you, they ignore your problems! Angry
    They are sellers , no support. No
    Build your own systems, then you know what is in there Geeked
  • Sat, Jul 18 2009 1:14 PM In reply to
    redreini:
    XPP and MC will specifically use the words "FAST IMPORT" on the import progress bar. Wink
    MSI Neo-2 Platinum Nforce3 Ultra (Bios Rev 1.0D) Athlon64 X2 4200+ (Overclocked to 2 x 2.4GHz) AMD Cool'N'Quiet CPU Throttling 2GB Corsair PC3200... [view my complete system specs]
  • Sat, Jul 18 2009 5:54 PM In reply to
    • redreini
    • Germany
    • Posts 16
    • Points 200
    Thanks for answering, malefunktion!
    Thanks Sycophant for the import-settings in MC!
    Did anyone try to encode some footage in Sorenson to DNxHD120 and then did a fast import in MC?
    What settings you use for this in Sorenson?
    If I do this I get a .mov-file and then import in MC! But MC tells me something about "Fill video" and not "fast import"!?
    Any ideas?
  • Sat, Jul 18 2009 11:01 PM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 4,239
    • Points 48,700
    redreini:
    Change your Avid import settings to "Ignore Alpha channel".  It's attempting to import your file as a matte.
    MC 4.0.3 - Asus P6T Deluxe V2 mobo - Intel i7 920 2.66GHz - nVidia Quadro 1700 - 12 Gbyte mem - Internal 4 Tb SATA II 4-way RAID 5 array - Pyro firewire... [view my complete system specs]
