Latest post Tue, Jun 16 2009 8:46 PM by kutter. 2 replies.
  • Tue, Jun 16 2009 2:43 AM
    • kutter
    • Joined on Sun, Jun 17 2007
    • Phoenix, Arizona
    • Posts 74
    • Points 910
    System Crash
    Can anyone tell me if Quicktime 7.3.1 is compatible with
    Symphony Nitris 1.8.3? I checked the readme, it says 7.3.
    I am having some trouble inside Avid. I get errors while
    trying to export ANY qt except Quicktime Reference. After I
    select the file for export (regardless of length) and then
    pick format, the 'Video Compression Settings' window opens
    and then this message appears:
    An ACCESS_VIOLATION exception occurred.For more
    information see the error log: C:\Program Files\Avid\
    AvidSymphony Nitris\AvidFatelErrorReports\
    Exception_2009.06.15_10.30.34.
    Then, the system crashes to the desktop.
    I've tried uninstalling - reinstalling. I have also upgraded
    to QTPRO.
    Any suggestions would be gratefully appreciated.
    Kent
    hp workstation xw8200, SP2, 4 gbs ram, 3.40ghz, Symphony Nitris 1.8.3, XP Pro, QT 7.3.1 MCSoft 3.0.1 Apple G5 dual 2.0 O. S. x 10.4.11 ... [view my complete system specs]
    Kent Kreiger
    ACI
    Kreiger Post - Metropolitan Post
    http://www.kreigerpost.com
  • Tue, Jun 16 2009 6:27 PM In reply to
    • jakeheat
    • Joined on Sun, Sep 3 2006
    • Posts 150
    • Points 1,810
    Re: System Crash
    No, I think you're on the right version of QT.  I think you just need to change your QT preference settings. Go to:
    Edit>Preferences>Quicktime Preferences" click on the "Advanced" and set the "video" to "safe mode (GDI only).
    I think your having the same issue addressed here:
    http://community.avid.com/forums/p/68205/381645.aspx#381645
    SYMPHONY NITRIS 3.5.4 HP xw8400 QT 7.6 Vista 64 ADRENALINE 3.5.1 PC HP xw8400 XP MC SOFT 4.0.2 PC HP xw8400 - & MacPro 3Ghz Quad OS 10.5.8 QT 7.6.2... [view my complete system specs]
  • Tue, Jun 16 2009 8:46 PM In reply to
    • kutter
    • Phoenix, Arizona
    • Posts 74
    • Points 910
    Re: System Crash
    THAT WAS IT!!!!!! Thanks so much!
    Kent
    jakeheat:
    Kent Kreiger
    ACI
