Please add a 3:2 add and subtract tool to the MC / Sympony line. It is available in DS. It is a necessary tool in a world where 23.976 footage co-exists with 29.97.
Cheers,
Jef
EDIT - see the whole thread. I want to modify this request to say "Add 3:2 add and subtract to transcode tools".
Seconded!
Burbank, Ca
www.alphadogs.tv
www.digitalservicestation.com
www.editorslounge.com
jef: Please add a 3:2 add and subtract tool to the MC / Sympony line. It is available in DS. It is a necessary tool in a world where 23.976 footage co-exists with 29.97. Cheers, Jef
Jef,
I rarely work in anything other than 1080i/50, but I think the Timewarp FluidFim option is what you're looking for:
Thanks for pointing that out. I thought I had messed with those a couple of years ago and found problems. So I just retested.
I took some 29.97p material I had. I burned in a TC window which showed fields (even though no fields in source). I added the Pulldown Insertion. It did not created the correct 2:3 sequence or any proper result that I could see.
In fact, results of both Pulldown Insertion and Pulldown Removal seem horribly wrong.
Now maybe I am not using them correctly. But I use the similar tools in Avid DS regularly. They work as expected.
These don't. I call bug.
But thanks for reminding me of them.
No worries, Jef.
Like I said, I'm in Pal-land, so never really ever use it. I just saw a tutorial recently where it mentioned it so jogged my memory.
http://community.avid.com/forums/p/73285/410077.aspx#410077
(the last part)
Shame it doesn't work though...
Ra-ey
Hey Ra-ey,
I just redid my test on this. Realized I had done things wrong.
I take back my comment that the 3:2 add / subtract tools don't work. In fact they do. I am sorry for the mistake.
So thanks for pointing these tools out Ra-ey.
Now .... Let me modify my original request.
3:2 add / subtract needs to be integrated into the transcode tools. This would be a small step towards the goal of having the ability to mix frame rates in a project, which is one of the biggest holes in Avids timelines now. This would not solve all the issues, but would surely help.
Excellent news! Thanks for posting the update. I vaguely remembered using it a couple of years ago and it working, but I wasn't sure.
Can you tell me how it compares to the one in the DS. We don't get much call for that kind of converting in ours.
To be quite honest, any project where I felt I was going to need 3:2 add / subtract, I would probably want to be in DS because of much more powerful effects and compositing tools.
The reasons I was looking for the tools in MC was to deal with the various different frame rate clips you get these days.
Does that make sense?
Thanks again.
Absolutely.
To be honest, whenener I need to convert anything, I either use Streamclip - or when Sync/Duration is not an issue - the old 'IgnoreQTRate True' console command. Avid's import filters have really improved, I think. This is great for the occasional piece of file-based archive, but not much use for a tape workflow.
I definitely second this feature request. I agree that the ability to add or remove pulldown in the file import window would be a HUGE benefit.
Chris
