hello,
i am having some difficulty working with my keyframes.
i set a mark at one point and set a mark keyframe at another. i then select just one keyframe to change a particular effect. when i go to the other keyframe, however, it has also been changed, thus i cannot make an effect change its course.
in other words, even though i select just one keyframe, its changing everythjing with it, when it should only be changing the mark.
what is going on here?
thanks,
steven
Steven,
What effect are you using?
Essentially you need to make sure that the parameter you are altering is actaulyl getting keyframed.
Enter the effect editior. Park at the point of the clip you want to eneter a keyframe and click the keyframe button on the effect editor. this should open a list of options. Choose add keyframe ALL parameters.
Now this keyframe and any added keyframes after this change should reflect all parameters keyframed and your adjustments should hold.
hi there,
ok looks like this is doing this with only the BCC filters and not the regulars. im not sure what u mean by selecting "all parameters." is this "list of options" the many details of the effect?
If you follow this link it gives you a good visual of what I am talking about:
http://community.avid.com/forums/p/27229/400247.aspx#400247
