Latest post Wed, Jun 17 2009 5:37 PM by FranzK. 3 replies.
  • Sat, Jun 13 2009 1:47 AM
    • John Moore
    • Joined on Fri, Feb 3 2006
    • Burbank, CA
    • Posts 144
    • Points 1,615
    Major Color Correction Bug SNDX wp 8400 ver. 3.5.1
    Most of the way through an hour long show I discovered that on an HP 8400 SNDX the non linear application of corrections has a bug. I've noticed that color correction applied forward in the sequence, either source clip name or master clip do not always enable the Master Gain and Master Setup parameters. The numbers will reflect the correction but the enable button isn't on. some of the time. Usually when I find the first error subsequent non linear applied corrections will have the error. Enabling the parameter button fixes the shot. It seems that correcting the enable button error and then saving the correction to a bucket and then removing the correction from the clip and then reapplying the correction from the bucket fixes the subsequent clips. This is a major pain in the tush!!!! I had to go back through the entire show shot by shot to see which corrections were at fault. It's 3:30 am I have better things to do. I don't know if this is a problem unique to this system but I haven't seen this on other SN classics or a mac based SNDX, but none of those systems were 3.5.1. Anybody else getting bit by this?
    Symphony Nitris 3.1.1 [view my complete system specs]
    John Moore Barking Trout Productions bigfish@pacbell.net
  • Sat, Jun 13 2009 1:48 AM In reply to
    • John Moore
    • Burbank, CA
    • Posts 144
    • Points 1,615
    Re: Major Color Correction Bug SNDX wp 8400 ver. 3.5.1
    Just heard from Avid and they have a patch.  I'm requesting this be refered to as the first official "Rubin" bug. ;-)
    John Moore
    Studio City, CA
    bigfish@pacbell.net
    --- On Thu, 6/11/09, J Hollywood <geoff.hollywood@avid.com> wrote:
    Subject: Fix for Color Correction Issue
    To: "bigfish@pacbell.net" <bigfish@pacbell.net>
    Date: Thursday, June 11, 2009, 8:22 AM
    Hi John,
    A colleague of mine saw your post on the yahoo forums about the color correction behavior and I wanted to let you know that Avid was made aware of the issue within the last week and we already have a fix that is literally hot off the press.
    I have posted the patch at the FTP link below. This is NOT a full installer - so no need to uninstall your existing 3.5 install. Just unzip the installer and launch it. It will walk you through  the process.
    ftp://avidcsdownload:243spdr04@ftp.avid.com/Barking_Trout
    I've also created a case for you, 00607526, to have for a record of the issue and the fix.
    Please let me know if you have any further problems. If we do not hear back from you within 5 days I will assume the issue is resolved and we'll close out the case.
    Thank you for choosing Avid John!
    Geoff Hollywood
    Supervisor DS/Nitris Technical Support | Video Customer Success
    Avid
    1 Park West - B1
    Tewksbury, MA 01876
    United States
    t + 1 (978) 275-2031
    We're Avid.  Learn more at www.avid.com
  • Sat, Jun 13 2009 3:31 AM In reply to
    • Ra-ey Saleh
    • Sydney, Australia
    • Posts 581
    • Points 6,925
    Thanks for the heads up, John.
    Ra-ey
    HP 8600 Symphony Nitris DX v4.0.2 Sapphire v2.081 Boris Continuum Complete v5.0.4 AvidFX (Boris Red) v5.8 Heroglyth v2.6 Vitascene v1 Adrenaline... [view my complete system specs]
  • Wed, Jun 17 2009 5:37 PM In reply to
    • FranzK
    • UK
    • Posts 15
    • Points 135
    Yep, thanks for posting this John.  I'd found this bug but hadn't had time yet to work out if it was a software problem or something else.  This'll save a lot of time...  Smile
