Latest post Wed, Jul 1 2009 6:13 PM by Randall L Rike. 8 replies.
Page 1 of 1 (9 items)
  • Wed, Jul 1 2009 3:28 PM
    • SHELGES1
    • Joined on Wed, Jul 1 2009
    • Posts 14
    • Points 170
    Stutter during Playback & Red "Render" Line in Timeline
    Hi - Help is greatly appreciated as I have to have this system up and running before the end of day!
    I just added a mojo DNA to my Avid Xpress Pro System and am now experiencing stuttering during playback as well as when I scrub through either monitors.  When I'm playing back even the simplest of sequences in the timeline, the audio drops out and the wheel starts spinning.  Then the red "Render" line appears on the timeline where the problem occurred.  The computer never crashes, but this problem occurs every 30 seconds or less. When I disconnect the Mojo this problem is resolved.  However, I'm eventually going to need it and would like to get it up and running now.  I didn't download or install anything when I connected  the Mojo - is there some software I'm missing?
    Specs:
    Avid Xpress Pro 5.8.4
    Mojo DNA
    G5 Powermac
    1.6 Ghz
    4 GB DDR SDRAM
    OS x 10.4.11
  • Wed, Jul 1 2009 3:52 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,837
    • Points 201,255
    Re: Stutter during Playback & Red "Render" Line in Timeline
    Did you plug your drives directly into the Mojo?
    If so, try pluggin them into the CPU instead. Also, if you have FW drives, you must be running them on an external PCI FW card. They cannot share the same FW bus as the Mojo and ALL of the G5's FW ports are on the same bus.
  • Wed, Jul 1 2009 3:55 PM In reply to
    • SHELGES1
    • Posts 14
    • Points 170
    NO, drives are definitely plugged into a separate PCI card.
  • Wed, Jul 1 2009 3:57 PM In reply to
    • SHELGES1
    • Posts 14
    • Points 170
    This is the setup:
    I have two FW 800 PCI Cards installed in the back of the tower where I connect the Hard drives.  Mojo is connectd via FW 400 in the front port of the machine.  They can not possibly be connected, can they?
  • Wed, Jul 1 2009 4:00 PM In reply to
    • SHELGES1
    • Posts 14
    • Points 170
    Aye... CORRECTION: Problem exists with OR without Mojo.
  • Wed, Jul 1 2009 4:19 PM In reply to
    SHELGES1:
    That's not a "render" line - that's a warning telling you that your storage is not fast enough to playback that footage or section of footage smoothly.  Sometimes rendering will help the playback, but it's really just a cure for the symptom not the problem.
  • Wed, Jul 1 2009 4:33 PM In reply to
    • SHELGES1
    • Posts 14
    • Points 170
    Ah, I see.  But I would have a hard time believing it is the Hard Drives themselves, seeing as I have used them on other similar systems with no problem.  Could it be that my Processor is not fast enough?  I noticed that the minimum processor speed for G5 listed on the Avid Website is 2.0 Ghz.  Or could it be a problem with the PCI cards?  I just installed a new one.  I have two FW 800 cards in slot 2 & 3.
  • Wed, Jul 1 2009 5:45 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 2,885
    • Points 32,930
    The Red line indicates the CPU is not up to the task.  Also, try using only one PCI card if possible.  Read the "Using Mojo" document to see which slot the Firewire card should be in on your machine as one of those slots may be conflicting with the internal bus that handles the built in firewire ports.
  • Wed, Jul 1 2009 6:13 PM In reply to
    According to the Avid built-in HELP, Red doesn't specify the cause, but indicates that frames cannot be displayed, and rendering is suggested.
    Blue indicates a disk speed limitation.
    Yellow indicates lack of processing power (CPU).
    See "Understanding Real-Time Playback Information in the Timeline".
    Media Composer 3.5.9/4.0.2 w/Mojo (analog), HP xw8400, 1xQC 3.0GHz, 8GB RAM, FX 3700, 1TB Boot, 1 x 1TB & 1 x 500GB internal SATA media drives, 3-Ware... [view my complete system specs]
    Our new websites are up!
    http://www.lifenetintl.org/
    http://www.capitalchristian.net/
