Latest post Tue, Nov 3 2009 6:32 AM by slydvd. 12 replies.
Page 1 of 1 (13 items)
  • Fri, Jul 10 2009 8:39 PM
    Mojo DX + Blackmagic possible?
    Has anyone built a system with both a Mojo DX and a Decklink or AJA card? Of course it would be dual boot so everything on the software side would be separate.
    Thanx!
    Annaël
    Filed under: ,
  • Sun, Jul 12 2009 9:55 AM In reply to
    • slydvd
    • Austria
    • Posts 36
    • Points 530
    Re: Mojo DX + Blackmagic possible?
    Hi!
    Just Build a new Nehalem Dual 2,26 Quadcore with MojoDX, Decklink HD Extrem, Sata Higpoint Raidcontroller.
    Was Tricky - but it works
    Slot 1: Geforce GT120
    Slot 2: Blackmagic Decklink !!! This is important - must be in 16x
    Slot 3: Highpoint SATA Raidcontroller
    Slot 4: MojoDX Xpress Card
    OS X 10.5.6 and Avid 3.5.1
    The good thing is - I can use the Decklink for Preview in AfterEffects, and for FinalCut AND....
    I can use Decklink for Convert ther Mojo DX SDI output to Analog Signal like Composite,S-Video or Component
    So I get more outputs from my MojoDX !!!
    Regards
    Sly
    2xQC 2,26GHZ MACPro Nehalem ,12 GigRAM, NVidea 120GT,1TB System, 4TB SATA Raid ,2x24" FullHD DellScreens,MC3.5.1 ,FXFactory,FinalCutStudio,DecklinkHD... [view my complete system specs]
    SeeYaa Sly in MMIX ----------------------------------- HD is the only resolution in LIFE MC AdrenalineHD Editor
  • Mon, Jul 13 2009 5:42 PM In reply to
    I have done a machine with a Mojo DX, AJA Kona 3 and a fibre channel HBA. All works as advertised as long as you dual boot.
    Add a firewire pro tools interface for the trifecta! ;)
    Don't trust the internet...
  • Thu, Jul 16 2009 9:16 PM In reply to
    Thanx for the info, guys!
    Annaël
  • Mon, Oct 26 2009 4:16 PM In reply to
    Hey Cowboy,
    I have both Mojo DX and Kona 3 cards, currently in separate machines, and would like to consolidate into one 8-core MacPro.
    I'm a long-time Avid editor but my business is now heavily FCP.  Would like an easy way to switch back and forth.
    Dual boot seems like a hassle, but perhaps I'm not thinking it through. I haven't experimented yet, and would value your input on how best to proceed.
  • Mon, Oct 26 2009 4:29 PM In reply to
    • nicov
    • Joined on Wed, Jun 7 2006
    • Posts 135
    • Points 1,610
    slydvd:
    Does it work also for input, can you input an analog signal to the decklink so its converted to SDI and captured by the mojo DX ?
    Can you use the serial port of the decklink for deck control with MC ?
    If it works I will buy one.
    OSX 10.5.5 / MC 3.1.3 / Mojo DX / octo 2.8 Macpro / 6g ram / Ati 2600 + Ati 3870 / 2x Nec 19' + JVC DTV24 / Sony HVR M15 / 2To sata raid0 / [view my complete system specs]
  • Mon, Oct 26 2009 7:19 PM In reply to
    • slydvd
    • Austria
    • Posts 36
    • Points 530
    Will try the SDI Capture from analoge input via decklink in the next week
    RS422 Control over ther Decklink does NOT work at all !
    regards
    sly
  • Mon, Oct 26 2009 8:26 PM In reply to
    • Bill Nelson
    • West Coast
    • Posts 715
    • Points 8,145
    don't know from DX (running SDI Mojo) so I don't qualify for this thread, but I'm running a Kona 3/Mojo SDI all day long on the same partition.  I switch from Avid to Motion to AE to Photoshop, with the Kona 3 and Avid keeping track of themselves very nicely.  All I need now is a new 12-core MacBeast running all 64-bit apps and 36 gig of RAM slammed in there, and I'll be set!
    Next year.
    MC v3.5.4 thru SDI Mojo, OS 10.5.8, QT 7.6, on Quad-Core Intel Xeon 2.8 w/8 gig RAM, 2Tb internal RAID volume, 4TB CalDigit HDOne RAID, 30"Display... [view my complete system specs]
    "I scare nothing! Even you become napkins!"
    (english subtitles in Hong Kong kung-fu movie)
  • Tue, Oct 27 2009 6:24 PM In reply to
    • nicov
    • Posts 135
    • Points 1,610
    slydvd:
    regards
    sly
    Thanks for sharing info,  the SDI capture from analogue input is of course my main concern, if RS422 control has to be done with the keyspan, then so be it.
    What I'm actually trying to determine is do we buy the decklink card or the blackmagic broadcast converter. The decklink is cheaper and provides monitoring for AE and other softs as well while the converter just does the converting job. I'll wait until you try the capture, thanks again for helping.
    Regards,
    Nicolas
  • Mon, Nov 2 2009 11:21 PM In reply to
    • slydvd
    • Austria
    • Posts 36
    • Points 530
    Sorry for the delay - i have a big concert project - this is finished next week
    then i will try the decklink/mojo thing
    seeyaa
    sly
  • Tue, Nov 3 2009 1:44 AM In reply to
    • nicov
    • Posts 135
    • Points 1,610
    slydvd:
    seeyaa
    sly
    Ok thanx for your time and nice editing meanwhile.
    Could you tell me how did the output conversion worked, did you just route the SDI output of the DX thru the SDI input of the decklink and the signal came out live from the component outputs of the decklink without any further set up process. Or did you need to have some kind of software running (other than MC of course) to make it work ? In other words does the decklink need some utility software running to be active or just works in a sort of standalone mode?
  • Tue, Nov 3 2009 1:50 AM In reply to
    • Avid 99
    • Dallas, Texas
    • Posts 448
    • Points 5,750
    Sorry for derailing this, but I'm curious, Sly, how does your HPT HBA work in slot 3?
    I thought those needed to be in Slot 2 to get the proper bandwidth.  No?  Is it working OK?
    MBP 17" - 1x2 2.66 - 4G RAM - 10.5.8 - 7.6.2 - MC 3.1.3 <<<<<>>>>>> MP (1/08) - 2x4 3GHz - 32G RAM - 10.5.8 - 7.6... [view my complete system specs]
  • Tue, Nov 3 2009 6:32 AM In reply to
    • slydvd
    • Austria
    • Posts 36
    • Points 530
    You mean the Highpoint Raidcontroller - it IS working fast - about 328MB/s Read - and 226 MB/s Write
    Sly
