Latest post Wed, Aug 5 2009 2:10 PM by miroa. 9 replies.
Page 1 of 1 (10 items)
  • Mon, Jul 6 2009 2:50 PM
    • miroa
    • Joined on Thu, Mar 23 2006
    • Slovakia
    • Posts 11
    • Points 155
    Unable mount workspaces with Mac ethernet client
    I have a problem with mounting unity workspaces on MacOS 10.5.7 with ethernet client. I can start connection manager and logged in without problem, but when I select workspaces and press connect button, connection finish with error message "unable connect ......because server not found".
    I tried change user, create new user, use unity administrator account, but without success. On WinXP everything works OK.
    Any idea?
    Thank you in advance
    Miroa
  • Mon, Jul 6 2009 7:22 PM In reply to
    • Doc Avid
    • Joined on Mon, Jul 17 2006
    • Los Angeles / Hollywood
    • Posts 2,238
    • Points 24,745
    Re: Unable mount workspaces with Mac ethernet client
    Did you read the release notes to ensure that your version of Unity works with that version of Mac OS?
    JDS
    Just about all of them, And a '06 Scion xB [view my complete system specs]
  • Tue, Jul 7 2009 12:47 PM In reply to
    • miroa
    • Slovakia
    • Posts 11
    • Points 155
    Lets double check
    From readme:
    Avid Unity MediaNetwork v5.1 now supports clients that use Macintosh Leopard operating
    systems (Mac OS version 10.5.3 and later). The following is a list of Leopard changes you
    need to know when working in the Avid Unity MediaNetwork environment and installing
    the client software on your Leopard clients.
    This release supports Macintosh 10.4.11 and 10.5.3 and later operating systems. When
    updating your Macintosh clients select the appropriate installer for your fiber or Ethernet
    client.
    I am using leopard installer 5.1.2
    Miroa
  • Wed, Jul 8 2009 6:49 AM In reply to
    • hosed
    • Joined on Wed, Jul 8 2009
    • Posts 11
    • Points 115
    make sure there are no spaces in your workspace names, macs hate this
  • Wed, Jul 8 2009 8:47 AM In reply to
    • miroa
    • Slovakia
    • Posts 11
    • Points 155
    No spaces, workspaces names like: edit, media, project .... no special characters
  • Sat, Jul 11 2009 3:10 AM In reply to
    • Doc Avid
    • Posts 2,238
    • Points 24,745
    So it says supported..   Is your firewall on your Mac turned on?
    JDS
  • Mon, Jul 13 2009 12:14 AM In reply to
    • hosed
    • Posts 11
    • Points 115
     I have seen case sensitivity problems with the user name and password, make sure its exactly the same as the user accounts entry
  • Mon, Jul 13 2009 4:05 PM In reply to
    • Carlos13
    • Joined on Mon, Jul 13 2009
    • Posts 1
    • Points 15
    Same problem here. We had a user name "student" for students to use in our advanced video classes. When I try to mount our Unity volumes with this user name none of the workspaces mount. I checked the user management section and this user name was missing from the user names list (I don't know why). I re-created the user name but it still fails to mount any workspaces. Another user name, admin, mounts all volumes without a problem. The settings in the connection manager are identical for both user names.
    Any help with this would be greatly appreciated.
    Avid Unity Media Network v.5.1 (Network and clients).
    iMacs running OS X 10.5.7
  • Wed, Jul 15 2009 7:42 PM In reply to
    • Doc Avid
    • Posts 2,238
    • Points 24,745
    Then delete the "bad" user,  and duplicate the good user, with the dupe taking the place of the bad user.   Also-  you have addressed the windows users, right?
    JDS
  • Wed, Aug 5 2009 2:10 PM In reply to
    • miroa
    • Slovakia
    • Posts 11
    • Points 155
    Thank you Hosed, you are right. When i created Macintosh user account with the exactly same name and password like on unity, everything works fine.
    I am just surprised, why I must have the same Macintosh account and unity account? On PC it is not necessary.
    Thanks once again.
