Latest post Tue, Jun 30 2009 1:09 PM by Medienmacher. 3 replies.
  • Mon, Jun 29 2009 11:42 AM
    • Medienmacher
    • Joined on Thu, Jan 22 2009
    • Hassfurt (Germany)
    • Posts 11
    • Points 135
    Using different HD-Formats & Framerates in one project/timeline --> what does AVID do on import?
    Hey guys.
    I hope someone can help me, trying to understand how AVID MC 3.5 deals with different formats and framerates:
    I am currently starting with a project that really needs a lot of different formats to mix:
    - DVCPro HD 720p/25  (P2)
    - DVCPro HD 720p/23,98  (PS)
    - AVID DNxHD 185 1080i/25  (MXF-Files)
    - Quicktime-Movies with libquicktime-1.0.0-Codec, 1920x1080, 25fps
    - Quicktime-Movies Apple ProRes 422, 1920x1080, 24fps
    - R3D-Files, RedCode 3840x2160, 23,98fps
    The final video should have 25fps (PAL) and a HD-resolution, but it`s not sure at the moment if 720 is sufficient or if Full HD with 1080 is needed.
    The resolution itself is not the big problem, as I can mix these in the "open timeline". But obviously I cannot mix the different framerates.
    In order to get a overview of the available footage for me and the customers I created a 720p/25-project and mounted the P2-folder with 720p/25 (thanks to AMA!). I also can use the 1080/25 MXF-files there, that originally came from a HDCAM-Tape. So far so good.
    But what`s the correct way to use the files with different formats?
    I imported some of the other files as well, and it worked!! So according to the headings in the BIN for example the 24fps-Apple ProRes-Files have 25fps, now. Same with imported libquicktime-Files.
    For the DVCPro HD 720p/23,98-files I created another fitting project, selected the footage I want to use, and exported this with 25 fps. Geeked
    Well, for a first footage selection this will do it, but I am not happy with this.
    What does AVID do when importing files with 23,98fps into a 25fps-project? I can see that the clips jutter a bit because of the missing frames, of course. So that seems not to be a great solution.
    Can anyone help me with this?
    What`s the "correct" workflow for projects that have different formats and framerates?
    And: how can I be sure that the framerates and formats as shown in a bin are REALLY correct, and not imported the wrong way? For example when I receive MXF-Files for Editing, and simply drag them in the AVID Media Files Folder and connect them via Media Tool....
    I`m thankfull for any hint and help on this!
    Thanks in advance.
    AVID Media Composer (MAC) @UNITY AVID Xpress Pro (Windows) [view my complete system specs]
  • Mon, Jun 29 2009 2:16 PM In reply to
    Re: Using different HD-Formats & Framerates in one project/timeline --> what does AVID do on import?
    If you're converting frame rates strictly within Avid, I don't know if there's a better way than this:
    http://www.24p.com/conversion.htm
    I'd love to be proven wrong there, though.
  • Mon, Jun 29 2009 5:00 PM In reply to
    One of the biggest things is basically, "does it look right?" If you aren't matching back, and never will need to, like in an online/offline edit, you can do what you like, but know that you may not ever be able to re-create that import. The 24p.com version is cool, and for bigger jobs a terranex or other hardware device is safest but not realistic for indie budgets.
    As always, "adding" frames/fields is easier than taking them away. And if you can't "go back" to what you've done, go high res for your transcoded media.
    Also, "Full HD" is not a correct way to think about 720 vs. 1080. There's technically more info in a progressive 720 frame than an interlaced 1080 one. Google it.
    Don't trust the internet...
  • Tue, Jun 30 2009 1:09 PM In reply to
    • Medienmacher
    • Posts 11
    • Points 135
    tube vacuum:
    Cool! Thanks for this. I remember having seen this page in the past, but somehow I forgot it. Will definitely try this. Does anyone know if this FluidMotion/Timewarp solution is better than e.g. changing framerates in After Effects? There are a lot of possibilities, too, there.
    @ hidefcowboy:
    A great hint, thx! Seems those "new" workflows with different footage from hard-drives, flash-cards etc need a new thinking of media in the matter of re-creating older projects. Was easier with good old tapes, wasn`t it?
    Well, anyone else that has experience in handling such different formats?
