Latest post Thu, Jan 21 2010 3:09 AM by Ra-ey Saleh. 30 replies.
Page 2 of 3 (31 items) < Previous 1 2 3 Next >
  • Thu, Oct 1 2009 2:26 AM In reply to
    Re: Wacom Intuos4 drivers conflict with Avid... still
    Oh man. I am now running MC 4.0.2 with the new Sept 29 released Intuos 4 driver (612-3). Same problem. Anyone have any luck?
    HP XW-8600 Quadcore 3GHz 5450 Xeon(Harpertown) 4 GB RAM Nvidia Quatro FX 1700 Windows XP SP3 (32-bit) Media Composer 4.0.2 [view my complete system specs]
    Trevor Hyslop day18.com
  • Thu, Oct 1 2009 11:41 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 2,173
    • Points 28,865
    There was such promise. A new MC and a new Wacom driver.... Two new releases and two fingers pointing at each other Stick out tongue
    What about that mark-in fix noted earlier - does that work for you?
    Camera(s) Sony HDR-FX1, Canon HV20 | MC 4.0.5 | QT 7.6.2 | Vista 64 Ultimate SP2 | System: P5W-DH QUAD QX6700 (2.66GHz clocked to 3.2GHz), 8GB RAM (800MHz... [view my complete system specs]
    Steve
  • Thu, Oct 1 2009 8:44 PM In reply to
    Maybe Windows 7 is our next hope. The mark in/mark out function didn't correct anything for me.  I haven't run into this issue on OSX though. Avid/Final Cut seem to work perfectly with the Intuos4 on a Mac.
  • Tue, Oct 20 2009 3:46 PM In reply to
    • Geoffs
    • Joined on Mon, Oct 19 2009
    • Brisbane, Australia
    • Posts 13
    • Points 135
    I'm another frustrated intuos 4 tablet user. The Mark in/out thing works for me. But that can only get you so far. It's pretty dissapointing. I'm running Vista and windows 7 with the same issues.
    The tablet works perfectly everywhere else.
    Man-o-man I hope this gets resolved soon. $500 bucks wasted on a tablet isn't my idea of a good time.
    EDIT* Well something worked, but it seems it was only temporary. Mark in/out doesn't seem to work anymore.
    Bah!
    Windows 7/ Vista Dual boot i7 920 6 gig-o-ram 285 GTX Video Card [view my complete system specs]
  • Tue, Oct 20 2009 5:38 PM In reply to
    • Adman
    • Atlanta Georgia, USA
    • Posts 4,391
    • Points 49,305
    • BlogAuthor
      Moderator: Avid Free DV
      Moderator: Avid Xpress DV PC
      Moderator: Avid Xpress Studio
    Great... my old Wacom tablet pen died and I just installed a new Wacom Intuous4... it is awesome for Corel Painter, fwiw... complaining to Wacom...
    Dell Precision 650, 3.06 Ghz, 2 SCSI drives, 600 GB LaCie D2, 3 GB Ram, Nvidia FX500 Suite 1. Avid Media Composer v4.0, Avid Studio Toolkit v 5.7, Pro... [view my complete system specs]
  • Wed, Oct 21 2009 1:38 AM In reply to
    • Geoffs
    • Posts 13
    • Points 135
    I have tested the same setup on my MAC pro running OSX 10.5.8 and intuos drivers 6.1.1 and everything runs fine. So it's clearly just a windows based issue.
    I also tried all the different suggestions on this thread and nothing has worked so far.
  • Thu, Oct 22 2009 1:22 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 4,538
    • Points 52,145
    The issue is most likely caused by Avid and Wacom using different versions of the same library code, or by them creating core program components with the same name.  If that's the case, unless one company or the other is prepared to change their methodology, it may never be fixed.  The fact that it doesn't happen with OSX is consistent with this assumption.
    I briefly also used a Wacom tablet with MC, ran into the same problem, and abandoned the tablet on that system.  The one thing that I did find was that the effect appeared to vary with tablet placement.  If I got the problem, moving the tablet physically often corrected it.
    Now that feels too much like black magic to me.  I tried searching for electromagnetic interference, dodgy cables, all the usual suspects, but was never able to come up with a satisfactory solution.
    It's now a permanent part of my AE workstation, where it does work.
    MC 4.0.5 - Asus P6T Deluxe V2 mobo - Intel i7 920 2.66GHz - nVidia Quadro 1700 - 12 Gbyte mem - Internal 4 Tb SATA II 4-way RAID 5 array - Pyro firewire... [view my complete system specs]
  • Fri, Oct 23 2009 8:38 AM In reply to
    • Geoffs
    • Posts 13
    • Points 135
    I decided to try this in Vista 32 with 4.02 today and had some success. Occasionally I'll still get the problem, but mostly it works.I was using drivers released by wacom a few days ago (6.12-4)
    Are people with the problem running 32bit or 64bit OS? Perhaps it's a 64bit issue?
  • Fri, Oct 23 2009 2:53 PM In reply to
    • Geoffs
    • Posts 13
    • Points 135
    I seem to have fixed the issue for myself. I am running windows 7 64bit, but it should also apply to those using Vista, not sure about XP.
    First thing I did was open up the group policy editor.
    Quick way to do this, in the start menu search bar type cmd
    In the window type gpedit
    Then go Computer configuration>administrative templates>windows components>Tablet PC
    Within that window I pretty well disabled (and by disabled, it sort of means enable, it will make sense when you look at it) everything I could. I don’t know for sure, but it seems to me that the windows tablet support side of things, is double dipping with wacoms drivers.
    Second thing I did was go into the control panel and disable all of the pen flicks etc that I don't use anyway. Here is a list of what I turned off/changed in the settings.
    control panel> Pen and Touch
    In pen options I disabled Press and Hold and I turned off start tablet PC input Panel
    So far I have been running my intuos 4 tablet without much of a hitch. I say "much" as it has still come up with the same problems on the rare occasion, but mostly it’s about 95% working.
    I guess the down side is if you normally utilise pen flicks etc. I don’t so there are no loss to me.
    Hopefully this will work for others. I’m sure I didn’t need to disable everything in the groups policy’s but I figured I had nothing to lose by trying.
  • Tue, Oct 27 2009 3:01 PM In reply to
    • Geoffs
    • Posts 13
    • Points 135
    I just got my official response from wacom
    "We are very sorry. We are aware of the problem. The issue comes from avid's
    side and we cannot change their software. (Our tablet driver has no special
    treatment for Avid). So far we have no sollution for this issue. But avid is
    not listed in our software atlas."
    Haha, oh well. Geeked I guess this issue isn't going to be resolved any time soon.
    One day [:'(]
  • Wed, Nov 4 2009 6:27 PM In reply to
    • JKL32
    • Joined on Sat, Dec 22 2007
    • The Netherlands
    • Posts 80
    • Points 1,100
    The solution for this annoying Intuos4 problem:
    From the
    Avid Knowledge Base
    Why can't I stop playback of my media when my Wacom tablet is connected?
    Some Wacom tablet drivers (version 6.1.0-6, for example) cause playback issues with Media Composer, Newscutter, or Symphony.
    To rectify this:
    1. Close the editor application
    2. Create an emplty text file named "wintab32.dll"(you can Right Click on your Desktop and select "New Text File," then replace the default name with "wintab32.dll")
    3. Make sure the .txt extension is removed
    4. Place it in the same directory as the Media Composer executable [(install drive):\Program Files\Avid\(Editor Application)]
    5. Re-launch the editor application
    I have tried it on my work today, and it works! Link:
    http://avid.custkb.com/avid/com.instranet.InstraServlet?Command=com.instranet.CmdDocVote&Redirect=/avid/app/selfservice/search.jsp&DocId=290089&UEL_DocVote_DocId=290089&UEL_DocVote_Rating=5&UEL_DocVote_VotedDocExtIds=&Module=selfservice
    Avid Media Composer Adrenaline 4.0.5 HP XW8200, 2x 3.4gig, 3 gig ram, Nvidia FX1400. [view my complete system specs]
    Avid Media Composer Adrenaline on HP XW8200
  • Wed, Nov 4 2009 9:31 PM In reply to
    • applebuckets
    • Pittsburgh, Pennsylvania
    • Posts 222
    • Points 2,850
    Really great tip! I wish I would have known that  few months ago. I wound up installing an old driver for my Intuos3. Good to know there
    MCA 3.5.4 hp xw8600 4GB RAM Nvidia FX3700MCA 3.0 hp xw8400 4GB RAM Nvidia FX1300 MacBook Pro 2.2Ghz, 4GB RAM OSX 10.5.6 [view my complete system specs]
  • Wed, Nov 4 2009 10:46 PM In reply to
    • Geoffs
    • Posts 13
    • Points 135
    Fantastic,that works for me too. Happy days.
    Any tech heads know what this fix is actually doing? Not that I care that much, just happy to be able to make use of tech new tablet. Thanks.
  • Thu, Nov 5 2009 12:28 AM In reply to
    • jwrl
    • Posts 4,538
    • Points 52,145
    Dynamic Link Library files (DLLs) are files that contain code that is dynamically loaded as the main program needs it.  The order in which they're searched for is the local launch directory, then several Windows directories.  So by creating a null file called wintab32.dll, Avid will find the local file of that name, attempt to load it, fail, and not try again.
    That file presumably contains support for functions that Avid never directly uses, but is none the less included in Avid's software library code.  It could also be automatically linked in by the compiler regardless of need.  Either way it's apparently totally unnecessary for Avid to function.
  • Thu, Nov 5 2009 7:50 PM In reply to
    I can't believe it!
    Someone finally found a solution that works for this annoying problem ! Excellent.
    Uhm, Mr. Avid, Mr. Wacom - hire this man! Huh?
    Avid Media Composer 4.03 - Nitris DX -HP xw8600 - Win XP Pro SP3 - G-Tech Raid 6TB - Wacom Intuos4 - [view my complete system specs]
    °° There's plenty of room down there °°
