Latest post Sun, Jul 5 2009 10:10 AM by jveekeres. 8 replies.
Page 1 of 1 (9 items)
  • Sat, Jul 4 2009 6:11 AM
    System Requirements
    I am about to purchase a new desktop PC for video editing.  I am on a budget and am hoping to find a computer that will work with Media Composer Software that is reasonably priced.  Will Avid Media Composer Software work with a a computer that has an AMD Phenom X4 2.2 GHz processor and an NVIDIA GeForce 9100 vgraphics card?  If not can you direct me to the most cost effecient machine that will work with this software.  Thank You
  • Sat, Jul 4 2009 8:10 AM In reply to
    • mvegas
    • Posts 1,482
    • Points 17,010
    Re: System Requirements
    http://www.avid.com/products/Media-Composer-Software/index.asp
    Visit the above link for system requirements.
  • Sat, Jul 4 2009 9:30 PM In reply to
    Thanks.  I did look at the requirements but it doesnt mention anything about Vista and the new Windows 7.  I am also curious if it will work on an Intel Pentium Processor 2.6 GHz.  And if it will, would I be able to install an Nvidia card in the following computer HP Pavilion p6110f Desktop Computer With Intel® Pentium® Processor E5300...
  • Sat, Jul 4 2009 9:39 PM In reply to
    The reason I am asking is that most of the models that Avid qualifies are discontinued and I am looking for a new desktop.  the HP XW8400 is discontinued on HP site.
  • Sat, Jul 4 2009 9:52 PM In reply to
    • jveekeres
    • Athens Greece
    • Posts 762
    • Points 9,530
    check ebay. Lots of xw8400's out there and for very good prices.
    Used is good.YesSmile
    7x HP XW8400 9x HP XW8200 4x HP XW8000 5x Media Composer 3.1 2x Media Composer 3.1 Adrenaline 2x Media Composer 2.7 Adrenaline HD 1x Media Composer... [view my complete system specs]
    Jeroen van Eekeres
    Ena productions
    Software activation AND dongle is better then only software activation.
  • Sat, Jul 4 2009 10:51 PM In reply to
    • camoscato
    • Posts 6,322
    • Points 75,685
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    tragik_entertainment:
    I did look at the requirements but it doesnt mention anything about Vista....
    It sounds like you were looking at the list with the specific systems.  Take a look at the system requirements page:
    http://www.avid.com/products/Media-Composer-Software/system-requirements.asp
    good luck,
    Carl
    MC 4.0.5, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 4 GB RAM, nVidia GeForce 7150M, Conexant HD Audio, G-tech 500GB G-drive [view my complete system specs]
    There is no such thing as a video emergency.
    I've got a new website for 2010!
  • Sun, Jul 5 2009 2:50 AM In reply to
    OK so do the Nvidia Quatro cards work in the Windows based PC's and do the Nvidia GEFORCE cards also work in the Windows based PC's and what about Nvidia NVS cards?  Also the specs state that the minimum requirements for processor are Intel Core 2 Duo 2.33 GHz, will an Intel Pentium Processor work with 2.66 GHz and will and AMD processor work with 2.66 or 3.0 GHz or does it HAVE to be Intel Core 2 Duo?
  • Sun, Jul 5 2009 7:59 AM In reply to
    • camoscato
    • Posts 6,322
    • Points 75,685
      Moderator: Meridien
    Although none of us can guarantee what will work and what will not, if you take a look at people's system specs in their profiles (mine, for example) you can see that some people are using AMD-based machines and GeForce cards and Media Composer works fine.
    I'd suggest trying a forum search for the specific nVidia card you're thinking about getting and the specific processor you're thinking about getting and see if there are any reports of trouble or success.  I'm afraid that's the only way to get information about specific components that are not listed in the system requirements.
    good luck,
    Carl
  • Sun, Jul 5 2009 10:10 AM In reply to
    • jveekeres
    • Athens Greece
    • Posts 762
    • Points 9,530
    Maybe I missed it but I did not read which version of media composer you want to use. I have tested media composer on other hardware and it works but, depending on version, with limitations. For example only lower resolutions work like dv25, a mojo can't be used, or network speeds, pci bus speeds, are not fast enough for network storage., etc, etc.. So are you going to use MC software only or is there more?
    After building my own systems for years I'm now totally running on HP XW machines. It makes me much more flexible.
    Jeroen van Eekeres
    Ena productions
