Latest post Sun, Jun 21 2009 5:49 PM by Randall L Rike. 26 replies.
Page 1 of 2 (27 items) 1 2 Next >
  • Sat, Jun 20 2009 8:19 PM
    • editgirl1
    • Joined on Sun, Apr 12 2009
    • NY
    • Posts 21
    • Points 235
    HELP EXPERTS! Playback stuttery and error. Just digitzed, no edits yet SONY HVR
    If anybody can quickly help with this what I think maybe simple hopefully.
    footage was shot on the sony HVR-Z1U in 1080i 60i. I digitized project format of 1080i/59.94.  dropped a couple of clips on the timeline. Wont playback only audio. Then get a error as follows:
    Exception  DecompStream: PostOp wait timed out for locate stream 0
    Please advise. My first time cutting footage from a SOny. always had Panasonic HD footage. Is there something that Im doing wrong? I dont see what I havent even started editing yet!!!
    Pleeeeeeeaaaassssse help Editgirl :(
    Laptop: HP Pavillion dv6000 series. Windows XP SP2, Core 2 Duo T5450 @ 1.66 GHz, 3gb Ram, Nvidia 8400M GS, internal SATA Drive, Avid Media Composer 2.8... [view my complete system specs]
    " You can always get back what was lost except time wasted, so what are you waiting for"
  • Sat, Jun 20 2009 8:34 PM In reply to
    • jknikman
    • Leiderdorp - NL
    • Posts 3,461
    • Points 39,230
    Re: HELP EXPERTS! Playback stuttery and error. Just digitzed, no edits yet SONY HVR
    What version of MC? You might need an upgrade! Version of QT?
    Dell Precision 670, Xeon 3Ghz 3GB Memory 1 x 250 systemdisk, Gb 2x500 Gb datadisks, 2x 1Tb datadisks, Soundblaster Audigy, Quadro FX 1400, MC 3.5.1, Mojo... [view my complete system specs]
  • Sat, Jun 20 2009 8:46 PM In reply to
    • editgirl1
    • NY
    • Posts 21
    • Points 235
    Thank you for your prompt response!!! My version is Media composer 2.8. OT  I believe is 7..
    A friend said I may have to defrag drive?? make sense to you?
  • Sat, Jun 20 2009 8:58 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,995
    • Points 107,070
      Moderator: Meridien
    NEVER EVER defrag any of your media drives! Avid deliberately breaks files into fragments which it spreads across a drive, partition, or RAID drive array, hence the "Initializing Media Streams Manager" stage of the boot up. According to the version matrix, you should be running Quicktime version 7.3 and NVIDIA graphics card driver 91.85. Please confirm.
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
  • Sat, Jun 20 2009 9:13 PM In reply to
    • editgirl1
    • NY
    • Posts 21
    • Points 235
    Confirmed. wow.. ok I didnt attempt that process. So I will download 7.3. however, the Nvidia card driver is appropricate for the my card? 8400MGS. im working off XP in which I downgraded from Vista using capitable drivers because most manufacturers stop [producing the drivers for XP with the newer laptops...
    So shall I install the Nvidia card driver?
  • Sat, Jun 20 2009 9:20 PM In reply to
    • editgirl1
    • NY
    • Posts 21
    • Points 235
    now that im double checking i do have QT 7.3!! what shall i do now about the error playback?
    this project has to show tomorrow :(. i dont know what im going to do
  • Sat, Jun 20 2009 9:23 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,995
    • Points 107,070
      Moderator: Meridien
    OK, there's a problem. The 8400MGS is a GE Force card, and on the PC side of Avid, a Quadro is required. Although, some users have found a way to force a GE to emulate a Quadro. But in any event, you need to run the EXACT driver and QT versions that Avid specifies for your version of MC, which are NOT necessarily the newest. So install the driver version indicated in the version matrix.
  • Sat, Jun 20 2009 9:33 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,995
    • Points 107,070
      Moderator: Meridien
    And for your reference, here are the system requirements for Media Composer.
  • Sat, Jun 20 2009 9:40 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,995
    • Points 107,070
      Moderator: Meridien
    Here are the standard things to do when encountering these types of problems.
    1) Is the problem only occurring in a specific project, but not others, or a newly created project? If so, the "(Project Name)settings.avs" file may be corrupted. Go into the specific project folder and delete that file. On re-launch the system will detect the missing file and build a new one.
    2) Rebuild the site settings files, they may have become corrupted. To do this, quit the app, and from the settings folder, delete the following: MC State, Site_Settings, Site_Attributes. On re-launch, the system will detect the missing files and build new ones. If you have previously dragged any user settings into the site settings window, those will need to be restored after the rebuild.
    3) Create a new user profile and see if the problem persists. It is not uncommon for corrupted user files to create bizarre problems in the interface.
  • Sat, Jun 20 2009 9:42 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,995
    • Points 107,070
      Moderator: Meridien
    And if none of the above help, you can try re-cycling the power on all your hardware and your Sony deck, then do a batch re-capture of your clips again.
  • Sat, Jun 20 2009 9:55 PM In reply to
    • editgirl1
    • NY
    • Posts 21
    • Points 235
    Thank you Larry for the informative answers. I am fully aware of Avid required Specs, however, I dont meet half of them due to unaffordale reasoning at the time of purchasing my system.
    I will download the appropiate drivers, however, I could not get 7.3 I realized I have 7.5  according to the version file that read on one of the QT installs. When searching for JUST 7.3 it keeps bringing me back to the newest QT version 7.62..
    I will attempt to delete settings files etc. And to answer your questions, No this hasnt happen to any projects ever since cutting ont his laptop for 2 years. Always p2 footage and goes smoothly. And yes this is a NEw Created project. An edit hasnt started yet just the digitizing process. Will report back with update. thanks again.
  • Sat, Jun 20 2009 10:04 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,995
    • Points 107,070
      Moderator: Meridien
    You can download 7.3 from here.
  • Sat, Jun 20 2009 10:07 PM In reply to
    Also, it may be simply a "play pipe" issue.  Try powering everything down, then power up only your laptop - leaving the deck off.  Does that work better?
    The deck uses a lot of your computer's resources when it's on, even though it may not be "doing anything".  That could be causing your issue.
  • Sat, Jun 20 2009 10:09 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,995
    • Points 107,070
      Moderator: Meridien
    Good point, Kenton. Please do as he suggests.
  • Sat, Jun 20 2009 10:36 PM In reply to
    • editgirl1
    • NY
    • Posts 21
    • Points 235
    actually guys sorry for the misunderstanding but Im NOT using a Sony deck. I digged footaged right from the Sony HVR-Z1U cam. Yesterday. AL files are deleted as suggested. Im about to install the other QT version and card and lets see what happens. You know I have 3.0 I never upgraded due to being in between projects all the time. Maybe I should go with 3.0 uh?
