Latest post Tue, Jul 21 2009 10:40 PM by EP@KMP. 5 replies.
Page 1 of 1 (6 items)
  • Sun, Jul 12 2009 9:40 PM
    • editdudes
    • Posts 37
    • Points 505
    Symphony internal effects, fractional interpolation?
    Does Avid Symphony internal effects render fractional interpolated values for example when keyframing small positioning changes?
    If not, how about Boris?
    DS 10.x • DS 4.0 • Symphony Nitris DX 3.x • MC Adrenaline DNxcel 3.x • HDCAM • DigiBeta • XDCAM • HDV • VirtualDub • Final Crap Pro • SAVE THE DONGLE!... [view my complete system specs]
    E D I T   D U D E S
    Independent Post Production Services
    Malmö - SWEDEN
    www.editdudes.com
  • Mon, Jul 20 2009 11:56 PM In reply to
    • EP@KMP
    • Posts 10
    • Points 140
    Re: Symphony internal effects, fractional interpolation?
    You can render effect at 16bit depth instead of 8bit. You can change resize filtering to Bi-Linear instead of closest. You could send it to DS and Render up to 32bit float and use Bi-Cubic filtering. Hope that answers your question.
  • Tue, Jul 21 2009 11:45 AM In reply to
    • editdudes
    • Posts 37
    • Points 505
    Unfortunately, no it doesn't.
    Slight movements should have sub-pixel interpolation rendering.
    Without it, movement is choppy i.e. position snaps to nearest pixel.
    E D I T   D U D E S
    Malmö - SWEDEN
    www.editdudes.com
  • Tue, Jul 21 2009 1:25 PM In reply to
    • riojapj
    • London, UK
    • Posts 114
    • Points 1,165
    editdudes:
    AFAIK, this is what the HQ button is for (hence, non-realtime). You can certainly see the difference with subtle, slow xy moves in effects like 3D Warp. Also, try the console: 'setresizetype 9' for polyphase filtering.
    Regards,
    MCA v3.0 & 2.6 w/ xw8200 (Avid cert) 2x XPRO STUDIO v5.2.1 w/ xw8200 (Avid cert) Digidesign Pro Tools HD1 v7.1 w/ xw8200 Avid Unity MediaNetwork v4 [view my complete system specs]
    Paul Johnson
    Creation Company
  • Tue, Jul 21 2009 8:54 PM In reply to
    • John Moore
    • Joined on Fri, Feb 3 2006
    • Burbank, CA
    • Posts 144
    • Points 1,615
    How do you change to Bi-Linear?  Is it a console command or is this invoked with the HQ button?
    Symphony Nitris 3.1.1 [view my complete system specs]
    John Moore Barking Trout Productions bigfish@pacbell.net
  • Tue, Jul 21 2009 10:40 PM In reply to
    • EP@KMP
    • Posts 10
    • Points 140
    It used to be a consle command only but since version 3.1.1 it is in the Standard setting under Render Settings image interpolation. HQ is used if effect is promoted to 3D and becomes a software based render, no hardware assisted render. Not every effect can use HQ render, which changes to the Polyphase interpolation, but a reposition effect should improve as well as using 16bit depth.
