Latest post Thu, Jun 18 2009 6:01 PM by Larry Rubin. 5 replies.
Page 1 of 1 (6 items)
  • Tue, Jun 16 2009 12:30 PM
    • bala0406
    • Joined on Tue, Jun 16 2009
    • Posts 2
    • Points 30
    AUDIO CRACKLING
    I have installed MC 3.5.1 with SDI Mojo on Vista 64bit Bussiness and i can import the clips with out any problem but if i try to play the clip i get audio crackling and in the console window it shows an error vsync and dport error. I use Dell Precession T 7500 work station with 6gb ram and Nvidia 3700 graphic card. My OS drive is a SATA drive. can some one help me on this.
  • Wed, Jun 17 2009 7:54 AM In reply to
    • jakeheat
    • Joined on Sun, Sep 3 2006
    • Posts 152
    • Points 1,820
    Re: AUDIO CRACKLING
    Double check the audio sample rate of your imported clips against the set sample rate and bit depth for you project.
    If it's different, you may want to transcode your audio media to the project settings.  In fact even if it's not, you might want to just test whether re-transcoding your media solves this problem.
    good luck
    SYMPHONY NITRIS 3.5.4 HP xw8400 QT 7.6 Vista 64 ADRENALINE 3.5.1 PC HP xw8400 XP MC SOFT 4.0.2 PC HP xw8400 - & MacPro 3Ghz Quad OS 10.5.8 QT 7.6.2... [view my complete system specs]
  • Wed, Jun 17 2009 10:24 AM In reply to
    • bala0406
    • Posts 2
    • Points 30
    Re: AUDIO CRACKLING
    I have tried transcoding and re-transcoding but dint help. If i play the audio in 1394 its working fine and if i switch it on to DNA only i have this problem.
  • Thu, Jun 18 2009 4:15 PM In reply to
    Re: AUDIO CRACKLING
    we've had one box that the audio gets crackly on playback after switching to and from dv.  cycling the power on the bob usually corrects the problem.  it is only on playback, there is acutally no problem with the files.  kind of strange, but it seems to relate back to dv based material for us.
    hp xw8200, 4 gig ram, fx1400 video, 8 rs146, 4 gig fibre unity, MCAHD 2.2.15, beta sp & sx, xdcam soon to include hd and ex, dvcpro, minidv. [view my complete system specs]
  • Thu, Jun 18 2009 5:12 PM In reply to
    • Sasquatch
    • Nottingham England
    • Posts 561
    • Points 6,705
    Re: AUDIO CRACKLING
    It uesd to be the case that you trashed the digi setup preferences every week on the old MC 6 on our mac  back in the day, has Avid come a full circle?
    HPXW8400 4gb ram Nvidia FX 1500 MC 4 Adrenaline, HP XW8200 3gb ram Nvidia FX1400 MC 3.5 with SDI mojo, Avid express DV. [view my complete system specs]
    Mike Kruft. Nottingham, UK
  • Thu, Jun 18 2009 6:01 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,003
    • Points 107,150
      Moderator: Meridien
    Re: AUDIO CRACKLING
    audiodaddy:
    If this happens after capturing material from tape, it will be recorded into the captured audio. You then must re-cycle the power on the BOB and re-capture the affected media. This problem pops up once in a while here. Re-cycling the power solves it every time.
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
