Latest post Wed, Jul 8 2009 7:04 AM by hosed. 8 replies.
Page 1 of 1 (9 items)
  • Fri, Jul 3 2009 9:08 AM
    640x480 low4bit display
    I restarted my Unity Media Network and after booting, my display became 640x480 at lowest4bit.I tried to set it at 32bit highest but it remains at the lowest resolution. I restarted it a couple of times already but still the display is set at the lowest level. I tried using all the monitors available here in the office but still no changes. Can anybody help me find a solution to this? Thanks.
    Avid Media Composer 3.5.1 Avid Unity MediaNetwork DELL T5400 3.16 Quad Core Intel Xeon 4gb ram Macbook Pro 2.96 4gb ram [view my complete system specs]
  • Sat, Jul 4 2009 1:25 PM In reply to
    • jveekeres
    • Athens Greece
    • Posts 660
    • Points 8,345
    Re: 640x480 low4bit display
    Have you checked in the device manager if your graphic card is recognized correctly?
    7x HP XW8400 9x HP XW8200 4x HP XW8000 5x Media Composer 3.1 2x Media Composer 3.1 Adrenaline 2x Media Composer 2.7 Adrenaline HD 1x Media Composer... [view my complete system specs]
    Jeroen van Eekeres
    Software activation AND dongle is better then only software activation.
  • Mon, Jul 6 2009 6:12 AM In reply to
    Yes. It says RAGE XL PCI, This device is working properly. Do you think I need to download any drivers that I need to install to fix the problem? The Unity works fine right now. I just don't know if it will cause some problems in the long run because it doesn't look normal having a 640x480 screen at this day and age.
  • Mon, Jul 6 2009 12:47 PM In reply to
    • jveekeres
    • Athens Greece
    • Posts 660
    • Points 8,345
    No, don't think so. You can two things. Reimage the unity but as it is working normal I wouldn't.
    In most cases an uninstall of the graphic card drivers and a restart fixes it on a windows XP workstation. I have never seen this on 2000/2003server but I see no harm in trying.
    Jeroen van Eekeres
  • Mon, Jul 6 2009 7:26 PM In reply to
    • Doc Avid
    • Joined on Mon, Jul 17 2006
    • Los Angeles / Hollywood
    • Posts 2,238
    • Points 24,745
    I have seen this before,  we have certain KVM switches and piss it off.
    Connect a different VGA monitor directly, then restart your Unity.
    JDS
    Just about all of them, And a '06 Scion xB [view my complete system specs]
  • Mon, Jul 6 2009 8:29 PM In reply to
    • jveekeres
    • Athens Greece
    • Posts 660
    • Points 8,345
    yeap a KVM switch can prevent a graphic card from detecting possible resolutions. But I didn't see any mentioning of a kvm switch...
    Jeroen van Eekeres
  • Tue, Jul 7 2009 6:37 AM In reply to
    thank you Jeroen. I did the uninstall display adapters from the device manager and restarted the unity and it did work. Rollback and update drivers didn't. Thank you. It was a very big help. Sorry guys no KVM switches attached.
  • Tue, Jul 7 2009 9:48 AM In reply to
    • jveekeres
    • Athens Greece
    • Posts 660
    • Points 8,345
    Happy to be of service.Smile
    Jeroen van Eekeres
  • Wed, Jul 8 2009 7:04 AM In reply to
    • hosed
    • Joined on Wed, Jul 8 2009
    • Posts 11
    • Points 115
    I've had this happen, most likely, the system has run out of resources even though it has 4 GB of system RAM due to improper memory allocation.
    Run the Unity Profiler by going to the Windows Start button > Programs > Avid Unity and choose Profiler. Select Media Engine and then look for the Metadata Configuration information in the Profiler window.
    If Page Table Entries shows "FAILED", then you need to run the 4 GB batch file to correct the allocation of RAM.
    The 4GBME file is in the Media Engine 5.1.1 Installation package within the Extras folder.
    Run the 4GBME.cmd file and reboot the Media Engine for the revised boot setting to take place.
