Latest post Wed, Jul 1 2009 2:37 PM by lordoff2. 5 replies.
Page 1 of 1 (6 items)
  • Thu, Jun 25 2009 7:36 PM
    • autolux
    • Joined on Tue, Jan 15 2008
    • Redwood City Ca
    • Posts 52
    • Points 750
    Importing footage
    Chello
         I'm working in an SD 16:9 show at 29.97 and we have some beautiful animation that is a bit higher resolution (1280x720) as well as being 30fps.  In DS assist everytime I import the file using the 'scale to fit" setting the animation looks bandy and fieldy.  I've turned the field dominace of and on and am getting the same results.  This is an animation of a building so I really wanted it to look as pristine as possible.  I'm assuming its something in the capture settings I'm missing.  Any ideas out there?
    AB
    later.
  • Fri, Jun 26 2009 3:05 AM In reply to
    • slabross
    • Montreal
    • Posts 381
    • Points 3,800
      Moderator: Avid DS
    Re: Importing footage
    Check the online help for the various capture options.
    And may I also suggest that you link instead of importing these larger than your sequence format files?  Then you can use a DVE and specific properties to enhance the image quality.
    If this animation is progressive instead of interlaced, like SD video normally is, you must set the DVE to read these images as frame-based, and you'll get much better image quality after this media has been processed for play back.
    There are also a few filtering options that might help optimize your images.
    Sylvain Labrosse
    Avid DS Product Champion | Video Customer Success
    Avid
    3510 St-Laurent Boulevard
    Montréal, QC H2X 2V2
    Canada
    sylvain.labrosse@avid.com
    We're Avid.  Learn more at www.avid.com
  • Fri, Jun 26 2009 3:10 AM In reply to
    • slabross
    • Montreal
    • Posts 381
    • Points 3,800
      Moderator: Avid DS
    I forgot mentioning that because you use the DS Assist then you are probably monitoring the images on the computer monitor, and not an external video monitor.
    The DS viewer does not do a very good job at correctly displaying interlaced (field) images on progressive computer display, and so do not rely too heavily on this for the final preview.  You must monitor the final show on a hardware equipped DS, or via another application and video hardware.
    Unless your Assist is also equipped with one of the supported AJA monitoring options.
    Sylvain Labrosse
    Avid
    Canada
  • Fri, Jun 26 2009 5:21 PM In reply to
    • autolux
    • Redwood City Ca
    • Posts 52
    • Points 750
    I tried linking the clip in assist and the option isnt event present when I rick cllick on the clip.
    AB
    later.
  • Sat, Jun 27 2009 3:46 PM In reply to
    • dermot
    • Vancouver, Canada
    • Posts 36
    • Points 380
    I'm guessing the file is Qt?
    If so then linkng is not possiable in X64...
    A (somewhat ugly) workaround would be to import it into a custom (1280x720) project , export as a file seq (DPX for example), and then link to the DPX, and then go on as per Sylvain's suggestions...
    d.
    8600 - 3700 - AJA 2Ke - u320 array - Dream Color [view my complete system specs]
  • Wed, Jul 1 2009 2:37 PM In reply to
    • lordoff2
    • Joined on Mon, Jun 9 2008
    • Sofia, Bulgaria
    • Posts 14
    • Points 180
    I use similar workflow for linking QT in X64.  Most of the case, convert first with TMPGEncoder (batch processing!!! Smile ) in TIFF seq. then link to DS.
    Not bad for me: it's work, only a litlle more time for preparationSmile
    Avid DS Nitris v.10.1.1 / xw8400 / Unity 5 / DS RP station [view my complete system specs]
