Due to a virus, I need to install a Windows patch on both SystemDirectors, which is fully supported by Avid. But, I want to make a metadata backup, just in case...
Where can I found the file/s?
Thank you!
Your total metadata is not on the SD- only partial, some is on the storage.
What patch- I may have already done it. And- in a 2 SD environment, you can patch the standby, fail over, then patch the new "standby"
JDS
That´s what I wanted to do: patch the standby one, trigger a failover, then work again on the current standby. If the patch is supported, nothing should happen.
The MS Windows patch is "KB958644" (Google it). It prevents remote code execution; what makes me doubt about the installation is the fact that MS doesn´t seems to provide a Windows XP Embedded version of the patch, just SP1, SP2, etc.
That´s why I want to backup my metadata before doing something I can regret.
So, again, how can I backup my SysDir metadata? and do you have any info about this patch?
Thank you in advance.
D: program files / Avid /Avid Unity ISIS/
Get partition0, Partition1, Partition dump.bin
Back it up, but only use in case of a failure- you should have no problems putting the patch in. I put it in last fall, with no problems.
