Latest post Sun, Jun 21 2009 10:35 PM by lawsonr. 1 replies.
Page 1 of 1 (2 items)
  • Fri, Jun 19 2009 3:05 PM
    • Extend
    • Berlin
    • Posts 15
    • Points 165
    BUG? Modify masterclip source / TC doesn't work properly in MC 3.5
    I digitised some HDV material with the wrong tape selected in the capture tool
    No problem - I thought I'd just alter the tape using the Modify... Source option, as in XPro.
    But when I change the tape, the TC of the masterclip also changes. 17 frames are added onto it.
    When I then try to change the starting TC back to the old one, again using the Modify option, nothing happens. That also used to work in XPro.
    The same thing happened with a number of masterclips.
    This is obviously bad news, should I need to rebatch clips in the future. The most I could do was add a reminder in the comments column of my bin...
    MC 3.5.4; Analogue Mojo; Win XP SP2; Intel Core 2 Quad Q9650; Gigabyte GA-EP45T-Extreme; 8GB Dual Channel DDR3 RAM; Quadro FX 1700; Matrox Dualhead Digital... [view my complete system specs]
    Filed under: ,
  • Sun, Jun 21 2009 10:35 PM In reply to
    • lawsonr
    • Joined on Thu, Jun 8 2006
    • CBS News
    • Posts 229
    • Points 2,745
    Re: BUG? Modify masterclip source / TC doesn't work properly in MC 3.5
    17 Frames?
    What is the duration of the clip you tried to modify? Was the source logged as drop or non-drop-frame timecode?
    Avid NewsCutter 7.1.1, ISIS 1.6, Interplay 1.5. [view my complete system specs]
