Latest post Tue, Jul 14 2009 10:46 AM by grayboy. 1 replies.
Page 1 of 1 (2 items)
  • Mon, Jul 13 2009 2:11 PM
    • DKGen
    • Joined on Mon, Sep 10 2007
    • Posts 129
    • Points 1,415
    30 minute capture limit/cut off
    I am sure I never used to experience this problem.. the only thing I can maybe relate it to is that now I capture in 1080 50i format and maybe that makes a difference?  But basically whenever I capture footage it stops capturing at 30 mins.  So every tape has to be split into two halves, which makes capturing (and editing) a bit of a pain.
    Any idea how I can resolve this problem?  Nothing worse than leaving a tape to capture, coming back after an hour to find it's only caught 30mins.  It's not timecode breaks.. it's exactly the same... 30 min segments, no matter what tape.
    HP XW8400 Workstation Dual 2.66GHz Xeon 3.00 GB RAM Quadro FX 1500 256 MB Avid XPPro v5.7.2 After Effects CS3 3ds Max 9 XP SP2 [view my complete system specs]
    HP XW8400 Workstation Dual 2.66GHz Xeon 3.00 GB RAM Quadro FX 1500 256 MB Avid XPPro v5.7.2 Mojo SDi XP SP2 G-tech Raid 1 TB Max 9 AE CS3 HVR M15E HPLP2465 JVC TM-H1750C CRT Monitor Samsung 40" LCD
  • Tue, Jul 14 2009 10:46 AM In reply to
    • grayboy
    • Halifax, West Yorkshire
    • Posts 451
    • Points 5,840
    Re: 30 minute capture limit/cut off
    Got to your Settings, click on  Capture, then the - Omfi (or MXF) tab and you can see the maximum default capture time.
    MC ver3. HPxw8400 Intel R Xeon quad core 5150@2.66Ghz. 3Gb ram. Xp Pro 4.6 Service Pack 2Pentium 2.8 GHZ2GB Ram Matrox Millenium G550 dual display80GB... [view my complete system specs]
