Latest post Mon, Jul 13 2009 9:49 PM by Kevin Klimek. 7 replies.
  • Thu, Jul 9 2009 8:31 AM
    Red question
    Is there any way of opening Red proxies in MC without having to import them first. I have been given 100 hours of footage and I don't have the time to convert it to Avid media.
    Cheers
    System 1: Dual quad core 3.2 Intel Xeon. 2gigs ram. OSX 10.5.4 MC 3.1.2 System 2: Dual 2.3 G5 Pci-e, 6.5 gigs ram, OSX 10.5.4, MC 3.1.1 2 x 250 gig... [view my complete system specs]
  • Thu, Jul 9 2009 10:10 AM In reply to
    • Bloersch
    • Joined on Sat, Dec 3 2005
    • Berlin, Germany
    • Posts 164
    • Points 1,975
    Re: Red question
    No.
    You can use Final Cut for that.
    You can convert the red files with redrushes, metafuze or several other apps, to edit with MC, but it will take some time...
    MC 3.1.3, OSX 10.5.5, MacBook Pro 17'', 2.33 GHZ Inter Core 2, Mojo SDI, e-Sata HDD [view my complete system specs]
  • Thu, Jul 9 2009 6:53 PM In reply to
    • BlueGirl Media
    • Joined on Tue, Apr 25 2006
    • Glasgow, Scotland (UK)
    • Posts 97
    • Points 1,340
    Re: Red question
    No not yet though with any luck the AMA should eventually allow something like that kind of instant access inside the MC. For the moment it's a long transcode from R3D to DNxHD.
    G.
    Dual 2.7GHz G5 | 5GB RAM | SIIG Firewire 400 | MC 2.8.3 | Mojo SDI | 2x 23" ACD [view my complete system specs]
     If it ain't broke, don't touch it!
  • Fri, Jul 10 2009 10:23 AM In reply to
    Re: Red question
    What's the difference between importing/transcoding R3D files and importing the quicktime proxies?
  • Sat, Jul 11 2009 7:59 PM In reply to
    • BlueGirl Media
    • Posts 97
    • Points 1,340
    Re: Red question
    If you do a straight import of the QT camera proxies then Avid will transcode them into whatever flavor of DNxHD you have chosen. This will take a while as Avid won't access all cores of the CPU during transcode (not sure if this is still true with v3.5) You will also loose all TC info and possibly even some extra metadata doing an import this way.
    When you use RedRushes to create the DNxHD QTs and an ALE file Avid will do a fast import (move and re-wrap as Avid MXF). RedRushes transcode to DNxHD should also be faster as it can access multiple cores.
    G.
  • Sun, Jul 12 2009 7:28 AM In reply to
    Re: Red question
    Also consider that Assimilate and BaseLight have products that will playback R3D in realtime. The BaseLight BLT will even render DNxHD mediafiles from R3D in slightly more than realtime. These are more costly options, but faster than the cheaper options. (You know the drill: good/fast/cheap, pick any two).
    Symphony Classic Nitris 4.0.2 on 2x 2.33 quad core XW8400/8GB Vista Biz 64bit | MC 4.0.2 on 2x dual core 2.66 XW8400/7GB Vista Biz 64bit | Mojo SDI | Unity... [view my complete system specs]
  • Mon, Jul 13 2009 9:27 PM In reply to
    • oze
    • New Zealand
    • Posts 200
    • Points 2,335
    Re: Red question
    I can confirm that the Baselight/BLT option works very well. Just finished my first project through this process it worked flawlessly matching back to and grading off the original Red files. The processing was very fast. BLT has 16 processor cores to render DNxHD MXF files that you simply copy to your HD.  No need to even import!
    Mac Pro 2.66Ghz , 17GB RAM, NVidia 8800GT/512MB, OS 10.5.6, MC 3.5, 750Gb Internal, Analog Mojo, 23 inch Cinema Display. Also 17" MBP Unibody 2.93Mhz... [view my complete system specs]
  • Mon, Jul 13 2009 9:49 PM In reply to
    Re: Red question
    In general, when you import the proxies, you will also not be seeing any of the camera data that the DP may have used to color correct.
    When you consider the difference in quality of the scenes as well as the ability to use another machine to conert the RED to DNxHD, using RedRushes or MetaFuze (on PC) is the way to go.
    MacPro MCA (v4.0.3/3.5.9/v3.1.4) on 2x3 GHz Quad Core Xeon; Mac Meridien (v12.1.2); Unity LanShare EX (v4.1.6) [view my complete system specs]
