Latest post Fri, Jul 3 2009 5:31 PM by FunkyDragon. 11 replies.
Page 1 of 1 (12 items)
  • Fri, Jun 12 2009 9:13 PM
    • chrisfoley
    • Joined on Fri, May 8 2009
    • Posts 5
    • Points 75
    Mojo DX deck control issue
    I am working on a new Mojo DX on a Mac.  We are doing an HD project that was supposed to be all tapeless, but for one of the shoots, they shot on HDCAM tapes...
    The serial port which would normally control the deck is useless on the Mojo DX.  Apparently, they just put it there for "manufacturing purposes."  (see page 20 "using the Avid Mojo DX)
    We are renting an HDCAM deck to digitize the footage tonight.  How am I going to get control of the deck thru the Avid?  Do I hook up the SDI for the footage and the firewire for deck control?
    Any help would be appreciated.
  • Fri, Jun 12 2009 9:37 PM In reply to
    Re: Mojo DX deck control issue
    You'll want to use RS-422 deck control.  This is connected to the Mac via the USB port using a Keyspan serial to USB adapter.
    So you'll need:
    1-a RS422 to serial cable
    2-a Keyspan adapter (this adapts the serial signal to USB)
    Once connected you'll configure the deck in the Avid software using the Deck Configuration setting.
    MC 4.0.2, Nitris DX, 8-Core/2.8ghz Harpertown MacPro, 8 GB RAM, Avid VideoRAID 2.5 TB, 1.5 TB internal SATA Raid [view my complete system specs]
    Conformity is the jailer of freedom and the enemy of growth. Motion Inc FCP2Avid
  • Fri, Jun 12 2009 10:00 PM In reply to
    • chrisfoley
    • Posts 5
    • Points 75
    thanx so much for the quick reply...
  • Fri, Jun 12 2009 10:19 PM In reply to
    • chrisfoley
    • Posts 5
    • Points 75
     we have a cable here from the old system that is a rosetta stone model usb/4.  it also says vtr 422 on it.  it is usb on one end and serial on the other
    i am guessing this is the adapter and cable rolled into one?
  • Fri, Jun 12 2009 10:22 PM In reply to
    But you need 422 for the deck.
    I should say... try it!  Big Smile
    If it works then whoo hooo!!!
  • Fri, Jun 12 2009 10:31 PM In reply to
    • chrisfoley
    • Posts 5
    • Points 75
    i just found a keyspan adapter back here as well, so this should work...
    i think this company i am working for this week used to have an old mojo, and it seems the old cables will work with the new mojo as well...
     we will see when the deck gets here
  • Sat, Jun 13 2009 2:16 AM In reply to
    chrisfoley:
    I've come across the same cable. Did you get it to work for you? If so, how? Thanks
    Mac Pro dual dual-core 2.66GHZ, MacOS 10.4.11 3 gigs of ram, 1TB in a RAID configuration, 512 Gig LaCie FW drive, Media Composer 2.8, (soon to be added... [view my complete system specs]
  • Sat, Jun 13 2009 3:29 AM In reply to
    • raspago
    • FL, USA
    • Posts 1,022
    • Points 12,675
    • Moderator: Spanish Language
    .- That's all you need, The USB/4 has a built in RS-422 cable.
    Download the Mac drivers from the addenda site, configure in Avid and you should be set.
    Custom made Intel core 2 duo 2.4 (overclocked to 3.0) Nvidia 8800GS, 3GB Ecc Ram, E-MU 1212M Sound card, Sata Drives, Analog Mojo. [view my complete system specs]
  • Sat, Jun 13 2009 3:34 AM In reply to
    Thanks for the quick response. How will it show up in AVID? Do i need to do anything in the MAC system prefs? And does anyone know if it works with Sony's DSR-1800A?
  • Fri, Jul 3 2009 12:38 AM In reply to
    raspago:
    I just picked up one of these cables today to connect to a DSR-45 - When I go into Deck config I select Direct, but my only option is "No Port"
    I've installed the Mac drivers, what else am I missing?
  • Fri, Jul 3 2009 5:31 PM In reply to
    • FunkyDragon
    • Boston MA
    • Posts 529
    • Points 6,280
    http://avid.custkb.com/avid/app/selfservice/search.jsp?DocId=257457&Hilite=direct+on+no+port
    http://avid.custkb.com/avid/app/selfservice/search.jsp?DocId=260091&Hilite=direct+on+no+port
    MC 3.5 Software License! HP nw9440 Laptop Mojo SDI Camera: DVX100A Deck: DSR 1500a [view my complete system specs]
     The FunkyDragon
    Happy Editing!
