Latest post Fri, Jun 12 2009 12:42 PM by lateral. 6 replies.
Page 1 of 1 (7 items)
  • Tue, Jun 9 2009 6:14 PM
    • lateral
    • UK
    • Posts 126
    • Points 1,525
    Exporting image seq with leading zeroes
    Bear with me, learning DS....
    1. Using the outsource effect...
    I need image0001.ext, image0002.ext, etc.
    Tried this example from DSwiki, filename.[x;y].tif, but ends up with image0.3[0.3].ext, etc.
    Any ideas...
    2. Also how can i view an image sequence (actually DSLR stills)  in Avid Explorer without it "collapsing" or showing all the file as one clip, I know I can capture or link and choose "no" to import them individually, but how can I view/select them individually before importing.
    3. Are there shortcuts to jump to the begining/end of an effect, not the clip or in-outs.
    Many thanks
    I support, use and own various systems. [view my complete system specs]
    Eddtheditor
  • Tue, Jun 9 2009 6:42 PM In reply to
    • Tommyp
    • Joined on Wed, Jan 25 2006
    • Southfield, MI
    • Posts 7
    • Points 95
    Re: Exporting image seq with leading zeroes
    You're close - "filename[0001..9999;4].ext"
    I like to do it this way "filename_[0001..9999;4].ext" The underscore gives a bit of seperation between the fileanme and all the numbers.
    The 0's are place holders until the count gets that high. The 9's are the highest it will go. The 4 is the number of places.
    Once you get to the point in Avid Explorer that shows the images as one seq, double click on them again, it will now expand to show them individually.
    HTH,
    Tom
  • Thu, Jun 11 2009 5:02 AM In reply to
    • dermot
    • Vancouver, Canada
    • Posts 36
    • Points 380
    And if you forget Tom's syntax one late night.. open up DS help, search "padding zero", and cut-n-paste the syntax from there ;-)
    d.
    8600 - 3700 - AJA 2Ke - u320 array - Dream Color [view my complete system specs]
  • Thu, Jun 11 2009 5:50 PM In reply to
    • lateral
    • UK
    • Posts 126
    • Points 1,525
    Thanks for the replys.
    Its the fact that it needs TWO decimals in between the start and end frame numbers that was catching me out.
    So obvious about expanding image seq's in Avid explorer, the icon is even a folder, duh.
    Any shortcuts to go to the start and end of effects? Anyone...
    Eddtheditor
  • Fri, Jun 12 2009 5:15 AM In reply to
    • mrmikster
    • Los Angeleez
    • Posts 353
    • Points 3,945
    • Moderator: Avid DS
      Moderator: MetaFuze
    You can also just type "filename[1..;4]"
    It does the same thing as Tom's version.
    "There are no rules for the brave". Albert Einstein
  • Fri, Jun 12 2009 5:19 AM In reply to
    • mrmikster
    • Los Angeleez
    • Posts 353
    • Points 3,945
      Moderator: MetaFuze
    You can use the shortcuts for first and last keyframe. "alt - left arrow" and "alt - right arrow"
  • Fri, Jun 12 2009 12:42 PM In reply to
    • lateral
    • UK
    • Posts 126
    • Points 1,525
    mrmikster:
    Thats the ticket, MUCH quicker. Big Smile
    Thanks all.
    Eddtheditor
