Latest post Fri, Jul 3 2009 9:42 PM by jef. 3 replies.
  • Wed, Jul 1 2009 6:11 PM
    • Sam Z
    • Joined on Fri, Jan 25 2008
    • Posts 37
    • Points 545
    23.98 -> 59.94
    Well, I've haven't run into this issue before.  I'm working in a 1080 59.94i DNxHD 145 project and I just got handed QT movie that is 1080 HDV 23.98p.  What is the best way to add pull-up?  The Avid won't do it, correct?  i think Apple's Compressor will, but I'm unsure what settings to use.  I also have Sorenson if that could work.
    Thanks for the help.
    -Sam
  • Wed, Jul 1 2009 7:41 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 470
    • Points 5,780
    Re: 23.98 -> 59.94
    Sorenson won't help.
    Do you have After Effects?  That can add 3:2.
    Or you could use the method noted
    http://www.24p.com/conversion.htm
    But note that that is not the same thing as 3:2 and can NOT be taken out after the fact the way that 3:2 can be.
    It will also look diifferent up against 3:2 footage.
    Jef
    MC 3.1.3 Mac Dual 2.8 8core ATI2600 OS 10.5.7 QT 7.6 10 GB ram 2xSATA software raid local storage [view my complete system specs]
  • Wed, Jul 1 2009 8:53 PM In reply to
    • Sam Z
    • Posts 37
    • Points 545
    Re: 23.98 -> 59.94
    Awesome, I do have After Effects.  This is what I did, and from what I can tell it worked.  Does this look correct to everyone?
    Import the HDV clip into AE, create a new comp.
    *Footage interpreted as Pixel Aspect Ratio HDV 1.33, seperate fields Off, Use Frame Rate of file 23.976fps.
    *Comp set to 1920x1080, Sq Pixel, 23.976fps.
    Add it to the render queue
    *Render Settings:  Field Render-Upper Field First, 3:2 Pulldown-WWSSW (on the right it now says "Frame Rate, Sampling Comp @23.976 fps, Use this Frame Rate 29.97)
    *Output Module:  Quicktime (1080i/59.94 DNxHD 145 8-bit, Alpha None, Color Levels 709, Millions of Colors, Frame Rate 29.97)
    *Avid Import:  Image sized for current format, 709, Odd, Ignore
  • Fri, Jul 3 2009 9:42 PM In reply to
    • jef
    • Maryland
    • Posts 470
    • Points 5,780
    Re: 23.98 -> 59.94
    Pretty much looks good!
    It sure would be nice if the Avid Media Composer line had 3:2 Add and Subtract like almost every other professional video application.
    Cheers,
    Jef
