Latest post Sun, Jun 28 2009 4:25 PM by cuervo. 2 replies.
  • Sun, Jun 28 2009 2:10 PM
    • cuervo
    • Joined on Fri, May 2 2008
    • Santa Fe, NM
    • Posts 330
    • Points 4,285
    Framerate in Metafuze
    Why does Metafuze limit the framerate options to 24fps? What happens when you transcode a 30fps footage?
    Media Composer 3.5 on Win XP Pro SP3 - Intel x48, dual core quad 6600 - 4Gb RAM - PNY Quadro FX1700 - Echo Mona [view my complete system specs]
    Chalchihuitl Productions Music video, Digital Imaging JVC HD110--Sony EX1
  • Sun, Jun 28 2009 3:35 PM In reply to
    • MichaelP
    • Boston
    • Posts 1,751
    • Points 21,670
      Moderator: Film
      Moderator: MetaFuze
    Re: Framerate in Metafuze
    Right now it is taking it's frame rate from the source material - in v2 it will default to but you can change its frame rate - for example, DPX that has 24fps declared in the header but needs to go to 1080p/25. You will be able to do that. A frame fro frame change will happen. MetaFuze only supports progressive source at this time. I need to check on 30p (29.97).
    Michael
    HP 8600 Symphony Nitris DX v4 || MBP 15" Media Composer v4 [view my complete system specs]
    ____________ Anything 24fps
  • Sun, Jun 28 2009 4:25 PM In reply to
    • cuervo
    • Santa Fe, NM
    • Posts 330
    • Points 4,285
    Thanx Michael. It is 29.97/30P source material that I am asking about.
