Latest post Sun, Jul 5 2009 2:31 AM by titohawaii. 2 replies.
  • Sat, Jul 4 2009 11:11 PM
    • titohawaii
    • Joined on Sun, May 14 2006
    • Hawaii
    • Posts 70
    • Points 895
    3 gig patch nessessary with MC 3.x
    i got this email from GeniusDV about "Media Composer Windows XP install 3GB"
    i looked in the forums and most of the posts seemed to involve versions of MC previous to 3.x
    is the patch nessessary with MC 3.x?
    i have gotten the running out of memeory warning several times when working with small HD projects so i am wondering if for larger projects i should plan on working in smaller sections and assembling later or will the 3 GB patch be enough of a fix.
    tito
     GeniusDV
    HP Workstation xw8200 PNY nVIDIA QUADRO FX 3450 PCI-E 4GB DDR2-400 ECC REGISTERED RAM 300GB SATA-II DRIVE (1ST) 300GB SATA-II DRIVE (2ND) ADS... [view my complete system specs]
  • Sun, Jul 5 2009 1:31 AM In reply to
    Re: 3 gig patch nessessary with MC 3.x
    As long as your OS is Windows XP 32 bit, you should run the /3GB bat file. This assumes you have 3GB or more of RAM installed.
    It basically tells the OS to allow MC to use a bit more than the 2GB limit (gives it another ~512MB). If you are in Vista 64 bit, it does not apply. Just add more RAM. MC will utilize up to 4GB in Vista 64 bit.
    MC 3.1.3, Intel i7 920, Vista 64 bit, Nvidia GTX 275, 6 GB of RAM, X-Fi Titanium Professional, MSI X58 SLI Platinum. [view my complete system specs]
  • Sun, Jul 5 2009 2:31 AM In reply to
    • titohawaii
    • Hawaii
    • Posts 70
    • Points 895
    i have 4 so i will do that
    thanks
    tito
