Latest post Thu, Jun 25 2009 6:49 PM by general_failure. 4 replies.
  • Thu, Jun 25 2009 4:30 PM
    Avid Pan and Zoom
    I am trying to make a picture I cropped out in photoshop move around using the Pan and Zoom effect, on a map i imported into Avid. Everytime I try to do it though, it has a white background. Is there anyway to just use the portion of the picture I cropped out? I saved it as a PSD without a background. If I just lay the picture on a seperate video track abpve my map, it does not have a background, but I can't move the picture around. With the Pan and Zoom feature it always has a background.
    Dell Precision T3400 Intel Core 2 Duo CPU E6850 @ 3.00GHZ 4.00GB RAM Windows Vista Business SP1 32 Bit OS NVIDIA Quadro FX 1700 SoundMax Integrated... [view my complete system specs]
  • Thu, Jun 25 2009 4:43 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,003
    • Points 107,150
      Moderator: Meridien
    Re: Avid Pan and Zoom
    In the effects editor when using Pan and Zoom, in the background fast (hamburger) menu, choose "Video" instead of "Color".
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
  • Thu, Jun 25 2009 4:45 PM In reply to
    Assuming you have saved the PSD without a background (just the checkerboard), import the psd using the following settings: Image Size = Maintain Square, Color = RGB, Field dominance = None/Progressive, Alpha = Invert existing.
    Edit the image into your sequence. Open the effect editor and promote the alpha matte to 3D. Now you can animate your picture using keyframes.
    Hope that's a solution for you, g_f
    [EDIT: or do it Larry's way! Stick out tongue Sometimes one thinks of complicated solutions when there are easy ones...]
    Dell Precision m6400, Intel QX9300 2,5GHz Quadcore, nVidia QuadroFX 3700@1GB, 4GB RAM, M-Box2, MC 3.5.1 Software Only, ProTools LE 8cs2, WindowsXP 32bit... [view my complete system specs]
  • Thu, Jun 25 2009 6:36 PM In reply to
    Many Thanks g_f! I was looking at it all the wrong way...I did not know you could move a picture using keyframes without using the Avid Pan and Zoom...
    Thanks again
  • Thu, Jun 25 2009 6:49 PM In reply to
    Cool Glad I could help you. But also keep Larry's suggestion in mind that you can alter the background in a P'n'Z effect, maybe you will need just that at some time.
    Regards, g_f
