Latest post Fri, Jun 26 2009 1:36 AM by sweetmadness. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Jun 25 2009 11:11 PM
    • sweetmadness
    • Joined on Tue, Jun 2 2009
    • vancouver bc
    • Posts 46
    • Points 645
    sound troubles
    I am having sound troubles.  the sound gets distorted over time, and my little sound icon has both disapeared and had an x through it, both in my icon tray and in avid.  however the problem is really only with avid.  i am assuming i dont have a sound card, but rather one integrated on my system.  i will check this.
    in this case is there sound card specs listed somewhere.  i find the knowledge base, quite hard to navigate.  alot of what i find i find from google easier than the avid search on the site!
    any help would be appreciated.
    thanks
    media composer 3.0 ( upgrading today to 3.1.3.2 Windows XP Pro SP3 dell precision 470 work station 2 x dual Xeon 3.2 ghz processors 4 gb ram quadro fx... [view my complete system specs]
  • Thu, Jun 25 2009 11:26 PM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,025
    • Points 25,875
    • Moderator: MCA PC
    Re: sound troubles
    sweetmadness:
    thanks
    Sweetmadness,
    Begin by looking HERE
    Without this information, it is impossible to give you any accurate help on the problems you seem to be having.
    Regards,
    Douglas
    (AMC MojoDX 3.1.2 - XP Pro SP2) + (AMC MojoDX 4.0.2 Vista64 Business SP1),ASUS PK5 DEluxe/WiFi-AP CH1-14 Mobo,Intel Core 2 Duo E6850 (3GHz)8GB Corsair... [view my complete system specs]
  • Fri, Jun 26 2009 12:32 AM In reply to
    • AquaPix
    • Joined on Sat, Sep 16 2006
    • UK
    • Posts 447
    • Points 5,555
    Re: sound troubles
    Members of this forum have always suggested to go with a Soundblaster Audigy card. I too have had good experiences in the past with an Audigy card. I had one in my old workstation and never had any sound issues.
    Having said that, at the moment I am using my integrated onboard soundcard of my ASUS P5K mobo without any troubles.
    MC3.0.5, QT7.4.5, Vista Business x64, Intel Quad Core Q6600 @ 3.4GHz, Asus P5K Mobo, 8GB RAM (OCZ Reaper @ 950MHz DDR II), GeForce 8800GTX (multithreading... [view my complete system specs]
     Andy Lange www.aquapix.tv
  • Fri, Jun 26 2009 12:48 AM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,025
    • Points 25,875
    • Moderator: MCA PC
    Re: sound troubles
    AquaPix:
    Thanks for that, Andy.
    As you can see I am also using an ASUS P5K board (and also using the onboard sound without any noticeable problems)
    However, it brings me back to my initial response - How can we know what Sweetmadness has or hasn't if there is no Profile with System specifications listed.  Smile
    Regards,
    Douglas
  • Fri, Jun 26 2009 12:56 AM In reply to
    • sweetmadness
    • vancouver bc
    • Posts 46
    • Points 645
    Re: sound troubles
    Hey guys,
    I have added the specs to my profile, so you can se what i am using.  Maybe it is compression, but not sure about that.
  • Fri, Jun 26 2009 1:16 AM In reply to
    • AquaPix
    • UK
    • Posts 447
    • Points 5,555
    Re: sound troubles
    sweetmadness:
    Can you elaborate on that? (i.e. what are your projects audio settings, how do you ingest the audio, what do you do with the audio in the Avid?).
    Do you have access to another Avid workstation? You could open your project on the other system and see if the sound is still distorted (then you know for sure that it is your onboard audio.
  • Fri, Jun 26 2009 1:36 AM In reply to
    • sweetmadness
    • vancouver bc
    • Posts 46
    • Points 645
    Re: sound troubles
    I dont' have another system, but i will get more into this tomorrow, and let you more information.
