Latest post Sat, Jun 20 2009 1:06 AM by John Moore. 4 replies.
  • Thu, Jun 18 2009 3:17 AM
    • Ra-ey Saleh
    • Sydney, Australia
    • Posts 581
    • Points 6,925
    Couple of issues in 3.5 (actually 3.5.1.3)
    I've noticed a couple of things and wondered if anybody else has seen anything similar...
    1)  When you go into Trim modein a HD project the Video Quality flips to Draft Mode (whether you were in Full Green 8 or 10bit).  It flips back when you go back to Source/Record.  Not the end of the world, just weird.
    2)  When I try and auto-configure a deck I get an NTSC drop/non-drop frame error.  Which is weird as I'm working in Pal.  I have to manually configure the deck.  This is working in HD (1080i/50).
    Ra-ey
    HP 8600 Symphony Nitris DX v4.0.2 Sapphire v2.081 Boris Continuum Complete v5.0.4 AvidFX (Boris Red) v5.8 Heroglyth v2.6 Vitascene v1 Adrenaline... [view my complete system specs]
  • Thu, Jun 18 2009 10:40 AM In reply to
    • John Moore
    • Joined on Fri, Feb 3 2006
    • Burbank, CA
    • Posts 144
    • Points 1,615
    Re: Couple of issues in 3.5 (actually 3.5.1.3)
    Could the trim behavior be controled by the setting that decides whether the render on the fly is on or off when in trim mode?  Just a thought I'm on an SN classic right now with 3.0.5 so I can't tinker.
    Symphony Nitris 3.1.1 [view my complete system specs]
    John Moore Barking Trout Productions bigfish@pacbell.net
  • Thu, Jun 18 2009 9:21 PM In reply to
    • Abeyta
    • Phoenix
    • Posts 109
    • Points 1,330
    Ra-ey Saleh:
    Yeah, I'm seeing this too on a Mac Symphony DX v3.5 system. I didn't notice it till you mentioned it though.
    Mac Pro 8 Core 3.0ghz, Symphony Nitris DX 3.5, 5GB RAM, OS 10.5.6, AvidVideoRaid 2.5 TB, Atto UL5D, dual Apple 23 cinema, HDCAM HDW-D1800, BETA SP UVW... [view my complete system specs]
    Derrick Abeyta | Blu Pixel
    Phoenix, Arizona
    www.blupixelpost.com
  • Thu, Jun 18 2009 11:50 PM In reply to
    • Ra-ey Saleh
    • Sydney, Australia
    • Posts 581
    • Points 6,925
    John Moore:
    Interesting, this was turned off (since when has it been in here?), but didn't effect the result.  Maybe this is a new 'feature'.
  • Sat, Jun 20 2009 1:06 AM In reply to
    • John Moore
    • Burbank, CA
    • Posts 144
    • Points 1,615
    No it's been around quite a while.  I think I really started to notice it's impact when the color correction method of meridian was changed to an effect based nature, even though the green line etc... act the same.  At the time of the switch over when I'd go into trim mode the color correction would disappear because it was now an effect to be rendered on the fly.  Turning that on makes the color correction appear also some effected clips will just go black without render on the fly in trim mode on.  Back when processing was at a premium it must have been used to make trim mode more responsive.
