Latest post Sat, Jul 4 2009 10:16 AM by jwrl. 6 replies.
Page 1 of 1 (7 items)
  • Fri, Jul 3 2009 11:56 AM
    • whippet65
    • Joined on Fri, Jul 3 2009
    • Posts 2
    • Points 30
    Relinking issues with ALE from Red R3d files
    Hiya, I am having an unusual problem.
    I am working with Avid Metafuze, transcoding R3D files.  My transcode settings are DnXHD 120 Iso 1280 and Quarter good quality. The media is transcoding to a unity drive - the destination folder is M:\Avid MediaFiles\MXF\1\
     After the transcode I am exporting an ALE file to the desktop and then reimporting it into a bin in Avid - however, when I go ro relink, the media remains offline.  Could someone please help.
    Cheers, Mark
  • Fri, Jul 3 2009 5:39 PM In reply to
    • ThomasDubiel
    • Joined on Wed, Jan 28 2009
    • Chicago, IL
    • Posts 75
    • Points 950
    Re: Relinking issues with ALE from Red R3d files
    How are you attempting to relink? Ive found that relinking according to specific resolution usually does the trick. Try setting the specific resolution and the drive the media is on.
    Avid MC v3.0, windows vists sp1, gigabyte ga-ex58-ud4p mobo,6GB 1800 Mhz ram, nvidia quadro fx 1800, 500 GB 7200 rpm boot drive, 1TB 7200 rpm media drive... [view my complete system specs]
  • Fri, Jul 3 2009 5:48 PM In reply to
    Deselect the option "relink to current project only" or something along those lines.
    Symphony Classic Nitris 4.0.2 on 2x 2.33 quad core XW8400/8GB Vista Biz 64bit | MC 4.0.2 on 2x dual core 2.66 XW8400/7GB Vista Biz 64bit | Mojo SDI | Unity... [view my complete system specs]
  • Fri, Jul 3 2009 5:57 PM In reply to
    • ThomasDubiel
    • Chicago, IL
    • Posts 75
    • Points 950
    oh yes, that usually does the trick.
  • Fri, Jul 3 2009 7:27 PM In reply to
    Also, for now, you don't need to export/import/relink ALE's. You can simply open the Media Tool, grab the clips and drag them into a bin. Currently, the ALE does not carry any more metadata than the MXF file itself does.
  • Fri, Jul 3 2009 7:41 PM In reply to
    • whippet65
    • Posts 2
    • Points 30
    Thanks for your help.  It turns out that the problem was that because I had manually created the subfolders Avid Mediafiles/MXF/1 there was no media database, so that the masterclips didn't appear in the media tool.  I wiped my media drive and brought in a test pattern so that avid created the directory structure and according the media daabases needed to catologue the MXF files.  It works as it should now.
    Mark
  • Sat, Jul 4 2009 10:16 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 4,233
    • Points 48,650
    If you had created Avid Mediafiles/MXF/1 I'm not surprised.  If you had created Avid MediaFiles/MXF/1 yourself, it should have worked.  I've done this in the past with no issues.
    MC 4.0.3 - Asus P6T Deluxe V2 mobo - Intel i7 920 2.66GHz - nVidia Quadro 1700 - 12 Gbyte mem - Internal 4 Tb SATA II 4-way RAID 5 array - Pyro firewire... [view my complete system specs]
