Latest post Sun, Jul 5 2009 3:44 AM by jwrl. 7 replies.
  • Sat, Jul 4 2009 8:30 AM
    • Editarian
    • Joined on Sat, Apr 22 2006
    • Posts 10
    • Points 130
    No Audio Playback in Media Composer
    Now I've checked my sound card...and outside of Avid, my audio works fine...but in my Avid Project, I cannot hear anything during playback. I can see the sample rate on the clip and I can monitor the audio on the Audio tool, but I cannot hear a thing.
    Any suggestions? Its an Avid Media Compose 3.0 and I'm running it on a Vista 64bit, all the digitized footage is in PCM (MXF) format.
    Also, in my audio project settings, I already have "Convert Sample Rate while Playing" to ALWAYS.
    Any suggestions?
  • Sat, Jul 4 2009 10:58 AM In reply to
    Re: No Audio Playback in Media Composer
    Check if MC muted your windows audio mixer.
    Could you please explain in detail how your system is set up? What I want to know is: are you using any external sound device or a PCI soundcard or an onboard soundchip? What kind of monitors are you using (audio monitors, not your screen :)? Any kind of mixer attached? Simply: your whole audio "chain".
    Complete system specs added to your profile could help, also.
    Editarian:
    From my experiences I set it to "Never" because I want to know if there are mismatched  samplerates in my project and would correct it immediately. Setting it to "Always" might work while editing but can lead to unpleasent results, in the end.
    Regards, g_f
    Dell Precision m6400, Intel QX9300 2,5GHz Quadcore, nVidia QuadroFX 3700@1GB, 4GB RAM, M-Box2, MC 3.5.1 Software Only, ProTools LE 8cs2, WindowsXP 32bit... [view my complete system specs]
  • Sat, Jul 4 2009 4:56 PM In reply to
    • Editarian
    • Posts 10
    • Points 130
    Thanks for the reply.
    I'm using the onboard soundchip which came with the Gigabyte Motherboard. And I'm not using any mixers or audio monitors...just plain speakers or headphones.
    I usually have "Convert Sample Rate" to NEVER as well. Its just that I'm tring different things.
  • Sat, Jul 4 2009 5:15 PM In reply to
    Afraid I am repeating myself: did you check that MC didn't mute the windows audio mixer (the monitor icon next to the clock)?
    g_f
  • Sat, Jul 4 2009 5:28 PM In reply to
    • Editarian
    • Posts 10
    • Points 130
    oh yeah yeah...all that I've checked.
  • Sat, Jul 4 2009 6:04 PM In reply to
    Hmmm, does MC recognize your soundcard in the "Audio Project" settings?
    Do you have the chance to test with a PCI Sounblaster card.
    g_f
  • Sat, Jul 4 2009 6:21 PM In reply to
    • Editarian
    • Posts 10
    • Points 130
    In HARDWARE in my Audio Project, its says
    CARD - "DirectSound Audio & 1394 Audio"
    PERIPHERAL - Avid OHCI
    SYNC MODE - Internal
    I'm not sure how to test my PCI Soundblaster card.
  • Sun, Jul 5 2009 3:44 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 4,234
    • Points 48,655
    Try the following.  Open Avid and launch a project (any project).  Launch the audio tool and try and output tone.  If this works, try playing a clip or sequence.  You should have audio working for the rest of your session.
    (I know this sounds like black magic, but I stumbled across this "fix" when I was trying to sort out issues with a Realtek chipset.  I have no idea why internally generated tone should fix a sound output problem.  It may work for you too.)
    MC 4.0.3 - Asus P6T Deluxe V2 mobo - Intel i7 920 2.66GHz - nVidia Quadro 1700 - 12 Gbyte mem - Internal 4 Tb SATA II 4-way RAID 5 array - Pyro firewire... [view my complete system specs]
