Latest post Mon, Jun 29 2009 1:09 PM by switthaus. 10 replies.
Page 1 of 1 (11 items)
  • Mon, Jun 29 2009 8:30 AM
    Divide and conquer
    Can somebody help me find the divide and conquer page? Is it still applicable? Or can someone teach me how to find corrupt media? Please? Thank you. I am having so many errors right now and I just can't isolate the problem.
    here are some of the errors that come out:
    Exception:invalid argument....
    Assertion failed:(*fileHdl)->magic==DISK_MAGIC
    STRM_BUF_SMALL,buflen:1024
    Badly need your help. Thank you.
    Avid Media Composer 3.5.1 Avid Unity MediaNetwork DELL T5400 3.16 Quad Core Intel Xeon 4gb ram Macbook Pro 2.96 4gb ram [view my complete system specs]
  • Mon, Jun 29 2009 9:20 AM In reply to
    • camoscato
    • Posts 6,093
    • Points 73,065
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: Divide and conquer
    Mark in and out around the first half of your sequence.  Press Play In to Out (6 key on the top row of the keyboard).
    If the sequence plays, there's no corrupt media between the in and out points, so try again by marking in and out around the second half of the sequence.  When you find which half won't play, continue marking in and out around smaller and smaller portions of the sequence until you find the clip or effect that is causing the problem.  Delete the effect or media and rebuild/recapture/reimport it.
    good luck,
    Carl
    MC 3.5.4, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 4 GB RAM, nVidia GeForce 7150M, Conexant HD Audio, G-tech 500GB G-drive [view my complete system specs]
  • Mon, Jun 29 2009 10:34 AM In reply to
    Thanks Carl. I did this before already and I already found some of the bad media. My problem now is I think I've got a bunch of corrupted files in the bins. What I'm trying to do now is batch import each bin that I have but a lot of times, it ends up stopping the batch import without me cancelling it. Then I also get the BUS THREAD error at times when I locate a file during batch import. I really don't know what's going on. First I had this problem on the Unity. Now I transferred the project into a local drive and started re-importing it on a local drive(because these are MXF media from SonyEX cameras), then I got a lot more errors. If you need any more info about my problem I'd be glad to talk about them here. I badly need help on this. Thanks.
  • Mon, Jun 29 2009 10:50 AM In reply to
    • camoscato
    • Posts 6,093
    • Points 73,065
      Moderator: Meridien
    biennarc100907:
    I'd try batch importing smaller selections of clips and see if you are able to identify which clips are causing the batch import to fail, or if it is not consistent and is a problem with the system itself rather than the media.
    biennarc100907:
    Hopefully a Mac person will chime in on this.  I know nothing about Mac error troubleshooting.
    biennarc100907:
    Just to make sure, have you tried creating a new user and a new project and deleting the MCState settings?  It may not be a settings problem, but it's best to eliminate them as a possible cause.
    good luck,
    Carl
  • Mon, Jun 29 2009 11:01 AM In reply to
    Where do I delete the MCstate settings?
  • Mon, Jun 29 2009 11:21 AM In reply to
    • camoscato
    • Posts 6,093
    • Points 73,065
      Moderator: Meridien
    Not sure on a Mac, but on my machine there's one in C:/Users/hp/Documents/Settings and one in C:/Users/hp/Documents/Avid Users/Carl.
    good luck,
    Carl
  • Mon, Jun 29 2009 12:45 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,008
    • Points 107,215
      Moderator: Meridien
    And from the settings folder, the files to delete are "MC State", "Site_Settings", and "Site_Attributes". On relaunch the system will detect the missing files and build new ones. If you have previously dragged any user settings into the site settings window, those will need to be restored after the rebuild.
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
  • Mon, Jun 29 2009 1:03 PM In reply to
    • switthaus
    • Richmond/Gwynns Island VA
    • Posts 1,071
    • Points 14,280
    certainly try all above and, if you can, delete all the pre-computes from your project and see what happens.  For some reason I have found (as has been noted in other threads of this nature) that most of the time corrupt media tends to be an Avid generated effect or title.
    Scott Witthaus
    Owner/Editor/Post Production Supervisor 1708 Editorial
    www.1708editorial.com
  • Mon, Jun 29 2009 1:06 PM In reply to
    • switthaus
    • Posts 1,071
    • Points 14,280
    biennarc100907:
    Applications>>Avid Media Composer>>Settings
    MC State is the the Settings folder.
    Scott Witthaus
  • Mon, Jun 29 2009 1:08 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,008
    • Points 107,215
      Moderator: Meridien
    switthaus:
    ...delete all the pre-computes from your project...
    Keep in mind that this would include any imported matte key clips as well.
  • Mon, Jun 29 2009 1:09 PM In reply to
    • switthaus
    • Posts 1,071
    • Points 14,280
    which is why I said "if you can..."!
    Scott Witthaus
