Latest post Fri, Jun 19 2009 5:01 AM by mrmikster. 5 replies.
Page 1 of 1 (6 items)
  • Thu, Jun 18 2009 6:46 PM
    • autolux
    • Joined on Tue, Jan 15 2008
    • Redwood City Ca
    • Posts 52
    • Points 750
    how to delete a keyframe?
    I've keyframed some basic camera moves and gain controls for a show and I usually do most any keyframing in AE.  How do I delete keyframes from effects?  Is there a button?  I dont get the option when I right click so I'm imagining there is some secret way of doing it I cant figure out.  Any ideas?
    AB
    later.
  • Thu, Jun 18 2009 6:51 PM In reply to
    • AKA Dave
    • Joined on Mon, Dec 3 2007
    • Posts 41
    • Points 490
    Re: how to delete a keyframe?
    I'm not sitting in front of my AVID at the moment but if I remember correctly, click the keyfrme you want to delete to highlight it and then hit the delete key.  It might be backspace, but I think it's the delete key.
    Dave
    Dell M6400, Windows 7 Pro-64bit, 2.66MHz T9550, NVIDIA Quadro FX 2700M, 4gig RAM, Mojo SDI, External RAID and internal 2nd HD - Nitris DX on HP 8600. [view my complete system specs]
  • Thu, Jun 18 2009 6:55 PM In reply to
    • autolux
    • Redwood City Ca
    • Posts 52
    • Points 750
    the delete key removes the whole effect from the clip, and the backspace key does nothing for me
    AB
    later.
  • Thu, Jun 18 2009 7:24 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,992
    • Points 107,005
      Moderator: Meridien
    AB
    You must be in the effects mode. Park on the appropriate keyframe in the keyframe timeline and highlight it, so it is the only one that is purple, then delete.
    {EDIT} Oops. Just noticed this is the DS Forum. My procedure may or may not work.
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
  • Thu, Jun 18 2009 7:46 PM In reply to
    • Tommyp
    • Joined on Wed, Jan 25 2006
    • Southfield, MI
    • Posts 7
    • Points 95
    You are asking for DS right? the answers you were getting were for MC.
    So in DS -
    When you have your effect property editor open, you can right click on the picture of the key in the upper left hand corner of the property editor, then select "Remove Animation".
    If you only want to delete a single key frame, make sure you are parked on the keyframe you want to delete, right click and select "remove key"
    You can navigate to the keyframes using the arrows next to the same key pic on the property editor.
    HTH,
    Tom
  • Fri, Jun 19 2009 5:01 AM In reply to
    • mrmikster
    • Los Angeleez
    • Posts 353
    • Points 3,945
    • Moderator: Avid DS
      Moderator: MetaFuze
    And to add another option. If you only want to delete a keyframe for one parameter, right click on the divot by the slider, and delete keyframe.
    "There are no rules for the brave". Albert Einstein
