Latest post Mon, Jul 6 2009 6:07 PM by ritam_bhatta. 6 replies.
Page 1 of 1 (7 items)
  • Tue, Jun 30 2009 5:32 AM
    16mm Keycode error
    plz help me i am using avid xpress pro hd 5.7 on an IBM platform my problem is that i started a 16mm film project and capture my telecine material but when i entering the keycode number starting keycode number is perfectly ok with the punch list (recived from lab along with telecine) but in end keycode its vary.
    Incase of 35mm project it works perfectly allright no problem.
    please help me.
    AVID XPRESS PRO 5.7 WITH MOJO(ANALOG),INTEL CORE2DUO, OS-WIN-XP(PROFESSIONAL),2GB RAM,NVIDIA 7300 GT GRAPHICS CARD,CREATIVE SOUND BLASTER AUDIGY SOUND... [view my complete system specs]
  • Tue, Jun 30 2009 1:02 PM In reply to
    • MichaelP
    • Boston
    • Posts 1,751
    • Points 21,670
      Moderator: Film
      Moderator: MetaFuze
    Re: 16mm Keycode error
    You shot 16mm and are in a 16mm project, and you are saying that the footage counter is wrong? How does it vary by? The punch list is counting in 20 frames per KeyKode correct and not 40 frames per foot as you would find on a film synchronizer.
    When you enter a value, does the separator between feet and frames show up as an "&" to denote 16mm? Also, is there a burn-in? Does the KeyKode value above the monitor match the burn-in?
    Michael
    HP 8600 Symphony Nitris DX v4 || MBP 15" Media Composer v4 [view my complete system specs]
    ____________ Anything 24fps
  • Wed, Jul 1 2009 4:41 PM In reply to
    yes keycode value is perfect match with burncode (moniter value) & separator between feet and frames show up as an "+" not "&".
  • Wed, Jul 1 2009 8:13 PM In reply to
    • MichaelP
    • Boston
    • Posts 1,751
    • Points 21,670
      Moderator: Film
      Moderator: MetaFuze
    So now I m trying to figure out why the Avid metadata in the bin and above the monitor matches the burn-in exactly, which is what you want, but does not match the punch lists...
    Also, you mention that it is a "+" and not an "&". Can you tell me what the burn-in code is rolling over for the frame counter? Is it +19 -> +00 or is it +15 -> +00?
    Michael
  • Fri, Jul 3 2009 8:07 PM In reply to
    no avid meta data in not matching wiht the moniter burn in & aloso not with the the punchlist. frame counter is +19 -> +00. not +15 -> +00.
  • Fri, Jul 3 2009 8:38 PM In reply to
    • MichaelP
    • Boston
    • Posts 1,751
    • Points 21,670
      Moderator: Film
      Moderator: MetaFuze
    Check two more things:
    1. Project window, format. Make sure it says 16mm film
    2, Bring up the KN Film column - make sure it says "16.1"
    If those aay 35mm then that would explaing why it may be counting as 35mm and not 16mm.
    Michael
  • Mon, Jul 6 2009 6:07 PM In reply to
    1. checking project window, format it is 16mm film.
    2. But i didnt find the KN Film Column, (There is KN START/END column only.)
    plz guide me.
    thankx.
