Latest post Tue, Jul 14 2009 6:50 PM by BLKDOG. 14 replies.
Page 1 of 1 (15 items)
  • Tue, Jul 14 2009 3:37 AM
    • jfilm
    • Joined on Tue, Jul 14 2009
    • Posts 2
    • Points 45
    Making a DVD from a Quicktime
    Hi, I am trying to make a normal DVD that will play on a regular DVD player from
    a quicktime made from a sequence in Avid Media Composer, 3.0.  I've tried several
    different settings, and they all produce DVDs that work on my laptop and computer,
    but they will not play smoothly on my TV.  There are stops and starts, picture break-up,
    etc.  Does anyone have some tips on what settings to use to make a normal DVD?  I'm
    using Toast 8.  Thanks.
  • Tue, Jul 14 2009 4:00 AM In reply to
    Re: Making a DVD from a Quicktime
    DVD's are just MPEG-2 files.  Encode your QT movie to MPEG-2 using an Encoder app and then author that file using a DVD authoring app.  It sounds like you're just creating a QT and going straight to Toast, which will likely do it's best to create the DVD compliant MPEG-2 file, but Toast is not an Encoder app.
  • Tue, Jul 14 2009 2:22 PM In reply to
    • jfilm
    • Posts 2
    • Points 45
    Thanks- so the Avid doesn't do any compression, or is it just unreliable?  I was using the MPEG-4 setting at one point and thought it would work.  Can you suggest any encoder applications and authoring apps (for Mac) for someone on a budget?  Thanks again.
  • Tue, Jul 14 2009 2:31 PM In reply to
    • St.John
    • UK
    • Posts 159
    • Points 1,920
    I know Kenton said that Toast doesnt work with qt reference, but I use it often, especially when I have a mixture of HD and SD material in a timeline
    St.John
    Mac pro 2.66 GHz 2gb ram OSX 10.4.11 qt 7.4.5, MC 3.05,mojo gtech drives firewire 800 connection Mac pro 2.8 6gb ram, OSx 10.5.5 QT 7.5.5, MC 3.05 Nitris... [view my complete system specs]
  • Tue, Jul 14 2009 2:55 PM In reply to
    St.John:
    ?Huh?
    I never said that.  I said that Toast is probably not the best Encoder.
  • Tue, Jul 14 2009 2:56 PM In reply to
    jfilm:
    Who's not on a budget?
    Sorenson Squeeze comes with MC and works on Mac.  For DVD authoring, I use DVDSP (part of the FCP suite)
  • Tue, Jul 14 2009 2:59 PM In reply to
    jfilm:
    What are you guy's mis-reading about my post?
    1. Export as a QTref from Avid
    2. Encode QTref to MPEG-2 using Encoder
    3. Author MPEG-2 file to DVD using Authoring app.
  • Tue, Jul 14 2009 3:17 PM In reply to
    Simplified breakdown of my workflow:
    1-export QT or QT Ref from Avid
    2-encode the video to m2v (I use Bitvice)
    3-encode the audio to ac3 (I use Compressor for this)
    4-drop the m2v and ac3 files into a DVD authoring program (I use DVDSP)
    5-once done authoring, make a VIDEO_TS folder
    6-drop the VIDEO_TS folder into a disc burning app (I use Toast)
    MC 4.0.2, Nitris DX, 8-Core/2.8ghz Harpertown MacPro, 8 GB RAM, Avid VideoRAID 2.5 TB, 1.5 TB internal SATA Raid [view my complete system specs]
    Conformity is the jailer of freedom and the enemy of growth. Motion Inc FCP2Avid
  • Tue, Jul 14 2009 4:55 PM In reply to
    Todd Sanderson:
    My process is nearly identical except I use Episode for the m2v and ac3 creation.
  • Tue, Jul 14 2009 5:56 PM In reply to
    • MiamiSteve
    • Joined on Thu, May 24 2007
    • Miami, FL
    • Posts 128
    • Points 1,560
    Kenton.VanNatten:
    Todd Sanderson:
    Maybe I am missing something but why not do:
    1-export QT or QT ref from Avid
    2-drop QT file in to a DVD authoring program ( I use DVDSP also)
    3-build and burn from DVDSP
    Please enlighten me as to why I would want to encode the video and audio files separately, then drop them in to DVDSP and then burn using toast.  What are the advantages of doing it how you guys do it compared to my workflow?
    Steve
    Media Composer 3.1.3 Adrenaline. OS 10.4.11, 4 x 2.5 GHz PowerPC G5, 4 GB DDR2 SDRAM. 1-LaCie Bigggest S2S 2.5TB SATA Drive, 2-Maxtor 300 GB External... [view my complete system specs]
     Just give the people what they want!
  • Tue, Jul 14 2009 6:00 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,828
    • Points 201,105
    IF you have FCS on your system, that's the best way to go for me too. Compression is done with compressor (Which is a decent encoder, there are better but it does a nice job) and does everything in one step.
  • Tue, Jul 14 2009 6:14 PM In reply to
    In my opinion, Bitvice is a far better encoder than Compressor... thus I take that extra step.
    MiamiSteve:
    Control.
    When you bring a QT into DVDSP it's going to encode it to MPEG-2.  What level of control do you have over the encoded result?  Using a dedicated encoder app gives you that.  In other words, "Horses for Courses"
  • Tue, Jul 14 2009 6:46 PM In reply to
    • MiamiSteve
    • Miami, FL
    • Posts 128
    • Points 1,560
    I can see your point.  However I haven't had a problem with my workflow so I guess if it isn't broke don't fix it.
  • Tue, Jul 14 2009 6:50 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,828
    • Points 201,105
    I'm with you Steve, it's another thing that Apple does very well, make a nice DVD so that you don't have to think about encoding settings.
    Most of the time my DVDs are for approvals so tossing a QT ref into DVDSP and burn is all I have to do. Not a lot of control needed.
