Latest post Sun, Jun 21 2009 5:14 PM by Joachim Claus. 5 replies.
Page 1 of 1 (6 items)
  • Sat, Jun 20 2009 12:32 AM
    • Strider
    • Joined on Fri, Sep 1 2006
    • Los Angeles
    • Posts 100
    • Points 1,485
    Software to convert a Quicktime to MPEG2 & AC3 files?
    What software do you recommend to convert a quicktime to MPEG2 & AC3 audio? I would export as a Quicktime with no compression (HD edit 1920 X 1080i) convert to MPEG2 & AC3 and then turn it over to be transmuxed.
    I have the transmuxing software but nothing to just simply be able to convert to the file to MPEG2 & AC3.
    Strider
    Intel(R) Xeon(R) CPU 5130 @ 2.00GHz 2.00Ghz, 3.00GB of RAM [view my complete system specs]
    STRIDER
  • Sat, Jun 20 2009 1:40 AM In reply to
    Re: Software to convert a Quicktime to MPEG2 & AC3 files?
    TMPGenc   Cheapest. I have had some problems with it for HD to SD MPEG in PAL
    Sorenson comes with MC or possibly as a $295 (?) Third party add on package with BCC package from Avid
    ProCoder 3
    Adobe media Convertor (Part of CS4)
    Directly in Avid DVD
    Thanks for the continued dongle support
  • Sat, Jun 20 2009 2:57 AM In reply to
    • Strider
    • Los Angeles
    • Posts 100
    • Points 1,485
    Hi, and thanks Andrew,
    Have you ever done this just directly with Avid DVD? If so would you be able to run me through it or tell me how. I don't see any options for this when I try.
    Thanks, Strider
    STRIDER
  • Sat, Jun 20 2009 3:21 AM In reply to
    I am fairly sure there is a Douglas tutorial on this workflow.
    My use of Avid DVD with HD source was to a Blu Ray disk. By choice I uses a HD QT ref file from Avid and ProCoder or Sorenson for the downconvert to SD MPEG 2 and AC3..
    If you have Avid DVD is it a fair assumption you have Sorenson? The latest version of SS seems to have speeded up the encode considerably
  • Sun, Jun 21 2009 12:03 PM In reply to
    • indigospin
    • Lubbock, Texas, USA
    • Posts 455
    • Points 5,080
    i use sorenson for mpeg2 with truly great results, though i don't think the version that ships with MC has an AC3 codec.  i think the very newest version of sorenson does have this.
    here is a link to a free WAV to AC3 encoder that i've used with great results.  its easy to use & runs right out of a folder on your desktop, no installation required.  http://www.softpedia.com/get/Multimedia/Audio/Audio-CD-Rippers-Encoders/WAV-to-AC3-Encoder.shtml
    shane
    ASUS P6T Delux MOBO, Intel core i7 2.93GHz, 3 GB RAM, Windows XP Pro SP3, NVIDIA QuadroFX3500 (driver 169.47), 4 TB of storage on 6 SATA drives... [view my complete system specs]
    staffer: "How do you go without sleep for so long?"  me: "Not nearly as well as I used to."
    indigospin.com
      <--Click to check out our online portfolio of more than 20 sample videos!
  • Sun, Jun 21 2009 5:14 PM In reply to
    • Joachim Claus
    • Seeheim-Jugenheim, Germany
    • Posts 185
    • Points 2,245
    I use TMPGEnc 4.0 Xpress with best results. It is available as demo version. So you can try it and see the results, befor you buy.
    Jaochim
    SuperMicro Workstation 7046A-3 Dual Xeon (Quadcore) X5550 2.67GHz 12 GB RAM PNY FX1700 Soundblaster Audigy 2 ZS Pro 4 SAS HDD's 300GB 15k (1 for OS... [view my complete system specs]
    Joachim Claus
