Latest post Wed, Jul 8 2009 5:45 AM by mjolnarn. 41 replies.
Page 1 of 3 (42 items) 1 2 3 Next >
  • Thu, Jun 25 2009 6:19 PM
    • grovechuck
    • Joined on Wed, Sep 13 2006
    • Coconut Grove, Miami
    • Posts 54
    • Points 825
    WMV>Sorenson>Avid- recommend Sorenson settings?
    Hi All,
    Client has WMVs (Arrrrgh!!!)
    I know I have to convert them to QTs in Sorenson.
    Could anybody recommend Sorenson settings ( 1 or 2 pass, VBR or CBR, Bitrate?) for best quality?
    Final product will be projected as WMV
    Is there ANY way this will look good in the end? (sigh...)
    And as long as I'm asking, best WMV settings for projection?
    thanks very much,
    Chuck
    MC 2.8 w Mojo/ xw8200/3.2 GHz Xeon/4GB DDR2 RAM/160GB SATA boot/500GB internal SATA/FX 1400/ XP Pro SP2, and a '63 Telecaster [view my complete system specs]
    ...EVERY Picture Tells A Story... Don't It?
  • Thu, Jun 25 2009 6:29 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 3,108
    • Points 35,520
    Re: WMV>Sorenson>Avid- recommend Sorenson settings?
    Wmv,s are all from highspeed very good looking Vc1 Hd files and down to something that not even the cat would like to have, what are the bitrate and resolution of the clips you are going to convert.
    MC 4,03 ( Liquid 7,2 ) V 64 Ultimate Mbo gigabyte 965-DQ6,cpu quad core QX 6700, mem Corsair Dominator 8500 8 GB, PNY Quadro 1800, Soundblaster X-Fi... [view my complete system specs]
    Tomas
  • Thu, Jun 25 2009 6:45 PM In reply to
    • grovechuck
    • Posts 54
    • Points 825
    It's 720x480, doesn't show bitrate in Media Player.
    Where else could I find it?
    :40 seconds, 30MB.
    Thanks!
  • Thu, Jun 25 2009 7:16 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 3,108
    • Points 35,520
    The easiest way is to just look at " properties " in media player while the clip is running, there are also special apps that are telling you all about your clips.
    Seems to be good hispeed clips by the way.
    Tomas
  • Thu, Jun 25 2009 10:35 PM In reply to
    • grovechuck
    • Posts 54
    • Points 825
    Anybody please?
    Suggested Sorenson Settings???
    WMV to QT?
    And back to WMV???
    Thanks!
  • Thu, Jun 25 2009 10:46 PM In reply to
    grovechuck:
    :40 seconds, 30MB.
    That is about 8000k for a bit rate.... if video only.
    Set a similar rate for your QT from Sorenson and again when going back to WMV.
    I would probably use a MJPEG B QT codec in Sorenson for getting the file to Avid
    Thanks for the continued dongle support
  • Thu, Jun 25 2009 11:10 PM In reply to
    • grovechuck
    • Posts 54
    • Points 825
    Thanks for the reply Andrew!
    I'd never even heard of/used MJPEG B QT!
    Found it (Apple Motion JPEG B, right?) in Sorenson.
    It defaults to 1 pass CBR, I can't set the bit rate, is that OK?
    I tried it, but didn't get audio.
    The WMV has Sonic Cinemaster mce audio decoder audio codec, is that relevant?
    In Sorenson (WMV> QT) I'm using MPEG-4 audio codec.
    Suggestions?
    Thanks in advance!!!
  • Fri, Jun 26 2009 1:05 AM In reply to
    • AquaPix
    • Joined on Sat, Sep 16 2006
    • UK
    • Posts 447
    • Points 5,555
    To not loose any quality I'd select the Avid QT 1:1 codec, if quality is an issue, if not, the MJPEG B QT is a good option too. The file size will be huge though bif you select 1:1.
    Regarding the audio, do you have sound when you play the wmv file in Windows Media Player?
    You definitely need the right audio codec on your machine to make it work.
    Just Google "Sonic Cinemaster mce audio decoder audio codec" and I am sure you'll find a wealth of information.
    MC3.0.5, QT7.4.5, Vista Business x64, Intel Quad Core Q6600 @ 3.4GHz, Asus P5K Mobo, 8GB RAM (OCZ Reaper @ 950MHz DDR II), GeForce 8800GTX (multithreading... [view my complete system specs]
     Andy Lange www.aquapix.tv
  • Fri, Jun 26 2009 2:29 AM In reply to
    • grovechuck
    • Posts 54
    • Points 825
    Thanks Andy, I'll try 1:1, see how the quality/size compares.
    I do want best quality here.
    The WMV has audio. AndrewAction suggested 2 encodes; one for audio, one for video.
    I'll look for the Sonic codec, not quite sure how to install it in Sorenson if I find it though...?
  • Fri, Jun 26 2009 3:08 AM In reply to
    • AquaPix
    • UK
    • Posts 447
    • Points 5,555
    I have the ffdshow codec pack installed on my system. It is freeware, so won't cost you anything!
    Once the pack is installed, Sorenson should be able to utilise the codec.
    Regarding the audio, I suggest you use "wave 16bit uncompressed", in the QT options tab in Sorenson..
    Whether you choose to encode audio and video in separate files, or embed the audio in the QT file shouldn't really matter. The resulting files should fast import in MC.
  • Fri, Jun 26 2009 3:51 AM In reply to
    • grovechuck
    • Posts 54
    • Points 825
    The ffdshow pack is audio and video codecs?
    Is Sonic Cinemaster part of it?
    I'm not at my Avid now, but I'll definitely check it out!
    Thanks Andy!
    Chuck
  • Fri, Jun 26 2009 4:02 AM In reply to
    • grovechuck
    • Posts 54
    • Points 825
    Andy, Is the download a Marine Screensaver?
  • Fri, Jun 26 2009 4:51 AM In reply to
    • AquaPix
    • UK
    • Posts 447
    • Points 5,555
    grovechuck:
    No it isn't. The link worked earlier ...sorry!
    Try this one instead http://ffdshow.en.softonic.com/.
  • Fri, Jun 26 2009 5:39 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 3,108
    • Points 35,520
    Although Andrews settings might work, I would also use Avid 1.1 for video and a wav file 16 - 48 for sound, as Andy already has said, to get the highest possible quality, this seems to be files that could have good quality.
    The audio encoding settings from Squeeze might even be called " little endian "
    As the files are playing with audio from wmp , you seem to have the correct audio codecs on your sys, are they also playing with sound from inside of Squeeze?
    Have you tried to import them directly into Avid, works with 3,5 and most wmv files, don´t know if it came after your version of 2,8 or not but might be worth a try.
    ( Edited my post a little after my first morning cup of coffee )
    Tomas
  • Fri, Jun 26 2009 6:33 AM In reply to
    • grovechuck
    • Posts 54
    • Points 825
    Thanks guys!
    I've been busy downloading NINETY WMVs!!!
    50- 200MBs each!!!    AAAAARRRRGGGHHHH!!!   ahhh...i feel better  ;^)
    After I converted the WMV to QT (JPEG B) I got no audio, but the WMV WOULD play audio in Sorenson.
    I'll try 1:1, though I am a little worried about file size.
    No. I can't import the WMVs directly into Avid.... MOST unfortunately.
    I guess you (Tomas?) have gone to sleep and woken up while I've been working on this! I could use some coffee, too!
    Thanks everyone for your help, you've been most generous with your time.
    I'll report back tomorrow. (my tomorrow, your tonight?)
    Cheers!
    Chuck
